【雷达通信】基于matlab GUI雷达定位【含Matlab源码 302期】
海神之光 发表于 2022/05/29 03:56:43 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【雷达通信】基于matlab GUI雷达定位【含Matlab源码 302期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = radarSimulation(varargin)
% RADARSIMULATION M-file for radarSimulation.fig
%      RADARSIMULATION, by itself, creates a new RADARSIMULATION or raises the existing
%      singleton*.
%      H = RADARSIMULATION returns the handle to a new RADARSIMULATION or the handle to
%      RADARSIMULATION('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in RADARSIMULATION.M with the given input
%      arguments.
%      RADARSIMULATION('Property','Value',...) creates a new RADARSIMULATION or raises the
%      applied to the GUI before radarSimulation_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to radarSimulation_OpeningFcn via varargin.
% Copyright 2002-2003 The MathWorks, Inc.
% Edit the above text to modify the response to help radarSimulation
% Last Modified by GUIDE v2.5 15-Mar-2008 11:30:35
gui_Singleton = 1;
                   'gui_OpeningFcn', @radarSimulation_OpeningFcn, ...
                   'gui_OutputFcn',  @radarSimulation_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before radarSimulation is made visible.
function radarSimulation_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to radarSimulation (see VARARGIN)
% Choose default command line output for radarSimulation
handles.output = hObject;
handles.FOV = [];
handles.mountains = [];
handles.IF_Freq = 3e7;
handles.currentTime = 0;
handles.targetsFigure = [];
handles.Targets = [];
handles.pulseNum = 0;
handles.plotedTargets = [];
plotDistLines(handles.radarDisplay,10);
PW_Callback(handles.PW, eventdata, handles);    % updating the current PW value
% Update handles structure
guidata(hObject, handles);
reset_Callback(hObject, eventdata, handles)
% UIWAIT makes radarSimulation wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = radarSimulation_OutputFcn(hObject, eventdata, handles)
function PRI_Callback(hObject, eventdata, handles)
% hObject    handle to PRI (see GCBO)
% Hints: get(hObject,'String') returns contents of PRI as text
%        str2double(get(hObject,'String')) returns contents of PRI as a double
% --- Executes during object creation, after setting all properties.
function PRI_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function ZSA_Callback(hObject, eventdata, handles)
% hObject    handle to ZSA (see GCBO)
% Hints: get(hObject,'String') returns contents of ZSA as text
%        str2double(get(hObject,'String')) returns contents of ZSA as a double
function ZSA_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
% --- Executes on slider movement.
function PW_Callback(hObject, eventdata, handles)
    percent = get(hObject,'value');
    str = ['PW = ' num2str(percent*100) '% of the PRI'];
    set(handles.PWstr,'string',str);
% hObject    handle to PW (see GCBO)
% Hints: get(hObject,'Value') returns position of slider
%        get(hObject,'Min') and get(hObject,'Max') to determine range of slider
function PW_CreateFcn(hObject, eventdata, handles)
% Hint: slider controls usually have a light gray background, change
%       'usewhitebg' to 0 to use default.  See ISPC and COMPUTER.
usewhitebg = 1;
if usewhitebg
    set(hObject,'BackgroundColor',[.9 .9 .9]);
else
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
[4]李树锋.基于完全互补序列的MIMO雷达与5G MIMO通信[M].清华大学出版社.2021
[5]何友,关键.雷达目标检测与恒虚警处理(第二版)[M].清华大学出版社.2011
原文链接:qq912100926.blog.csdn.net/article/details/113812250
