【图像分割】基于matlab GUI图像提取【含Matlab源码 702期】
海神之光 发表于 2022/05/29 02:57:55 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像分割】基于matlab GUI图像提取【含Mat...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像分割】基于matlab GUI图像提取【含Matlab源码 702期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像分割简介
理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】
三、部分源代码
function varargout = go(varargin)
% GO M-file for go.fig
%      GO, by itself, creates a new GO or raises the existing
%      singleton*.
%      H = GO returns the handle to a new GO or the handle to
%      GO('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in GO.M with the given input arguments.
%      GO('Property','Value',...) creates a new GO or raises the
%      applied to the GUI before go_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to go_OpeningFcn via varargin.
% Edit the above text to modify the response to help go
% Last Modified by GUIDE v2.5 30-Dec-2011 13:41:52
gui_Singleton = 1;
                   'gui_OpeningFcn', @go_OpeningFcn, ...
                   'gui_OutputFcn',  @go_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before go is made visible.
function go_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to go (see VARARGIN)
% Choose default command line output for go
handles.output = hObject;
handles.image=[];
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes go wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = go_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
msgbox({'无94 勾志君 2009012870 ','无94 赵文腾 2009012055','无94 李炳霖 2009011086'},'制作信息','help');
% --- Executes on selection change in listbox1.
function listbox1_Callback(hObject, eventdata, handles)
% hObject    handle to listbox1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns listbox1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from listbox1
% --- Executes during object creation, after setting all properties.
function listbox1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: listbox controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
index=get(handles.listbox1,'Value');
switch index
    case 1
handles.image=imread(strcat('imag\','b.jpg'));
    case 2
handles.image=imread(strcat('imag\','c.jpg'));
    case 3
handles.image=imread(strcat('imag\','d.jpg'));
    case 4
handles.image=imread(strcat('imag\','e.jpg'));
end
axes(handles.axes1);
imshow(handles.image);
set(handles.text9,'String','0s');
guidata(hObject,handles);
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
t_begin=clock;
src=handles.image;
[height,width,~]=size(src);
if(height*width<4e+5)scale=4;
else scale=8;
end
temp=mod(width,scale);width=width-temp;
temp=mod(height,scale);height=height-temp;
w=width/scale;h=height/scale;
r=double(src(1:height,1:width,1));g=double(src(1:height,1:width,2));b=double(src(1:height,1:width,3));
ravrg=zeros(h,w);%分块均值阵红
gavrg=zeros(h,w);%分块均值阵绿
bavrg=zeros(h,w);%分块均值阵蓝
color=zeros(h,w);%分块颜色阵
colorscale=0;%颜色空间大小
largestscale=100;%最大颜色空间大小
eps=32;%颜色差别阈值
step=9;%滤波窗口
colorspace=repmat([r(1,1),g(1,1),b(1,1),0],largestscale,1);colorscale=1;
for countw=1:w
    for counth=1:h
        ravrg(counth,countw)=mean(mean(r(counth*scale-(scale-1):counth*scale,countw*scale-(scale-1):countw*scale)));
        gavrg(counth,countw)=mean(mean(g(counth*scale-(scale-1):counth*scale,countw*scale-(scale-1):countw*scale)));
        bavrg(counth,countw)=mean(mean(b(counth*scale-(scale-1):counth*scale,countw*scale-(scale-1):countw*scale)));
        for count3=1:colorscale
            if( all(abs([ravrg(counth,countw)-colorspace(count3,1),gavrg(counth,countw)-colorspace(count3,2),...
                bavrg(counth,countw)-colorspace(count3,3)])<eps) )%和已有颜色相近
                color(counth,countw)=count3;colorspace(count3,4)=colorspace(count3,4)+1;break;
            else if(colorscale==count3 &&colorscale<largestscale)%与已有颜色不同,增添新颜色
                    colorscale=colorscale+1;colorspace(count3+1,:)=[ravrg(counth,countw),gavrg(counth,countw),bavrg(counth,countw),1];
                    color(counth,countw)=count3+1;break;
                end
            end
        end
    end
end
delta=0.005;
temp=1:colorscale;
colorarray=temp(colorspace(:,4)>delta*h*w);%取有效颜色
ratio=zeros(length(colorarray),25);
%开窗
hh=floor(h/8);ww=floor(w/8);j=1;
for counth=ceil(0.0375*h):ceil(h/5):h+1-hh
    for countw=ceil(0.0375*w):ceil(w/5):w+1-ww
        for i=1:length(colorarray)
            ratio(i,j)=sum(sum(color(counth:counth+hh-1,countw:countw+ww-1)==colorarray(i)));
        end
        j=j+1;
    end
end
H=[-2,-1,-0.5,-1,-2;
    -1,0,1.5,0,-1;
    -0.5,1.5,1.5,1.5,-0.5;
    -1,0,1.5,0,-1;
    -2,-1,-0.5,-1,-2;];
H=reshape(H,25,1);
result=ratio*H./colorspace(colorarray,4);
%epsrslt=max(0.6*max(result)+0.4*min(result),mean(result));%mean([mean(result(result<0)),mean(result(result>0))]);
epsrslt=min(0.7*max(result)+0.3*min(result),0.1);
result=colorarray(result>epsrslt);
enable=zeros(1,colorscale);
for i=1:length(result)
    enable(result(i))=1;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/115441705
