【运动学】基于matlab GUI不等半径泊车方法仿真【含Matlab源码 691期】
海神之光 发表于 2022/05/29 02:17:55 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【运动学】基于matlab GUI不等半径泊车方法仿真【含Matlab源码 691期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = budengbanjinbochefangzhen(varargin)
% BUDENGBANJINBOCHEFANGZHEN M-file for budengbanjinbochefangzhen.fig
%      BUDENGBANJINBOCHEFANGZHEN, by itself, creates a new BUDENGBANJINBOCHEFANGZHEN or raises the existing
%      singleton*.
%      H = BUDENGBANJINBOCHEFANGZHEN returns the handle to a new BUDENGBANJINBOCHEFANGZHEN or the handle to
%      BUDENGBANJINBOCHEFANGZHEN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in BUDENGBANJINBOCHEFANGZHEN.M with the given input arguments.
%      BUDENGBANJINBOCHEFANGZHEN('Property','Value',...) creates a new BUDENGBANJINBOCHEFANGZHEN or raises the
%      applied to the GUI before budengbanjinbochefangzhen_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to budengbanjinbochefangzhen_OpeningFcn via varargin.
% Edit the above text to modify the response to help budengbanjinbochefangzhen
% Last Modified by GUIDE v2.5 14-Sep-2010 11:41:20
gui_Singleton = 1;
                   'gui_OpeningFcn', @budengbanjinbochefangzhen_OpeningFcn, ...
                   'gui_OutputFcn',  @budengbanjinbochefangzhen_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before budengbanjinbochefangzhen is made visible.
function budengbanjinbochefangzhen_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to budengbanjinbochefangzhen (see VARARGIN)
% Choose default command line output for budengbanjinbochefangzhen
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes budengbanjinbochefangzhen wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = budengbanjinbochefangzhen_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
global long;% 使这个变量变成全局变量
global width;% 使这个变量变成全局变量
global qianxuan;% 使这个变量变成全局变量
global houxuan;% 使这个变量变成全局变量
global lunjin;% 使这个变量变成全局变量
global fai;% 使这个变量变成全局变量
global x6;% 使这个变量变成全局变量
global y6;% 使这个变量变成全局变量
global x7;% 使这个变量变成全局变量
global y7;% 使这个变量变成全局变量
global x8;% 使这个变量变成全局变量
global y8;% 使这个变量变成全局变量
global x9;% 使这个变量变成全局变量
global y9;% 使这个变量变成全局变量
global ds;% 使这个变量变成全局变量
global r;% 使这个变量变成全局变量
global xd;% 使这个变量变成全局变量
global yd;% 使这个变量变成全局变量
axis([-10,20,-10,20]);
axis manual;
hold on;
%参数集,这里存放的为车辆与车位已经仿真所需的主要参数
%手动输入参数集
long=str2double(get(handles.edit1,'string'));
width=str2double(get(handles.edit2,'string'));
qianxuan=str2double(get(handles.edit3,'string'));
houxuan=str2double(get(handles.edit4,'string'));
lunjin=str2double(get(handles.edit5,'string'));
fai=-str2double(get(handles.edit6,'string'));
x6=str2double(get(handles.edit8,'string'));
y6=str2double(get(handles.edit9,'string'));
x7=str2double(get(handles.edit10,'string'));
y7=str2double(get(handles.edit11,'string'));
x9=str2double(get(handles.edit12,'string'));
y9=str2double(get(handles.edit13,'string'));
x8=str2double(get(handles.edit14,'string'));
y8=str2double(get(handles.edit15,'string'));
ds=str2double(get(handles.edit7,'string'));
% long=6;%long 为车车长
% width=3;%width 为车宽
% qianxuan=1;%qianxuan 为车前悬长度
% houxuan=1;% houxuan 为车后悬长度
% lunjin=0.3;%lunjin为车轮半径
% fai=-(pi)/5;%fai 为前一段轨迹的车前轮偏角
% x6=11;
% y6=15;
% x7=18;
% y7=15;
% x8=18;
% y8=0;
% x9=11;
% y9=0;
% ds=0.3; %仿真步长
%自动生成参数集
r=(long-qianxuan-houxuan)/abs(tan(fai));% 车辆的后轴中心点转弯半径
%theta0=(pi)/2;%theta0为起始点车身偏角
xd=(x8+x9)/2;%终点坐标
yd=(y8+y9)/2+1.5;
h0=plot(xd,yd,'bo');
%画车位
%(x6,y6)、(x7,y7)、(x8,y8)、(x9,y9)分别为车位的四个端点坐标
%根据车位的四个端点画出车位的轮廓
l0=plot([x6,x7],[y6,y7],'-k');
l1=plot([x7,x8],[y7,y8],'-k');
l2=plot([x8,x9],[y8,y9],'-k');
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/115434402
