【语音处理】基于matlab GUI语音信号综合处理平台【含Matlab源码 290期】
海神之光 发表于 2022/05/29 04:10:26 2022/05/29
【摘要】 一、简介 本设计针对现在大部分语音处理软件内容繁多、操作不便等问题,采用MATLAB综合运用GUI界面设计、各种函数调用等来实现语音信号的变频、变幅、傅里叶变换及滤波,程序界面简练,操作简便。 二、部...
一、简介
二、部分源代码
function varargout = untitledb(varargin)
% UNTITLEDB MATLAB code for untitledb.fig
%      UNTITLEDB, by itself, creates a new UNTITLEDB or raises the existing
%      singleton*.
%      H = UNTITLEDB returns the handle to a new UNTITLEDB or the handle to
%      UNTITLEDB('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in UNTITLEDB.M with the given input arguments.
%      UNTITLEDB('Property','Value',...) creates a new UNTITLEDB or raises the
%      applied to the GUI before untitledb_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to untitledb_OpeningFcn via varargin.
% Edit the above text to modify the response to help untitledb
% Last Modified by GUIDE v2.5 13-Jan-2017 21:00:41
gui_Singleton = 1;
                   'gui_OpeningFcn', @untitledb_OpeningFcn, ...
                   'gui_OutputFcn',  @untitledb_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before untitledb is made visible.
function untitledb_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to untitledb (see VARARGIN)
% Choose default command line output for untitledb
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes untitledb wait for user response (see UIRESUME)
% uiwait(handles.figure1);
global t fs x x11 f  y0 y1 y2 mag x6 x7 x77 x20 k N fullname;
fs= str2num(get(handles.edit3,'String'));
a = str2num(get(handles.edit4,'String'));
b = str2num(get(handles.edit5,'String'));
N=(b-a)*fs+1;
x20=zeros(10,N);
x6=0;
x7=0;
x20=[];
x77=0;
k=0;
function varargout = untitledb_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes during object creation, after setting all properties.
function pushbutton1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on selection change in popupmenu2.
function popupmenu2_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu2 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu2 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu2
function popupmenu2_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on selection change in popupmenu3.
function popupmenu3_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu3 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu3 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu3
function popupmenu3_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on selection change in popupmenu4.
function popupmenu4_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu4 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu4 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu4
function popupmenu4_CreateFcn(hObject, eventdata, handles)
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
原文链接:qq912100926.blog.csdn.net/article/details/113800676
