【物理应用】基于matlab GUI家庭室内温湿度控制【含Matlab源码 326期】
海神之光 发表于 2022/05/29 03:50:56 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【物理应用】基于matlab GUI家庭室内温湿度控制【含Matlab源码 326期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = HomeMonitoringSystem(varargin)
% HOMEMONITORINGSYSTEM MATLAB code for HomeMonitoringSystem.fig
%      HOMEMONITORINGSYSTEM, by itself, creates a new HOMEMONITORINGSYSTEM or raises the existing
%      singleton*.
%      H = HOMEMONITORINGSYSTEM returns the handle to a new HOMEMONITORINGSYSTEM or the handle to
%      HOMEMONITORINGSYSTEM('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in HOMEMONITORINGSYSTEM.M with the given input arguments.
%      HOMEMONITORINGSYSTEM('Property','Value',...) creates a new HOMEMONITORINGSYSTEM or raises the
%      applied to the GUI before HomeMonitoringSystem_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to HomeMonitoringSystem_OpeningFcn via varargin.
% Edit the above text to modify the response to help HomeMonitoringSystem
% Last Modified by GUIDE v2.5 09-Apr-2013 21:36:08
gui_Singleton = 1;
    'gui_OpeningFcn', @HomeMonitoringSystem_OpeningFcn, ...
    'gui_OutputFcn',  @HomeMonitoringSystem_OutputFcn, ...
    'gui_LayoutFcn',  [] , ...
    'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before HomeMonitoringSystem is made visible.
function HomeMonitoringSystem_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to HomeMonitoringSystem (see VARARGIN)
% Choose default command line output for HomeMonitoringSystem
handles.output = hObject;
web -browser http://www.ilovematlab.cn/thread-201914-1-1.html
% Update handles structure
global smtp_server_status camera_working  temp_humd_working
smtp_server_status=0; %邮件系统是否工作 Email System Status
camera_working=0;%相机是否能工作 Camera can work or not?
temp_humd_working=0; %温度计、湿度计是否在工作 temperature/humidity sensor works or not?
handles.live_view=0; %系统是否在监视
handles.receiver1='';%接受人邮件地址
handles.receiver2='';
handles.receiver3='';
%默认为中文界面  By Default, load the Chinese GUI
handles.my_gui_msg_struct = msg_cn();
guidata(hObject, handles);
%删除所有现有的计时器
%Delete all timers in the system
try
    out = timerfind;
    stop(out);
    delete(out);
catch exception
end
% UIWAIT makes HomeMonitoringSystem wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = HomeMonitoringSystem_OutputFcn(hObject, eventdata, handles)
function Untitled_1_Callback(hObject, eventdata, handles)
% hObject    handle to Untitled_1 (see GCBO)
% --- Executes on button press in PB_real_time_video.
function PB_real_time_video_Callback(hObject, eventdata, handles)
% hObject    handle to PB_real_time_video (see GCBO)
% UD_capture_image(hObject,handles);
% TM_video = timer('TimerFcn',{@UD_capture_image,hObject,handles}, 'Period', 0.5);
% start(TM_video);
%相机是否能正常工作,只有获取第一副图片以后,该状态才被改变
%The camera is working unless one image is captured
global camera_working
camera_working=0;
warning('off');
% 判断系统是否已经有定时器在运行,若是,则删除现有的定时器
% Determine if it is already running. Stop the timer is so.
try
    out = timerfind('Tag', 'Continuous Capture');
    stop(out);
    delete(out);
catch exception
end
% 获得帧数
% Get the fps from GUI
try
    video_fs=1/str2num(get(handles.TE_video_fs,'string'));
    if str2num(get(handles.TE_video_fs,'string'))<0 | str2num(get(handles.TE_video_fs,'string'))>100
        throw(exception);
    end
catch exception
    msgbox(handles.my_gui_msg_struct.live_view_wrong_fps);
    return;
end
% 获取抓取图片的URL链接
% Get the URL for image capture
handles.image_url=get(handles.TE_image_url,'string');
% 定义一个全局变量,用于储存网络摄像头的用户名和密码
% Define a global variable to store username and password
global global_url_pwd;
global_url_pwd=base64_encode(get(handles.TE_url_pwd,'string'));
% 创建一个计时器,回调函数为UD_capture_image
% Create a timer with callback UD_capture_image
handles.UD_continuous_capture_timer = timer('Tag','Continuous Capture','period',video_fs);
set(handles.UD_continuous_capture_timer,'ExecutionMode','fixedrate','StartDelay',0.5);
set(handles.UD_continuous_capture_timer,'TimerFcn',{@UD_capture_image,hObject,handles});
start(handles.UD_continuous_capture_timer);
function UD_capture_image(~, ~, hObject,handles)
% 读取图片
% Read an image
try
    handles.raw_image=imread_auth(handles.image_url);
catch exception
    msgbox(handles.my_gui_msg_struct.live_view_wrong_URL_username_password);
    try
        stop(out);
        delete(out);
    catch exception2
    end
    return;
end
% 显示图片,更新状态
% show the image, Update System Status
handles.live_view=1;
camera_working=1;
imshow(handles.raw_image,'Parent',handles.AX_video);
% --- Executes on button press in PB_stop_real_time_video.
function PB_stop_real_time_video_Callback(hObject, eventdata, handles)
% hObject    handle to PB_stop_real_time_video (see GCBO)
try
    stop(out);
    delete(out);
catch exception
end
% --- Executes when user attempts to close figure1.
function figure1_CloseRequestFcn(hObject, eventdata, handles)
% hObject    handle to figure1 (see GCBO)
% Hint: delete(hObject) closes the figure
% delete(hObject);
% Delte all timers
try
    out = timerfind;
    stop(out);
    delete(out);
catch exception
end
delete(hObject);
function TE_video_fs_Callback(hObject, eventdata, handles)
% hObject    handle to TE_video_fs (see GCBO)
% Hints: get(hObject,'String') returns contents of TE_video_fs as text
%        str2double(get(hObject,'String')) returns contents of TE_video_fs as a double
% --- Executes during object creation, after setting all properties.
function TE_video_fs_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in CB_monday.
function CB_monday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_monday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_monday
% --- Executes on button press in CB_tuesday.
function CB_tuesday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_tuesday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_tuesday
% --- Executes on button press in CB_wednesday.
function CB_wednesday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_wednesday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_wednesday
% --- Executes on button press in CB_thursday.
function CB_thursday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_thursday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_thursday
% --- Executes on button press in CB_friday.
function CB_friday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_friday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_friday
% --- Executes on button press in CB_saturday.
function CB_saturday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_saturday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_saturday
% --- Executes on button press in CB_sunday.
function CB_sunday_Callback(hObject, eventdata, handles)
% hObject    handle to CB_sunday (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of CB_sunday
% --- Executes on selection change in PM_hours.
function PM_hours_Callback(hObject, eventdata, handles)
% hObject    handle to PM_hours (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns PM_hours contents as cell array
%        contents{get(hObject,'Value')} returns selected item from PM_hours
function PM_hours_CreateFcn(hObject, eventdata, handles)
% Hint: popupmenu controls usually have a white background on Windows.
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/113851070
