【手指识别】基于matlab GUI指尖图像采集与检测【含Matlab源码 585期】
海神之光 发表于 2022/05/29 03:08:32 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【手指识别】基于matlab GUI指尖图像采集与检测【含Matlab源码 585期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = hands(varargin)
% HANDS MATLAB code for hands.fig
%      HANDS, by itself, creates a new HANDS or raises the existing
%      singleton*.
%      H = HANDS returns the handle to a new HANDS or the handle to
%      HANDS('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in HANDS.M with the given input arguments.
%      HANDS('Property','Value',...) creates a new HANDS or raises the
%      applied to the GUI before hands_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to hands_OpeningFcn via varargin.
% Edit the above text to modify the response to help hands
% Last Modified by GUIDE v2.5 07-Jul-2019 22:20:32
gui_Singleton = 1;
                   'gui_OpeningFcn', @hands_OpeningFcn, ...
                   'gui_OutputFcn',  @hands_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before hands is made visible.
function hands_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to hands (see VARARGIN)
% Choose default command line output for hands
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes hands wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = hands_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global obj
obj = videoinput('winvideo',1,'MJPG_640x480');
vidRes = get(obj,'VideoResolution');
nBands = get(obj,'NumberOfBands');
axes(handles.axes1);
global hImage
hImage = image(zeros(vidRes(2),vidRes(1),nBands));
preview(obj,hImage);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
global obj
stoppreview(obj)
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
global InputImg
[filename,pathname] = uigetfile({'*.bmp','BMP files';'*.jpg','JPG files'},'选择格式');
if isequal(filename,0) || isequal(pathname,0)
    return
else
    fpath = fullfile(pathname,filename);
end
InputImg = imread(fpath);
imshow(InputImg);
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
global InputImg
global BinaryImg
global OutlineImg
[BinaryImg,OutlineImg] = ColorofSkinDection(InputImg);
imshow(OutlineImg);
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
global obj;
frame = getsnapshot(obj);
[filename,pathname] = uiputfile({'*.bmp','BMP files';'*.jpg','JPG files'},'选择格式');
    return
else
end
imwrite(frame,fpath);
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
%退出
h = questdlg('您确定要退出识别系统吗?','退出提示','Yes','No','No');
if h=='Yes'
    close(gcf);
end
% --- Executes when figure1 is resized.
function figure1_SizeChangedFcn(hObject, eventdata, handles)
% hObject    handle to figure1 (see GCBO)
% --- If Enable == 'on', executes on mouse press in 5 pixel border.
% --- Otherwise, executes on mouse press in 5 pixel border or over pushbutton1.
function pushbutton1_ButtonDownFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton8.
function pushbutton8_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton8 (see GCBO)
global OutlineImg
global InputImg
[Res,OutImg] = finger(InputImg,OutlineImg);
imshow(OutImg);
% --- Executes on key press with focus on pushbutton5 and none of its controls.
function pushbutton5_KeyPressFcn(hObject, eventdata, handles)
% eventdata  structure with the following fields (see MATLAB.UI.CONTROL.UICONTROL)
%	Key: name of the key that was pressed, in lower case
%	Character: character interpretation of the key(s) that was pressed
%	Modifier: name(s) of the modifier key(s) (i.e., control, shift) pressed
global InputImg
if double(get(gcf,'CurrentCharacter'))==32   %如果按下的是空格(32)
        return
    else
    end
    imshow(InputImg);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/115023203
