【数学建模】基于matlab时变参数随机波动率向量自回归模型(TVP-VAR)【含Matlab源码 037期】
海神之光 发表于 2022/05/29 05:00:19 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab时变参数随机波动率向量自回归模型(TVP-VAR)【含Matlab源码 037期】 获取代码方式2: 通过订阅紫...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%==================================4.1 Main================================
clear;
clc;
% Load Korobilis (2008) quarterly data
load ydata.dat; % data
load yearlab.dat; % data labels
%----------------------------------BASICS----------------------------------
Y=ydata;
t=size(Y,1);        % t - The total number of periods in the raw data (t=215)
M=size(Y,2);        % M - The dimensionality of Y (i.e. the number of variables)(M=3)
tau = 40;           % tau - the size of the training sample (the first forty quarters)
p = 2;              % p - number of lags in the VAR model
%% Generate the Z_t matrix, i.e. the regressors in the model.
ylag = mlag2(Y,p);          % This function generates a 215x6 matrix with p lags of variable Y.
ylag = ylag(p+tau+1:t,:);   % Then remove our training sample, so now a 173x6 matrix.
K = M + p*(M^2);            % K is the number of elements in the state vector
% Here we distribute the lagged y data into the Z matrix so it is
% conformable with a beta_t matrix of coefficients.
Z = zeros((t-tau-p)*M,K);
for i = 1:t-tau-p
    ztemp = eye(M);
    for j = 1:p
        xtemp = ylag(i,(j-1)*M+1:j*M);
        xtemp = kron(eye(M),xtemp);
        ztemp = [ztemp xtemp];
    end
    Z((i-1)*M+1:i*M,:) = ztemp;
end
% Redefine our variables to exclude the training sample and the first two
% lags that we take as given, taking total number of periods (t) from 215
% to 173.
y = Y(tau+p+1:t,:)';
yearlab = yearlab(tau+p+1:t);
t=size(y,2); % t now equals 173
%% --------------------MODEL AND GIBBS PRELIMINARIES-----------------------
nrep = 5000;    % Number of sample draws
nburn = 2000;   % Number of burn-in-draws
it_print = 100; % Print in the screen every "it_print"-th iteration
%% INITIAL STATE VECTOR PRIOR
% We use the first 40 observations (tau) to run a standard OLS of the
% measurement equation, using the function ts_prior. The result is
% estimates for priors for B_0 and Var(B_0).
[B_OLS,VB_OLS]= ts_prior(Y,tau,M,p);
% Given the distributions we have, we now have to define our priors for B,
% Q and Sigma. These are set in accordance with how they are set in
% Primiceri (2005). These are the hyperparameters of the beta, Q and Sigma
% initial priors.
B_0_prmean = B_OLS;
B_0_prvar = 4*VB_OLS;
Q_prmean = ((0.01).^2)*tau*VB_OLS;
Q_prvar = tau;
Sigma_prmean = eye(M);
Sigma_prvar = M+1;
% To start the Kalman filtering assign arbitrary values that are in support
% of their priors, Q and Sigma.
consQ = 0.0001;
Qdraw = consQ*eye(K);
Sigmadraw = 0.1*eye(M);
% Create some matrices for storage that will be filled in once we
% start the Gibbs sampling.
Btdraw = zeros(K,t);
Bt_postmean = zeros(K,t);
Qmean = zeros(K,K);
Sigmamean = zeros(M,M);
%% -------------------------IRF-PRELIMINARIES------------------------------
nhor = 21;     % The number of periods in the impulse response function.
% Matricies to be filled containing IRFs for 1975q1, 1981q3, 1996q1. The
% dimensions correspond to the iterations of the gibbs sample, each of the
% variables, and each of the 21 periods of the IRF analysis.
imp75 = zeros(nrep,M,nhor);
imp81 = zeros(nrep,M,nhor);
imp96 = zeros(nrep,M,nhor);
% This corresponds to variable J introduced in equation (14) in the report
bigj = zeros(M,M*p);
bigj(1:M,1:M) = eye(M);
%% ================ START GIBBS SAMPLING ==================================
tic; % This is just a timer
disp('Number of iterations');
for irep = 1:nrep + nburn    % 7000 gibbs iterations starts here
    % Print iterations - this just updates on the progress of the sampling
    if mod(irep,it_print) == 0
        disp(irep);toc;
    end
%% Draw 1: B_t from p(B_t|y,Sigma)
    % We use the function 'carter_kohn_hom' to to run the FFBS algorithm.
    % This results in a 21x173 matrix, corresponding to one Gibbs sample
    % draw of each of the coefficients in each time period. The inputs
    % Sigmadraw and Qdraw are updated for each Gibbs sample repetition.
    [Btdraw] = carter_kohn_hom(y,Z,Sigmadraw,Qdraw,K,M,t,B_0_prmean,B_0_prvar);
%% Draw 2: Q from p(Q^{-1}|y,B_t) which is i-Wishart
    % We draw Q from an Inverse Wishart distribution. The parameters
    % of the distribution are derived as equation (11) in the main report.
    % The mean is taken as the inverse of the accumulated sum of squared
    % errors added to the prior mean, and the variance is simply t.
    % Differencing Btdraw to create the sum of squared errors
    Btemp = Btdraw(:,2:t)' - Btdraw(:,1:t-1)';
    sse_2Q = zeros(K,K);
    for i = 1:t-1
        sse_2Q = sse_2Q + Btemp(i,:)'*Btemp(i,:);
    end
    Qinv = inv(sse_2Q + Q_prmean);      % compute mean to use for Wishart draw
    Qinvdraw = wish(Qinv,t+Q_prvar);    % draw inv q from the wishart distribution
    Qdraw = inv(Qinvdraw);              % find non-inverse q
%% Draw 3: Sigma from p(Sigma|y,B_t) which is i-Wishart
    % We draw Sigma from an Inverse Wishart distribution. The parameters
    % of the distirbution are derived as equation (10) in the main report.
    % The mean is taken as the inverse of the sum of squared residuals
    % added to the prior mean. The variance is simply t.
    % Find residuals using data and the current draw of coefficients
    resids = zeros(M,t);
    for i = 1:t
        resids(:,i) = y(:,i) - Z((i-1)*M+1:i*M,:)*Btdraw(:,i);
    end
    % Create a matrix for the accumulated sum of squared residuals, to
    % be used as the mean parameter in the i-Wishart draw below.
    sse_2S = zeros(M,M);
    for i = 1:t
        sse_2S = sse_2S + resids(:,i)*resids(:,i)';
    end
    Sigmainv = inv(sse_2S + Sigma_prmean);          % compute mean to use for the Wishart
    Sigmainvdraw = wish(Sigmainv,t+Sigma_prvar);    % draw from the Wishsart distribution
    Sigmadraw = inv(Sigmainvdraw);                  % turn into non-inverse Sigma
%% IRF
    % We only apply IRF analysis once we have exceeded the burn-in draws phase.
    if irep > nburn;
            % Create matrix that is going to contain all beta draws over
            % which we will take the mean after the Gibbs sampler as our moment
            % estimate:
            Bt_postmean = Bt_postmean + Btdraw;
            % biga is the A matrix of the VAR(1) version of our VAR(2) model,
            % found in equation (12. biga changes in every period of the
            % analysis, because the coefficients are time varying, so we
            % apply the analysis below in every time period.
            biga = zeros(M*p,M*p);
            for j = 1:p-1
                biga(j*M+1:M*(j+1),M*(j-1)+1:j*M) = eye(M); % fill the A matrix with identity matrix (3) in bottom left corner
            end
            % The following procedure is applied separately in each time period.
            % This loop takes coefficients of the relevant time period from
            % Bt_draw (which contains all coefficients for all t) and uses
            % them to update the biga matrix, so that it can change for
            % every t.
            for i = 1:t
                bbtemp = Btdraw(M+1:K,i);  % get the draw of B(t) at time i=1,...,T  (exclude intercept)
                splace = 0;
                for ii = 1:p
                    for iii = 1:M
                        biga(iii,(ii-1)*M+1:ii*M) = bbtemp(splace+1:splace+M,1)'; % Load non-intercept coefficient draws
                        splace = splace + M;
                    end
                end
                % Next we want to create a shock matrix in which the third
                % column is [0 0 1]', therefore implementing a unit shock
                % in the interest rate.
                shock = eye(3);
                % Now get impulse responses for 1 through nhor future
                % periods. impresp is a 3x63 matrix which contains 9
                % response values in total for each period, 3 for each
                % variable. These three responses correspond to the 3
                % possible shocks that are contained in the schock
                % matrix
                % bigai is updated through mulitiplication with the
                % coefficient matrix after each time period.
                % Create a results matrix to store impulse responses in all periods
                impresp = zeros(M,M*nhor);
                % Fill in the first period of the results matrix with the shock (as defined above)
                impresp(1:M,1:M) = shock;
                % Create a separate variable for the a matrix so that we
                % can update it for each period of the IRF analysis.
                bigai = biga;
                % This follows the impulse response function as in equation 15.
                % Fill in each period of the results matrix according to
                % the impulse response function formula.
                for j = 1:nhor-1
                    impresp(:,j*M+1:(j+1)*M) = bigj*bigai*bigj'*shock;
                    bigai = bigai*biga; % update the coefficient matrix for next period
                end
                % The section below keeps only the responses that we are interested in:
                % - those from the periods 1975q1, 1981q3, and 1996q1
                % - those that correspond to the shock in the interest
                % rate (i.e. those caused by the third column of our shock
                % matrix).
                if yearlab(i,1) == 1975.00;   % store only IRF from 1975:Q1
                    impf_m = zeros(M,nhor);
                    jj=0;
                    for ij = 1:nhor
                        jj = jj + M;    % select only the third column for each time period of the IRF
                        impf_m(:,ij) = impresp(:,jj);
                    end
                % For each iteration of the Gibbs sampler, fill in the
                % results along the first dimension
                    imp75(irep-nburn,:,:) = impf_m;
                end
                if yearlab(i,1) == 1981.50;   % store only IRF from 1981:Q3
                    jj=0;
                    for ij = 1:nhor
                    end
                % For each iteration of the Gibbs sample, fill in the
                    imp81(irep-nburn,:,:) = impf_m;
                end
                if yearlab(i,1) == 1996.00;   % store only IRF from 1996:Q1
                    jj=0;
                    for ij = 1:nhor
                    end
                    imp96(irep-nburn,:,:) = impf_m;
                end
            end % End getting impulses for each time period
        end % End the impulse response calculation section
end % End main Gibbs loop (for irep = 1:nrep+nburn)
clc;
toc; % Stop timer and print total time
%% ================ END GIBBS SAMPLING ==================================
% Even though it is not used in our IRF analysis since we are integrating
% that into the Gibbs sampling loop, here is how to take the mean of the
% draw of the betas as moment estimate:
Bt_postmean = Bt_postmean./nrep;
%% Graphs and tables
% This works out the percentage range of that each variable's coefficient
% spans across time. I.e. to what extent was the TVP facility used by each
% variable in the model? This is calculated by finding the range for each
% variable as a percentage of the mean coefficient size for that variable.
% The result is a 21x1 vector, and it is reshaped into a 3x7 matrix in order
% to map onto the system of equations (2,3,and 4) set out in the report.
Bt_range = ones(21,1)
for i = 1:21
    Bt_range(i) = abs((max(Bt_postmean(i,:))-min(Bt_postmean(i,:)))/mean(Bt_postmean(i,:)))
end
Bt_range = reshape(Bt_range,3,7)
% Create a table of coefficient ranges for export to the report
rowNames = {'Inflation','Unemployment','Interest Rate'};
colNames = {'Intercept','Inf_1','Unemp_1', 'IR_1','Inf_2','Unemp_2', 'IR_2'};
pc_change_table = array2table(Bt_range,'RowNames',rowNames,'VariableNames',colNames)
writetable(pc_change_table,'pc_change.csv')
% Now plot a separate chart for each of the coefficients
figure
for i = 1:21
    subplot(7,3,i)
    plot(1:t,Bt_postmean(i,:))
end
% Now we move to plotting the IRF. This section takes moments along the
% first dimension, i.e. across the Gibbs sample iterations. The moments
% are for the 16th, 50th and 84th percentile.
    qus = [.16, .5, .84];
    imp75XY=squeeze(quantile(imp75,qus));
    imp81XY=squeeze(quantile(imp81,qus));
    imp96XY=squeeze(quantile(imp96,qus));
    % Plot impulse responses
    figure
    set(0,'DefaultAxesColorOrder',[0 0 0],...
        'DefaultAxesLineStyleOrder','--|-|--')
    subplot(3,3,1)
    plot(1:nhor,squeeze(imp75XY(:,1,:)))
    title('Impulse response of inflation, 1975:Q1')
    xlim([1 nhor])
    ylim([-0.2 0.1])
%    % yline(0)
    set(gca,'XTick',0:3:nhor)
    subplot(3,3,2)
    plot(1:nhor,squeeze(imp75XY(:,2,:)))
    title('Impulse response of unemployment, 1975:Q1')
    xlim([1 nhor])
    ylim([-0.2 0.2])
   % yline(0)
    subplot(3,3,3)
    %ylim([0 1])
%    % yline(0)
    plot(1:nhor,squeeze(imp75XY(:,3,:)))
    title('Impulse response of interest rate, 1975:Q1')
    xlim([1 nhor])
    %ylim([-0.3 0.1])
   % yline(0)
    subplot(3,3,4)
    plot(1:nhor,squeeze(imp81XY(:,1,:)))
    title('Impulse response of inflation, 1981:Q3')
    xlim([1 nhor])
    ylim([-0.2 0.1])
   % yline(0)
    subplot(3,3,5)
    plot(1:nhor,squeeze(imp81XY(:,2,:)))
    title('Impulse response of unemployment, 1981:Q3')
    xlim([1 nhor])
    ylim([-0.2 0.2])
   % yline(0)
    subplot(3,3,6)
    plot(1:nhor,squeeze(imp81XY(:,3,:)))
    title('Impulse response of interest rate, 1981:Q3')
    xlim([1 nhor])
    %ylim([-0.4 0.1])
   % yline(0)
    subplot(3,3,7)
    plot(1:nhor,squeeze(imp96XY(:,1,:)))
    title('Impulse response of inflation, 1996:Q1')
    xlim([1 nhor])
    ylim([-0.2 0.1])
   % yline(0)
    subplot(3,3,8)
    plot(1:nhor,squeeze(imp96XY(:,2,:)))
    title('Impulse response of unemployment, 1996:Q1')
    xlim([1 nhor])
    ylim([-0.2 0.2])
   % yline(0)
    subplot(3,3,9)
    plot(1:nhor,squeeze(imp96XY(:,3,:)))
    title('Impulse response of interest rate, 1996:Q1')
    xlim([1 nhor])
     %ylim([0 1])
    % yline(0)
disp('             ')
disp('To plot impulse responses, use:         plot(1:nhor,squeeze(imp75XY(:,VAR,:)))           ')
disp('             ')
disp('where VAR=1 for impulses of inflation, VAR=2 for unemployment and VAR=3 for interest rate')
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
  • 334
  • 335
  • 336
  • 337
  • 338
  • 339
  • 340
  • 341
  • 342
  • 343
  • 344
  • 345
  • 346
  • 347
  • 348
  • 349
  • 350
  • 351
  • 352
  • 353
  • 354
  • 355
  • 356
  • 357
  • 358
  • 359
  • 360
  • 361
  • 362
  • 363
  • 364
  • 365
  • 366
  • 367
  • 368
  • 369
  • 370
  • 371
  • 372
  • 373
  • 374
  • 375
  • 376
  • 377
  • 378
  • 379
  • 380
  • 381
  • 382
  • 383
  • 384
  • 385
  • 386
  • 387
  • 388
  • 389
  • 390
  • 391
  • 392
  • 393
  • 394
  • 395
  • 396
  • 397
  • 398
  • 399
  • 400
  • 401
  • 402
  • 403
  • 404
  • 405
  • 406
  • 407
  • 408
  • 409
  • 410
  • 411
  • 412
  • 413
  • 414
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/112152864
