【人民币识别】基于matlab GUI RGB和BP神经网络的人民币识别系统【含Matlab源码 097期】
海神之光 发表于 2022/05/29 03:13:42 2022/05/29
【摘要】 一、简介 本设计为基于MATLAB的人民币识别系统。带有一个GUI界面。先利用radon进行倾斜校正,根据不同纸币,选择不同维度的参数识别纸币金额,有通过RGB分量识别100元; 通过面额图像的宽度识...
一、简介
通过面额图像的宽度识别1元、5元;通过构建矩形结构体识别10元 ;通过RGB分量识别 20元 与 50元。
二、部分源代码
function varargout = main(varargin)
% MAIN MATLAB code for main.fig
%      MAIN, by itself, creates a new MAIN or raises the existing
%      singleton*.
%      H = MAIN returns the handle to a new MAIN or the handle to
%      MAIN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MAIN.M with the given input arguments.
%      MAIN('Property','Value',...) creates a new MAIN or raises the
%      applied to the GUI before main_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to main_OpeningFcn via varargin.
% Edit the above text to modify the response to help main
% Last Modified by GUIDE v2.5 29-May-2020 00:04:07
gui_Singleton = 1;
    'gui_OpeningFcn', @main_OpeningFcn, ...
    'gui_OutputFcn',  @main_OutputFcn, ...
    'gui_LayoutFcn',  [] , ...
    'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before main is made visible.
function main_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to main (see VARARGIN)
% Choose default command line output for main
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes main wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = main_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
%% 图像读取
[filename, pathname] = uigetfile({'*.jpg;*.tif;*.png;*.gif','All Image Files';...
    '*.*','All Files' });
l = imread([ pathname,filename]);
axes(handles.axes1)
imshow(l);
title('原始图像')
l1=rgb2gray(l);                %将真彩色图像转换为灰度图像
bw1=edge(l1,'sobel', 'both');  %采用sobel算子进行边缘检测
handles.bw1=bw1;
theta=0:179;                   %定义theta角度范围
r=radon(bw1,theta);            %对图像进行Radon变换
%%%%%检测Radon变换矩阵中的峰值所对应的列坐标%%%%
[m,n]=size(r);
c=1;
for i=1:m
    for j=1:n
        if  r(1,1)<r(i,j)
            r(1,1)=r(i,j);
            c=j;
        end
    end
end
rot=90-c;
pic=imrotate(l,rot,'crop');                     %对图片进行旋转矫正
handles.pic=pic;
pic_gray=rgb2gray(pic);                         %转换为灰度图像
handles.pic_gray=pic_gray;
pic_a=imadjust(pic_gray,[0,0.001],[1,0]);       %明暗反转
pic_b=1.3*pic_gray+0.7*pic_a;
pic_c=imadjust(pic_b,[0.5,1],[0,1]);            %明暗反转
handles.pic_c=pic_c;
pic_b_edge=edge(pic_c,'sobel');                 %采用sobel算子进行边缘检测
handles.pic_b_edge=pic_b_edge;
se=[1;1;1];                                     %线型结构元素
pic_imerode=imerode(pic_b_edge,se);             %腐蚀图像
handles.pic_imerode=pic_imerode;
se=strel('rectangle',[60,60]);                  %矩形结构元素
pic_imclose=imclose(pic_imerode,se);            %图像聚类、填充图像
handles.pic_imclose=pic_imclose;
pic_bwareaopen=bwareaopen(pic_imclose,10000);   %去除聚团灰度值小于10000的部分
%%%%%求纸币行起始位置和终止位置%%%%%
[y,x]=size(pic_bwareaopen);
I6=double(pic_bwareaopen);
Y1=zeros(y,1);
for i=1:y
    for j=1:x
        if(I6(i,j,1)==1)
            Y1(i,1)= Y1(i,1)+1;
        end
    end
end
[temp MaxY]=max(Y1);
%%%%%%求纸币列起始位置和终止位置%%%%%
PY1=MaxY;
while ((Y1(PY1,1)>=50)&&(PY1>1))
    PY1=PY1-1;
end
PY2=MaxY;
while ((Y1(PY2,1)>=50)&&(PY2<y))
    PY2=PY2+1;
end
IY=pic(PY1:PY2,:,:);
X1=zeros(1,x);
for j=1:x
    for i=PY1:PY2
        if(I6(i,j,1)==1)
            X1(1,j)= X1(1,j)+1;
        end
    end
end
%%提取并画出背景中的RMB图像%%
PX1=1;
while ((X1(1,PX1)<3)&&(PX1<x))
    PX1=PX1+1;
end
PX2=x;
while ((X1(1,PX2)<3)&&(PX2>PX1))
    PX2=PX2-1;
end
dw=pic(PY1:PY2,PX1:PX2,:);
dw_gray=rgb2gray(dw);
dw_gray=imadjust(dw_gray,[0,1],[1,0]);
dw_bw=im2bw(dw_gray);
handles.dw_bw=dw_bw;
%%分割提取RMB数值图像%%
[m,n]=size(dw_bw);
m1=round(m/3);
m2=round(2*m/3);
n1=round(n/6);
n2=round(n/3);
n3=round(2*n/3);
n4=round(5*n/6);
sum1=sum(sum(dw_bw(m1:m2,n1:n2)));
sum2=sum(sum(dw_bw(m1:m2,n3:n4)));
if sum1>sum2
    dw=imrotate(dw,180,'crop');
end
%%图像处理%%
x=dw;
x1=imresize(x,[236,500]);%'缩放图像
z=imcrop(x1,[270,150,160,65]);%对图像进行剪切,选取有效区域
I=imcrop(x1,[130,60,130,65]);    %对图像进行剪切,选取有效区域
handles.I=I;
I1=rgb2gray(I);    %转换为灰度图像
I2=medfilt2(I1);    %滤波默认窗口
I3=imadjust(I2,[0.3,0.5],[0,1],1);   %明暗反转
I4=im2bw(I3);
handles.I4=I4;
se=strel('rectangle',[3,3]);   %构造结构函数,以长方形构造一个se
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/112461586
