【图像修复】基于matlab GUI运动模糊消除(逆滤波)【含Matlab源码 847期】
海神之光 发表于 2022/05/29 04:38:19 2022/05/29
【摘要】 一、简介 基于matlab GUI运动模糊消除(逆滤波) 二、源代码 function varargout = motion_remove(varargin) % MOTION_REMOVE M-f...
一、简介
二、源代码
% MOTION_REMOVE M-file for motion_remove.fig
%      MOTION_REMOVE, by itself, creates a new MOTION_REMOVE or raises the existing
%      singleton*.
%      H = MOTION_REMOVE returns the handle to a new MOTION_REMOVE or the handle to
%      MOTION_REMOVE('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MOTION_REMOVE.M with the given input arguments.
%      MOTION_REMOVE('Property','Value',...) creates a new MOTION_REMOVE or raises the
%      applied to the GUI before motion_remove_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to motion_remove_OpeningFcn via varargin.
% Edit the above text to modify the response to help motion_remove
% Last Modified by GUIDE v2.5 27-Apr-2021 17:53:02
gui_Singleton = 1;
                   'gui_OpeningFcn', @motion_remove_OpeningFcn, ...
                   'gui_OutputFcn',  @motion_remove_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin & isstr(varargin{1})
end
if nargout
else
end
% --- Executes just before motion_remove is made visible.
function motion_remove_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to motion_remove (see VARARGIN)
axes(handles.axes1);
img = imread('lena1.bmp');
imshow(img);
LEN = 30;
THETA = 45;
PSF = fspecial('motion',LEN,THETA);
MF = imfilter(img,PSF,'circular','conv');
axes(handles.axes2);
imshow(MF);
INITPSF = fspecial('motion',LEN,THETA);
[J,P] = deconvblind(MF,INITPSF,30);
axes(handles.axes3);
imshow(J);
set(handles.len_edit,'string',30);
set(handles.theta_edit,'string',45);
% Choose default command line output for motion_remove
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes motion_remove wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = motion_remove_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function len_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to len_edit (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function len_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of len_edit as text
%        str2double(get(hObject,'String')) returns contents of len_edit as a double
function theta_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to theta_edit (see GCBO)
if ispc
else
end
function theta_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of theta_edit as text
%        str2double(get(hObject,'String')) returns contents of theta_edit as a double
% --- Executes on button press in apply_button.
function apply_button_Callback(hObject, eventdata, handles)
% hObject    handle to apply_button (see GCBO)
LEN = str2num(get(handles.len_edit,'string'));
THETA = str2num(get(handles.theta_edit,'string'));
img = getimage(handles.axes1);
imshow(MF);
imshow(J);
% --- Executes on button press in close_button.
function close_button_Callback(hObject, eventdata, handles)
% hObject    handle to close_button (see GCBO)
close(motion_remove);
function image_pop_menu_CreateFcn(hObject, eventdata, handles)
% hObject    handle to image_pop_menu (see GCBO)
% Hint: popupmenu controls usually have a white background on Windows.
if ispc
else
end
% --- Executes on selection change in image_pop_menu.
function image_pop_menu_Callback(hObject, eventdata, handles)
val = get(hObject,'value');
str = get(hObject,'string');
switch str{val}
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
三、运行结果
四、备注
版本:2014a
原文链接:qq912100926.blog.csdn.net/article/details/116206811
