【音乐播放】基于matlab GUI动感音乐播放【含Matlab源码 778期】
海神之光 发表于 2022/05/29 03:23:54 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【音乐播放】基于matlab GUI动感音乐播放【含M...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【音乐播放】基于matlab GUI动感音乐播放【含Matlab源码 778期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、案例简介
基于matlab GUI 动感音乐播放:
1 自由选择本地音乐;
2 播放音乐的同时还有行走人的动画;
3 人的速度和姿态都可调整;
4 还可输入文本;
三、部分源代码
function varargout = hdm_player(varargin)
% HDM_PLAYER MATLAB code for hdm_player.fig
%      HDM_PLAYER, by itself, creates a new HDM_PLAYER or raises the existing
%      singleton*.
%      H = HDM_PLAYER returns the handle to a new HDM_PLAYER or the handle to
%      HDM_PLAYER('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in HDM_PLAYER.M with the given input arguments.
%      HDM_PLAYER('Property','Value',...) creates a new HDM_PLAYER or raises the
%      applied to the GUI before hdm_player_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to hdm_player_OpeningFcn via varargin.
% Edit the above text to modify the response to help hdm_player
% Last Modified by GUIDE v2.5 08-Jun-2013 07:56:33
gui_Singleton = 1;
                   'gui_OpeningFcn', @hdm_player_OpeningFcn, ...
                   'gui_OutputFcn',  @hdm_player_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before hdm_player is made visible.
function hdm_player_OpeningFcn(hObject, eventdata, handles, varargin)
global T_obj which_channel T_start x;
which_channel = 1;
T_start = 0;
x = 0;
% hObject    handle to figure
% varargin   command line arguments to hdm_player (see VARARGIN)
T_obj=timer('TimerFcn',{@plotupdate, handles}, 'Period', 0.1, 'ExecutionMode', 'FixedRate');
% Choose default command line output for hdm_player
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes hdm_player wait for user response (see UIRESUME)
% uiwait(handles.figure1);
set(gcf, 'color','w')
function varargout = hdm_player_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in loadbutton.
function loadbutton_Callback(hObject, eventdata, handles)
global  wavfile Fs;
% hObject    handle to loadbutton (see GCBO)
[filename pathname] = uigetfile('*.wav', '选择播放文件');
[wavfile Fs] = wavread([pathname filename]);
%sound(wavfile,Fs);
% --- Executes on button press in playbutton.
function playbutton_Callback(hObject, eventdata, handles)
global p   wavfile Fs T_obj T_start x;
% hObject    handle to playbutton (see GCBO)
x = wavfile(:, 1);
p = audioplayer(x, Fs);
play(p);
if T_start == 0
    start(T_obj);
    T_start = 1;
end
% --- Executes on button press in pausebutton.
function pausebutton_Callback(hObject, eventdata, handles)
global p T_obj;
% hObject    handle to pausebutton (see GCBO)
pause(p);
% --- Executes on button press in continued.
function continued_Callback(hObject, eventdata, handles)
global p;
% hObject    handle to continued (see GCBO)
resume(p);
% --- Executes on button press in stopbutton.
function stopbutton_Callback(hObject, eventdata, handles)
global p T_obj T_stop;
% hObject    handle to stopbutton (see GCBO)
stop(p);
stop(T_obj);
delete(T_obj);
T_stop = 1;
% --- Executes during object deletion, before destroying properties.
function figure1_DeleteFcn(hObject, eventdata, handles)
global T_obj T_stop p;
stop(p);
if T_stop == 0
    stop(T_obj);
    delete(T_obj);
end
% hObject    handle to figure1 (see GCBO)
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
shg
set(gcf,'doublebuf','on','color','w','name','Walker','numbertitle','off')
set(gca,'pos',get(gca,'pos')+[0 .07 0 0])
% The body is represented by 15 points in three space, i.e. a vector of
% length 45.  The data consists of F, five vectors describing the average
% female and M, five vectors describing the average male.  Four linked
% segments, indexed by L, are the head, torso, arms, and legs.
% Initial view
load walkers
X = reshape((F(:,1)+M(:,1))/2,15,3);
L = {[1 5],[5 12],[2 3 4 5 6 7 8],[9 10 11 12 13 14 15]};
for k = 1:4
   p(k) = line(X(L{k},1),X(L{k},2),X(L{k},3),'marker','o', ...
      'markersize',10,'linestyle','-','erasemode','background');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
原文链接:qq912100926.blog.csdn.net/article/details/115712598
