【幅度调制】基于matlab GUI语音幅度调制【含Matlab源码 292期】
海神之光 发表于 2022/05/29 04:27:54 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【幅度调制】基于matlab GUI语音幅度调制【含M...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【幅度调制】基于matlab GUI语音幅度调制【含Matlab源码 292期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、调幅简介
“调幅”就是调制幅度,高频信号的幅度随着音频信号幅度的改变而改变,当音频信号的幅度高时高频信号的幅度也跟着高,反之跟着变低,形成音频信号的幅度包络,但高频信号的频率没有变;
三、部分源代码
function varargout = AMtiaozhi(varargin)
% AMTIAOZHI M-file for AMtiaozhi.fig
%      AMTIAOZHI, by itself, creates a new AMTIAOZHI or raises the existing
%      singleton*.
%      H = AMTIAOZHI returns the handle to a new AMTIAOZHI or the handle to
%      AMTIAOZHI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in AMTIAOZHI.M with the given input arguments.
%      AMTIAOZHI('Property','Value',...) creates a new AMTIAOZHI or raises the
%      applied to the GUI before AMtiaozhi_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to AMtiaozhi_OpeningFcn via varargin.
% Edit the above text to modify the response to help AMtiaozhi
% Last Modified by GUIDE v2.5 10-May-2010 16:42:40
gui_Singleton = 1;
                   'gui_OpeningFcn', @AMtiaozhi_OpeningFcn, ...
                   'gui_OutputFcn',  @AMtiaozhi_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin & isstr(varargin{1})
end
if nargout
else
end
% --- Executes just before AMtiaozhi is made visible.
function AMtiaozhi_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to AMtiaozhi (see VARARGIN)
% Choose default command line output for AMtiaozhi
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes AMtiaozhi wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = AMtiaozhi_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
set(hObject, 'String', {'调制信号', '载波信号','已调波信号'});
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% Hints: contents = get(hObject,'String') returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
function popupmenu2_CreateFcn(hObject, eventdata, handles)
% hObject    handle to popupmenu2 (see GCBO)
if ispc
else
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
原文链接:qq912100926.blog.csdn.net/article/details/113800767
