【手势识别】基于matlab GUI石头剪刀布【含Matlab源码 774期】
海神之光 发表于 2022/05/29 04:20:05 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源: 【手势识别】基于matlab GUI石头剪刀布【含Matlab源码 774期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = RockPaperScissors(varargin)
% ROCKPAPERSCISSORS MATLAB code for RockPaperScissors.fig
%      ROCKPAPERSCISSORS, by itself, creates a new ROCKPAPERSCISSORS or raises the existing
%      singleton*.
%      H = ROCKPAPERSCISSORS returns the handle to a new ROCKPAPERSCISSORS or the handle to
%      ROCKPAPERSCISSORS('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in ROCKPAPERSCISSORS.M with the given input arguments.
%      ROCKPAPERSCISSORS('Property','Value',...) creates a new ROCKPAPERSCISSORS or raises the
%      applied to the GUI before RockPaperScissors_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to RockPaperScissors_OpeningFcn via varargin.
% Edit the above text to modify the response to help RockPaperScissors
% Last Modified by GUIDE v2.5 13-Apr-2021 23:17:57
gui_Singleton = 1;
                   'gui_OpeningFcn', @RockPaperScissors_OpeningFcn, ...
                   'gui_OutputFcn',  @RockPaperScissors_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before RockPaperScissors is made visible.
function RockPaperScissors_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to RockPaperScissors (see VARARGIN)
% Choose default command line output for RockPaperScissors
handles.output = hObject;
axes(handles.axes1);axis off
axes(handles.axes2);axis off
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes RockPaperScissors wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = RockPaperScissors_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbuttonGo.
function pushbuttonGo_Callback(hObject, eventdata, handles)
% hObject    handle to pushbuttonGo (see GCBO)
 text = {'石头' '剪刀' '布'};people = {'平' '甲        ' '      乙'};
 aP = 1+mod(b-a,3);
%  disp(['甲  ',text{a},char(9),'乙  ',text{b},'胜者:',people{aP}])
 set(handles.textNo1,'String',text{a});
 set(handles.textNo2,'String',text{b});
 set(handles.textResult,'String',people{aP});
axes(handles.axes1)
cla reset;
image(imread(jpg{a}));axis off
axes(handles.axes2)
cla reset;
image(imread(jpg{b}));axis off
%  hc = HColor;
set(handles.textResult,'backgroundcolor',hc);
set(handles.text1,'backgroundcolor',hc0);
set(handles.text2,'backgroundcolor',hc0);
switch aP
	case 1
% 		 set(handles.text1,'backgroundcolor',hc0);
% 		 set(handles.text2,'backgroundcolor',hc0);
		 set(handles.text1,'backgroundcolor',hc);
		 set(handles.text2,'backgroundcolor',hc);
	 case 2
	 case 3
 end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/115682264
