【语音处理】基于matlab GUI语音原始信号+变速信号时域频域分析(带面板)【含Matlab源码 294期】
海神之光 发表于 2022/05/29 04:38:09 2022/05/29
【摘要】 一、语音处理简介 MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口...
一、语音处理简介
MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口、光标、按键、菜单、文字说明等对象(Object)构成的一个用户界面。用户通过一定的方法(如鼠标或键盘)选择、激活这些图形对象,使计算机产生某种动作或变化,比如实现计算、绘图等。本设计基于MATLAB GUI技术,完成了语音信号处理的界面平台,可进行语音的选取、线性预测分析(LPC)、语谱图、频谱等相关波形的显示。这样可以更直观、更方便地分析和处理语音信号,得到用户需要的实验结果。
具体理论知识参考:基于MATLAB GUI的语音处理界面设计
二、部分源代码
unction varargout = zuoye(varargin)
% ZUOYE MATLAB code for zuoye.fig
%      ZUOYE, by itself, creates a new ZUOYE or raises the existing
%      singleton*.
%      H = ZUOYE returns the handle to a new ZUOYE or the handle to
%      ZUOYE('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in ZUOYE.M with the given input arguments.
%      ZUOYE('Property','Value',...) creates a new ZUOYE or raises the
%      applied to the GUI before zuoye_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to zuoye_OpeningFcn via varargin.
% Edit the above text to modify the response to help zuoye
% Last Modified by GUIDE v2.5 03-Jan-2022 17:00:59
gui_Singleton = 1;
                   'gui_OpeningFcn', @zuoye_OpeningFcn, ...
                   'gui_OutputFcn',  @zuoye_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before zuoye is made visible.
function zuoye_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to zuoye (see VARARGIN)
% Choose default command line output for zuoye
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes zuoye wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = zuoye_OutputFcn(hObject, eventdata, handles)
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global x;
global fs;
global bits;
global file;
clear sound;
if nargin<1;action='initialized';end;
[fname,pname]=uigetfile('*.wav','Open Wave File');
file=[pname,fname];
[x,fs,bits]=wavread(file);       % 读入声音文件(*.wav)
sound(x,fs);
set(handles.edit1,'string',fs);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
%画原信号时域波形
global x;
global w;
global fs;
axes(handles.axes1);
N=length(x);
t=[0:1:N-1]/fs;
plot(t,x);
xlabel('时间t')
ylabel('幅值')
n=[0:N-1]';
w=2*n*pi/N;
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
%画原信号时域波形
global x;
global w;
X=fft(x);
axes(handles.axes2);
plot(w/pi,abs(X))
axis([0,2,0,500])
xlabel('归一化')
ylabel('幅值')
% --- Executes on button press in pushbutton4.
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
global pitch
global nFrames
xt=1:nFrames;
xt=20*xt;
plot(xt,pitch)
xlim([0,3]);
axis([xt(1) xt(nFrames) 0 max(pitch)+50]);
ylabel('基音频率/HZ');
xlabel('时间');
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
global ybiansu;
global fs;
N=length(ybiansu);
t=[0:1:N-1]/fs;
plot(t,ybiansu);
xlabel('时间t')
ylabel('幅值')
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
global ybiansu;
NS=length(ybiansu);
nS=[0:NS-1]';
wS=2*nS*pi/NS;
YH=fft(ybiansu);
plot(wS/pi,abs(YH))
axis([0,2,0,500])
xlabel('归一化')
ylabel('幅值')
% --- Executes on button press in pushbutton8.
function pushbutton8_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton8 (see GCBO)
%画重采样时域波形
global x2;
global fs;
N=length(x2);
t=[0:1:N-1]/fs;
plot(t,x2);
xlabel('时间t')
ylabel('幅值')
% --- Executes on button press in pushbutton9.
function pushbutton9_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton9 (see GCBO)
global x2;
X2=fft(x2);
NS=length(x2);
nS=[0:NS-1]';
wS=2*nS*pi/NS;
plot(wS/pi,abs(X2))
axis([0,2,0,500])
xlabel('归一化')
ylabel('幅值')
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
function edit1_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
[3]宋云飞,姜占才,魏中华.基于MATLAB GUI的语音处理界面设计[J].科技信息. 2013,(02)
原文链接:qq912100926.blog.csdn.net/article/details/113800838
