【雷达图像】SAR合成孔径雷达成像及处理【含Matlab源码 307期】
海神之光 发表于 2022/05/29 03:51:48 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【雷达图像】SAR合成孔径雷达成像及处理【含Matlab源码 307期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、简介
三、部分源代码
clear all;
%%% (I) parameters' definition
c=3e+8;										% speed of light
pi=3.1415926;	 					   	% pi
j00=sqrt(-1);							   % square root of -1
res_a=2;										% required azimuth resolution
k_r=1.2;										% range factor
Ra=4000.;									% radar working distance
va=70.; 										% radar/platform forward velocity
fc=3.e+9;	 						   	% carrier frequency
FsFactor = 1.0;
theta=90*pi/180;						   % squint angle
lamda=c/fc;									% wavelength
Br=k_r*c/2./res_r;					   % required transmitted bandwidth
Fs=Br*FsFactor;						   % A/D sampling rate
bin_r=c/2./Fs;							   % range bin
Kr=Br/Tp;					  		      % range chirp rate
La=Ra*k_a*lamda/2/res_a;            % required synthetic aperture length
Ta=La/va;									% required synthetic aperture time
fdc=2*va*cos(theta)/lamda;          % doppler centriod
fdr=-2*(va*sin(theta)).^2/lamda/Ra;	% doppler rate
Bd=abs(fdr)*Ta;						   % doppler bandwidth
prf=round(Bd*2);						   % PRF
%%%(II) echo return modelling (point target)
na=fix(Ta*prf/2);							% azimuth sampling number
ta=-na:na;
ta=ta/prf;								   % slow time along azimuth
xa=va*ta-Ra*cos(theta);				   % azimuth location along flight track
Na=2*fix(na);
%x0=[  0  0  0  0  0 ];             % define multi points if you want
%R0=[-20 -10 0 10 20 ];             % x0: azimuth location (positive towards forward velocity)
                                    % R0: slant range location (positive towards far range)
x0=[ 0 0 ];  R0=[ 0 10 ];                % only one point
Npt_num = length(x0);
ra=zeros(Npt_num, length(xa));      % calculate every point target's slant range history
for i=1:Npt_num
	ra(i,:)=sqrt((Ra*sin(theta)+R0(i)).^2+(xa+x0(i)).^2);
end
rmax=max(max(ra));						% max. slant range
rmin=min(min(ra));						% min. slant range
rmc=fix((rmax-rmin)/bin_r);			% range migration,	number
rg=0*ra;                            % initialize
rg=fix((ra-rmin)/bin_r+1);				% range gate index caused by range migration
rgmax=max(max(rg));
rgmin=min(min(rg));
nr=round(Tp*Fs);							% samples of a pluse
tr=1:fix(nr)+1;
tr=tr/Fs-Tp/2;								% fast time within a pluse duration
Nr=nr+rgmax;
sig=zeros(Na,Nr);
for i=1:Na
	for k=1:Npt_num
  		sig(i,rg(k,i):rg(k,i)+nr)=sig(i,rg(k,i):rg(k,i)+nr)+exp(-j00*4*pi/lamda*ra(k,i))*exp(-j00*pi*Kr*(tr).^2);
   end
end
%%%  parameters' definition
pi=3.1415926;
j=sqrt(-1);
Tp=1.e-6; 								% transmitted pulse width
fc=1.e+9;	 						   	% carrier frequency
Br=50.e+6;              % transmitted bandwidth
Fs=200.e+6;             % A/D sample rate
kr=Br/Tp;               % range chirp rate
Nr=Tp*Fs;
Ni=1:Nr;
tr=(Ni-Nr/2)*Tp/Nr;
%Chirp pulse echo from point A
sig_point0 = exp(j*pi*kr*(tr).^2);
%Chirp pulse echo from point B
dr=3;  dr_t=2*dr/c;  dN=dr_t*Fs;
sig_point1 = exp(j*pi*kr*(tr-dr_t).^2);
sig_0 = zeros(1, 3*Nr); sig_1 = sig_0; sum_sig = sig_0;
sig_0(Nr+1:2*Nr)=sig_point0;
sig_1(Nr+dN+1:2*Nr+dN)=sig_point1;
% Summary echo signal of A and B
sum_sig = sig_0 + sig_1;
figure;
subplot(4,1,1); plot(real(sig_0));
subplot(4,1,2); plot(real(sig_1));
subplot(4,1,3); plot(real(sum_sig));
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/113824675
