【光学】基于matlab GUI光的双缝干涉【含Matlab源码 455期】
海神之光 发表于 2022/05/29 03:08:04 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【光学】基于matlab GUI光的双缝干涉【含Matlab源码 455期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = gui_light_13_9(varargin)
% GUI_LIGHT_13_9 M-file for gui_light_13_9.fig
%      GUI_LIGHT_13_9, by itself, creates a new GUI_LIGHT_13_9 or raises the existing
%      singleton*.
%      H = GUI_LIGHT_13_9 returns the handle to a new GUI_LIGHT_13_9 or the handle to
%      GUI_LIGHT_13_9('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in GUI_LIGHT_13_9.M with the given input arguments.
%      GUI_LIGHT_13_9('Property','Value',...) creates a new GUI_LIGHT_13_9 or raises the
%      applied to the GUI before gui_light_13_9_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to gui_light_13_9_OpeningFcn via varargin.
% Edit the above text to modify the response to help gui_light_13_9
% Last Modified by GUIDE v2.5 08-Sep-2007 17:51:39
gui_Singleton = 1;
                   'gui_OpeningFcn', @gui_light_13_9_OpeningFcn, ...
                   'gui_OutputFcn',  @gui_light_13_9_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before gui_light_13_9 is made visible.
function gui_light_13_9_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to gui_light_13_9 (see VARARGIN)
% Choose default command line output for gui_light_13_9
set(handles.lambda_edit,'String',0.0000006);
set(handles.d_edit,'String',0.0015);
set(handles.z_edit,'String',2);
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes gui_light_13_9 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = gui_light_13_9_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in light_pushbutton.
function light_pushbutton_Callback(hObject, eventdata, handles)
% hObject    handle to light_pushbutton (see GCBO)
Lambda=str2num(get(handles.lambda_edit,'String'));
d=str2num(get(handles.d_edit,'String'));
z=str2num(get(handles.z_edit,'String'));
yMax=5*Lambda*z/d;xs=yMax;
Ny=101;ys=linspace(-yMax,yMax,Ny);
for i=1:Ny
    L1=sqrt((ys(i)-d/2).^2+z.^2);
    L2=sqrt((ys(i)+d/2).^2+z.^2);
    Phi=2*pi*(L2-L1)/Lambda;
    B(i,:)=4*cos(Phi/2).^2;
end
NCL=255;%确定所用灰度等级为255级
Br=(B/4.0)*NCL;%定标,使最大光强(4.0)定为最大灰度级(白色)
axes(handles.axes1)
image(xs,ys,Br);
colormap(gray(NCL));
xlabel('双缝干涉条纹')
axes(handles.axes2)
plot(B(:),ys);
xlabel('双缝干涉光强分布')
% --- Executes on button press in close_pushbutton.
function close_pushbutton_Callback(hObject, eventdata, handles)
% hObject    handle to close_pushbutton (see GCBO)
close
function lambda_edit_Callback(hObject, eventdata, handles)
% hObject    handle to lambda_edit (see GCBO)
% Hints: get(hObject,'String') returns contents of lambda_edit as text
%        str2double(get(hObject,'String')) returns contents of lambda_edit as a double
% --- Executes during object creation, after setting all properties.
function lambda_edit_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/114410643
