【瑕疵检测】基于matlab Gabor滤波布匹瑕疵检测【含Matlab源码 407期】
海神之光 发表于 2022/05/29 02:59:24 2022/05/29
【摘要】 一、Gabor滤波布匹瑕疵检测简介 1 Gabor滤波器 2 Gabor函数结合代码分析: 二、部分源代码 function varargout = bupi(varargin) % BUP...
一、Gabor滤波布匹瑕疵检测简介
1 Gabor滤波器
2 Gabor函数结合代码分析:
二、部分源代码
% BUPI MATLAB code for bupi.fig
%      BUPI, by itself, creates a new BUPI or raises the existing
%      singleton*.
%      H = BUPI returns the handle to a new BUPI or the handle to
%      BUPI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in BUPI.M with the given input arguments.
%      BUPI('Property','Value',...) creates a new BUPI or raises the
%      applied to the GUI before bupi_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to bupi_OpeningFcn via varargin.
% Edit the above text to modify the response to help bupi
% Last Modified by GUIDE v2.5 28-May-2015 22:11:59
gui_Singleton = 1;
                   'gui_OpeningFcn', @bupi_OpeningFcn, ...
                   'gui_OutputFcn',  @bupi_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before bupi is made visible.
function bupi_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to bupi (see VARARGIN)
axes(handles.axes1);
imshow([255]);
axes(handles.axes2);
imshow([255]);
axes(handles.axes3);
imshow([255]);
axes(handles.axes4);
imshow([255]);
axes(handles.axes5);
imshow([255]);
axes(handles.axes6);
imshow([255]);
% Choose default command line output for bupi
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes bupi wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = bupi_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
global tu
axes(handles.axes1)
[filename,pathname]=uigetfile({ ...
    '*.*','All Files(*.*)';},...
    '选择文件');
if isequal([filename,pathname],[0,0])
    return
else
    %读取图片
    pic = fullfile(pathname,filename);
    b = imread(pic);
    imshow(b);%上面是打开图片的步骤,这一句是显示图片
    tu=b;
    title('原始图像');
    %handle.axes1=b;
end
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
global tu;
tu2 = gabor2(tu,0);
imshow(tu2);
title('0度滤波结果');
tu2 = gabor2(tu,pi/4);
imshow(tu2);
title('pi/4度滤波结果');
tu2 = gabor2(tu,pi/2);
imshow(tu2);
title('pi/2度滤波结果');
tu2 = gabor2(tu,pi/4*3);
imshow(tu2);
title('pi/4*3度滤波结果');
% hObject    handle to pushbutton2 (see GCBO)
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
global tu;
P  = 5;
T1 =8;
T2 = 100;
I = tu;
 I0=I;
    %预处理
    I=double(I0); %数据类型的转换
    [M,N]=size(I);%得到待检测图像的大小
    J=junzhicaiyang(I,M,N,P); %调用均值下采样函数
    J=uint8(J);
    %双线性插值,恢复原来的图像大小
    I1=imresize(J,P,'bilinear'); %双线性插值,恢复原来图像的大小。
    %进行方差下采样,用于增强图像疵点信息
    I1=double(I1);
    J1=fangchacaiyang(I1,M,N,P); %调用方差下采样函数
    J1=uint8(J1);
    %双线性插值,恢复原来图像的大小。
    I=imresize(J1,P,'bilinear');
    %进行二值化及其后处理
    T=Otsu(I);
    %解决了利用大津法不能分辨是否含有疵点的缺陷的缺点,统计发现无疵点图像otsu得到阈值均小于8
    if T<=T1
        T=T1+1;
    end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/114176979
