【人脸识别】基于matlab GUI人脸实时检测与跟踪【含Matlab源码 673期】
海神之光 发表于 2022/05/29 05:15:22 2022/05/29
【摘要】 一、简介 如何在视频流中检测到人脸以及人脸追踪。对象检测和跟踪在许多计算机视觉应用中都很重要,包括活动识别,汽车安全和监视。所以这篇主要总结MATLAB的人脸检测和跟踪。 首先看一下流程。检测人脸——&...
一、简介
首先看一下流程。检测人脸——>面部特征提取——>脸部追踪。
二、部分源代码
unction varargout = facedetecion(varargin)
% FACEDETECION MATLAB code for facedetecion.fig
%      FACEDETECION, by itself, creates a new FACEDETECION or raises the existing
%      singleton*.
%      H = FACEDETECION returns the handle to a new FACEDETECION or the handle to
%      FACEDETECION('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in FACEDETECION.M with the given input arguments.
%      FACEDETECION('Property','Value',...) creates a new FACEDETECION or raises the
%      applied to the GUI before facedetecion_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to facedetecion_OpeningFcn via varargin.
% Edit the above text to modify the response to help facedetecion
% Last Modified by GUIDE v2.5 01-May-2017 19:18:42
gui_Singleton = 1;
                   'gui_OpeningFcn', @facedetecion_OpeningFcn, ...
                   'gui_OutputFcn',  @facedetecion_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before facedetecion is made visible.
function facedetecion_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to facedetecion (see VARARGIN)
% Choose default command line output for facedetecion
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes facedetecion wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = facedetecion_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global myvideo myvideo1;
[fileName,pathName] = uigetfile('*.*','Please select an video');%文件筐,选择文件
if(fileName)
   fileName = strcat(pathName,fileName);
   fileName = lower(fileName);%一致的小写字母形式
else
%   J = 0;%记录区域生长所分割得到的区域
  msgbox('Please select an video');
   return; %退出程序
end
% boxlnserter = vision.ShapeInserter('BorderColor','Custom','CustomBorderColor',[255 0 0]);
% videoOut = step(boxlnserter,videoFrame,bbox);
myvideo = VideoReader(fileName);
nFrames = myvideo.NumberOfFrames
vidHeight = myvideo.Height
vidWidth = myvideo.Width
mov(1:nFrames) = struct('cdata',zeros(vidHeight,vidWidth,3,'uint8'),'colormap',[]);
 B_K = read(myvideo,1);
 axes(handles.axes1);
    imshow(B_K);
% myvideo = VideoReader(fileName);
% nFrames = myvideo.NumberOfFrames
% vidHeight = myvideo.Height
% vidWidth = myvideo.Width
% mov(1:nFrames) = struct('cdata',zeros(vidHeight,vidWidth,3,'uint8'),'colormap',[]);
%  B_K = read(myvideo,1);
%     axes(handles.axes1);
%     imshow(B_K);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
 faceDetector = vision.CascadeObjectDetector();
% videoFileReader = vision.VideoFileReader(fileName);
% videoFrame = step(videoFileReader);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]孟逸凡,柳益君.基于PCA-SVM的人脸识别方法研究[J].科技视界. 2021,(07)
[6]张娜,刘坤,韩美林,陈晨.一种基于PCA和LDA融合的人脸识别算法研究[J].电子测量技术. 2020,43(13)
[7]陈艳.基于BP神经网络的人脸识别方法分析[J].信息与电脑(理论版). 2020,32(23)
[8]戴骊融,陈万米,郭盛.基于肤色模型和SURF算法的人脸识别研究[J].工业控制计算机. 2014,27(02)
原文链接:qq912100926.blog.csdn.net/article/details/115387757
