【数字信号调制】基于matlab GUI QPSK调制+解调【含Matlab源码 646期】
海神之光 发表于 2022/05/29 02:40:59 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源: 【数字信号调制】基于matlab GUI QPSK调制+解调【含Matlab源码 646期】 获取代码方式2: 通过订阅紫极神光博客付费专...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、QPSK简介
1 调制模型
与QPSK相比,OQPSk调制方式在复数通道Q通道中,插入了一个比特的时延Tb。
2.优点
OQPSK能够把180度的相移变化变成两个π /2的相位变化,因此相轨道远离了原点
3 解调
因为调制时Q路进行了延时,所以解调时I路进行延时
三、部分源代码
function varargout = GUI_QPSK(varargin)
% GUI_QPSK MATLAB code for GUI_QPSK.fig
%      GUI_QPSK, by itself, creates a new GUI_QPSK or raises the existing
%      singleton*.
%      H = GUI_QPSK returns the handle to a new GUI_QPSK or the handle to
%      GUI_QPSK('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in GUI_QPSK.M with the given input arguments.
%      GUI_QPSK('Property','Value',...) creates a new GUI_QPSK or raises the
%      applied to the GUI before GUI_QPSK_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to GUI_QPSK_OpeningFcn via varargin.
% Edit the above text to modify the response to help GUI_QPSK
% Last Modified by GUIDE v2.5 03-Dec-2018 20:37:56
gui_Singleton = 1;
                   'gui_OpeningFcn', @GUI_QPSK_OpeningFcn, ...
                   'gui_OutputFcn',  @GUI_QPSK_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before GUI_QPSK is made visible.
function GUI_QPSK_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to GUI_QPSK (see VARARGIN)
% Choose default command line output for GUI_QPSK
handles.output = hObject;
s=round(rand(1,100));  %生成二进制基带数据并画出基带信号图
N=1:100;
%figure(1);subplot(311);stem(N,s);title('基带信号');grid on;
Ps=1;
M=4;        %QPSK星座图
d=sqrt(Ps)*sin(pi/M);
A=[1+1*i,-1+1*i,-1-1*i,1-1*i]*d;
%subplot(312);scatter(real(A),imag(A),'filled');title('QPSK星座图');hold on;
theta=0:pi/100:2*pi;
x=cos(theta);
y=sin(theta);
%plot(x,y);grid on;
Maptable=[0 0;0 1;1 1;1 0];        %QPSK格雷码比特映射
for j=1:2:100
    for m=1:M
         if isequal(s(j:j+1),Maptable(m,:))
            Qu((j+1)/2)= (2*m-1)*pi/4;
            x((j+1)/2)=A(m);
         break
         end
    end
end               %基带数据s携带的信息映射到X[n]
Am=1;             %载波调制
T=0.0001;            fc=6/T;
Smpl=1000;
deltaT=T/Smpl;    %连续时间离散化间隔
Ns=5;            %画出Ns个符号的波形
t=deltaT:deltaT:Ns*T;  %离散时间序列
for j=1:Ns
    index=(j-1)*Smpl+1:j*Smpl; %第i个符号对应的离散时间序号
    g(index)=1;              %矩形脉冲成型
    X(index)=Am*g(index).*cos(2*pi*fc*t(index)+Qu(ceil(index/100.01))); %载波调制信号
end
%subplot(313);plot(t,X);title('QPSK调制信号波形');
SNR_dB=15;    %定义信噪比
SNR=10^(SNR_dB/10); %定义线性信噪比
Ps=1;     %发射功率
Pn=Ps/SNR;  %噪声方差
x=x(1:50);
z=sqrt(Pn/2)*(randn(size(x))+randn(size(x))*i); %生成白噪声
h=1;  %AWGN信道下,信道增益h=1
y=h*x+z;   %基带接受信号
%figure(2);subplot(211);scatter(real(y(1:10)),imag(y(1:10)),'filled'); %y的星座图title('QPSK接收星座图');
for j=1:length(y)
    Dist=abs(y(j)-A);                  %第j个接受信号与各星座图点的距离
    [~,Index]=min(Dist);               %找到距离最近的点
    x_est(j)=A(Index);                 %得到发射调制信号的估计
    s_est(2*j-1:2*j)=Maptable(Index,:);   %得到比特数据的估计
end
W=1:100;
%subplot(212);stem(W,s_est);title('QPSK解调后信号');
for n=1:25
  Pe_t(n)=2*sqrt(2)/4*erfc(sqrt(2*n)*sin(pi/M))-sqrt(2)/4*erfc(sqrt(2*n)*sin(pi/M))* sqrt(2)/4*erfc(sqrt(2*n)*sin(pi/M));
  Pb_t(n)=0.5*Pe_t(n);
end
PESUM=0;
PBSUM=0
for n=1:25
for m=1:1000
        SNR=n;
        Ps=1;
        Pn=Ps/SNR;
        h=1;
        y=h*x+z;
        for j=1:length(y)
            Dist=abs(y(j)-A);
            x_est(j)=A(Index);
        end
for  k=1:100
if(s(k)+s_est(k)==1)
      		   PBSUM=PBSUM+1;
end
        end
for k1=1:50
if isequal(x(k1),x_est(k1))
               PESUM=PESUM+0;
           else
               PESUM=PESUM+1;
end
end
end
Pb(n)=PBSUM/1000/100;
Pe(n)=PESUM/1000/50;
PBSUM=0;
PESUM=0;
end
SNRX=1:25;
%figure(3);plot(SNRX,Pb); hold on;plot(SNRX,Pe);scatter(SNRX,Pe_t);scatter(SNRX,Pb_t, 'filled');
%xlabel('信噪比 SNR(r/dB)');title('AWGN信道下误码率与误符号率曲线'); axis([1 25 0 1]);grid on;hold off;
H=sqrt(1/2)*(randn+i*randn);
Y=H*x+z;
%figure(4);subplot(211);scatter(real(Y(1:10)),imag(Y(1:10)),'filled');title('4PSK信道均衡前星座图');
Y1=Y/H;
%subplot(212);scatter(real(Y1(1:10)),imag(Y1(1:10)),'filled');title('4PSK信道均衡后星座图');
PESUM1=0;
PBSUM1=0
for n=1:25
  for m=1:1000
         SNR=n;
        Ps=1;
            Pn=Ps/SNR;
Y1=(H*x+z)/H;
        for j=1:length(Y1)
            Dist=abs(Y1(j)-A);
            x_est1(j)=A(Index);
            s_est1(2*j-1:2*j)=Maptable(Index,:);
        end
for  k=1:100
if(s(k)+s_est1(k)==1)
      		PBSUM1=PBSUM1+1;
end
end
for k1=1:50
if isequal(x(k1),x_est1(k1))
               PESUM1=PESUM1+0;
           else
               PESUM1=PESUM1+1;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/115292958
