【图像重建】基于matlab GUI投影法图像重建【含Matlab源码 861期】
海神之光 发表于 2022/05/29 01:59:58 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像重建】基于matlab GUI投影法图像重建【含...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像重建】基于matlab GUI投影法图像重建【含Matlab源码 861期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
unction varargout = chongjian(varargin)
% CHONGJIAN MATLAB code for chongjian.fig
%      CHONGJIAN, by itself, creates a new CHONGJIAN or raises the existing
%      singleton*.
%      H = CHONGJIAN returns the handle to a new CHONGJIAN or the handle to
%      CHONGJIAN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CHONGJIAN.M with the given input arguments.
%      CHONGJIAN('Property','Value',...) creates a new CHONGJIAN or raises the
%      applied to the GUI before chongjian_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to chongjian_OpeningFcn via varargin.
% Edit the above text to modify the response to help chongjian
% Last Modified by GUIDE v2.5 22-Mar-2020 18:21:37
gui_Singleton = 1;
                   'gui_OpeningFcn', @chongjian_OpeningFcn, ...
                   'gui_OutputFcn',  @chongjian_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before chongjian is made visible.
function chongjian_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to chongjian (see VARARGIN)
axes(handles.axes1);
imshow([255]);
axes(handles.axes2);
imshow([255]);
axes(handles.axes3);
imshow([255]);
% Choose default command line output for chongjian
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes chongjian wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = chongjian_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
global tu
axes(handles.axes1)
[filename,pathname]=uigetfile({ ...
    '*.*','All Files(*.*)';},...
    '选择文件');
if isequal([filename,pathname],[0,0])
    return
else
    %读取图片
    pic = fullfile(pathname,filename);
    b = imread(pic);
    imshow(b);%上面是打开图片的步骤,这一句是显示图片
    tu=b;
    title('原始图像');
    %handle.axes1=b;
end
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
global tu
global tu2
P = tu;
[N,N]=size(P);
%先进行自定义radon变换------------------------------------------------------------
thm=45;                %45度时会出现最大尺寸
pre = imrotate(P,thm);
[mmax,nmax] = size(pre);
s=1;
%创建一个180*nmax的空白图片,用以存储投影后的线状图片
Final = zeros(180/s,nmax);%这里180代表180角度,每个角度投影成为一条线
t = 1;
for theta = 1:s:179
Protate = imrotate(P,theta);    %对原图旋转一个角度,求和(线积分)
Pf = sum(Protate,1);
[mreal,nreal]=size(Pf);           %计算实际尺寸
%确定起始点
if (nmax - nreal)/2-floor((nmax - nreal)/2) == 0
    From = floor((nmax - nreal)/2 + 1);%总点数为偶数时
   else
    From = floor((nmax - nreal)/2) + 1;%总点数为奇数时
    end
    %结果文本显示------------------------------------------------------------
% o=ones(500,1000);
% subplot(2,3,6);
% imshow(o,[]);
% s_title=['图像重建精度判据如下:'];
% text(0,0,s_title,'Fontsize',14);
% s=num2str(toc);
% s_one=['run time = ' s ' s;'];
% text(0,100,s_one,'FontSize',10);
% s=num2str(evaluate_d);
% s_two=['归一化均方距离判据d=' s ';'];
% text(0,200,s_two,'Fontsize',10);
% s=num2str(evaluate_r);
% s_three=['归一化平均绝对距离判据r=' s ';'];
% text(0,300,s_three,'Fontsize',10);
% s=num2str(evaluate_e);
% s_four=['最坏情况距离判据e=' s ';'];
% text(0,400,s_four,'Fontsize',10);
% toc
% hObject    handle to pushbutton2 (see GCBO)
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
global tu2
imshow(tu2);
title('投影重建后的图像');
% hObject    handle to pushbutton3 (see GCBO)
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
imshow([255]);
imshow([255]);
imshow([255]);
% hObject    handle to pushbutton4 (see GCBO)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/116265881
