【图像修复】基于matlab GUI约束最小二乘方滤波图像复原【含Matlab源码 852期】
海神之光 发表于 2022/05/29 04:07:51 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像修复】基于matlab GUI约束最小二乘方滤波...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像修复】基于matlab GUI约束最小二乘方滤波图像复原【含Matlab源码 852期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、约束最小二乘方滤波简介
约束最小二乘方滤波(Constrained Least Squares Filtering,aka Tikhonov filtration,Tikhonov regularization)核心是H对噪声的敏感性问题。减少噪声敏感新问题的一种方法是以平滑度量的最佳复原为基础的,因此我们可以建立下列约束条件:
三、部分源代码
function varargout = zuixiaoercheng(varargin)
% ZUIXIAOERCHENG M-file for zuixiaoercheng.fig
%      ZUIXIAOERCHENG, by itself, creates a new ZUIXIAOERCHENG or raises the existing
%      singleton*.
%      H = ZUIXIAOERCHENG returns the handle to a new ZUIXIAOERCHENG or the handle to
%      ZUIXIAOERCHENG('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in ZUIXIAOERCHENG.M with the given input arguments.
%      ZUIXIAOERCHENG('Property','Value',...) creates a new ZUIXIAOERCHENG or raises the
%      applied to the GUI before zuixiaoercheng_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to zuixiaoercheng_OpeningFcn via varargin.
% Edit the above text to modify the response to help zuixiaoercheng
% Last Modified by GUIDE v2.5 20-May-2009 15:56:50
gui_Singleton = 1;
                   'gui_OpeningFcn', @zuixiaoercheng_OpeningFcn, ...
                   'gui_OutputFcn',  @zuixiaoercheng_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin & isstr(varargin{1})
end
if nargout
else
end
% --- Executes just before zuixiaoercheng is made visible.
function zuixiaoercheng_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to zuixiaoercheng (see VARARGIN)
img = imread('squarebox.bmp');
axes(handles.axes1);
imshow(img);
PSF = fspecial('motion',20,45);
MF = imfilter(img,PSF,'circular');
noise = imnoise(zeros(size(img)),'gaussian',0,0.01);
MF = double(MF);
MFN = MF+noise;
axes(handles.axes2);
imshow(uint8(MFN));
fr = deconvreg(MFN,PSF,4,[1e-7,1e7]);
axes(handles.axes3);
imshow(uint8(fr));
set(handles.noisepower_edit,'string',4);
% Choose default command line output for zuixiaoercheng
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes zuixiaoercheng wait for user response (see UIRESUME)
% uiwait(handles.zuixiaoercheng);
function varargout = zuixiaoercheng_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function image_pop_menu_CreateFcn(hObject, eventdata, handles)
% hObject    handle to image_pop_menu (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
% --- Executes on selection change in image_pop_menu.
function image_pop_menu_Callback(hObject, eventdata, handles)
noisepower = str2num(get(handles.noisepower_edit,'string'));
val = get(hObject,'value');
str = get(hObject,'string');
switch str{val}
    case 'Squarebox'
        squarebox = [];
        squarebox = imread('squarebox.bmp');
        img = squarebox;
    case 'Lena'
        lena = [];
        lena = imread('lena.bmp');
        img = lena;
    case 'Saturn'
        saturn = [];
        load imdemos saturn
        img = saturn;
    case 'Quarter'
        quarter = [];
        load imdemos quarter
        img = quarter;
    case 'Circuit'
        circuit = [];
        load imdemos circuit
        img = circuit;
    case 'Fingerprint'
        fingerprint = [];
        fingerprint = imread('fingerprint.jpg');
        img = fingerprint;
    case 'Licenceplate'
        licenceplate = [];
        licenceplate = imread('licenceplate.jpg');
        img = licenceplate;
    case 'Cloudy'
        cloudy = [];
        cloudy = imread('cloudy.tif');
        img = cloudy;
end
imshow(img);
MF = double(MF);
MFN = MF+noise;
imshow(uint8(MFN));
fr = deconvreg(MFN,PSF,noisepower,[1e-7,1e7]);
imshow(uint8(fr));
% Hints: contents = get(hObject,'String') returns image_pop_menu contents as cell array
%        contents{get(hObject,'Value')} returns selected item from image_pop_menu
function noisepower_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to noisepower_edit (see GCBO)
% Hint: edit controls usually have a white background on Windows.
if ispc
else
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/116208336
