【图像评价】基于matlab GUI图像客观评价【含Matlab源码 855期】
海神之光 发表于 2022/05/29 03:42:02 2022/05/29
【摘要】 一、简介 理论知识参考文献:图像印刷质量的客观评价——以报纸印刷为例 二、部分源代码 function varargout = Kgpj(varargin) %KGPJ M-file for Kgp...
一、简介
二、部分源代码
%KGPJ M-file for Kgpj.fig
%      KGPJ, by itself, creates a new KGPJ or raises the existing
%      singleton*.
%      H = KGPJ returns the handle to a new KGPJ or the handle to
%      KGPJ('Property','Value',...) creates a new KGPJ using the
%      given property value pairs. Unrecognized properties are passed via
%      varargin to Kgpj_OpeningFcn.  This calling syntax produces a
%      warning when there is an existing singleton*.
%      KGPJ('CALLBACK') and KGPJ('CALLBACK',hObject,...) call the
%      local function named CALLBACK in KGPJ.M with the given input
%      arguments.
gui_Singleton = 1;
                   'gui_OpeningFcn', @Kgpj_OpeningFcn, ...
                   'gui_OutputFcn',  @Kgpj_OutputFcn, ...
                   'gui_LayoutFcn',  [], ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Kgpj is made visible.
function Kgpj_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   unrecognized PropertyName/PropertyValue pairs from the
%            command line (see VARARGIN)
% Choose default command line output for Kgpj
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Kgpj wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Kgpj_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbuttonLoadImage.
function pushbuttonLoadImage_Callback(hObject, eventdata, handles)
% hObject    handle to pushbuttonLoadImage (see GCBO)
filter = { ...
        '*.bmp;*.jpg;*.gif;*.emf', '所有图像文件 (*.bmp; *.jpg; *.gif; *emf)'; ...
        '*.bmp',  '位图文件 (*.bmp)'; ...
        '*.jpg', 'JPEG文件 (*.jpg)'; ...
        '*.gif', 'GIF文件 (*.gif)'; ...
        '*.emf', '图元文件 (*.emf)'; ...
        '*.*',  '所有文件 (*.*)' ...
% 选择文件
[filename, pathname] = uigetfile( filter, '打开...');
if isequal(filename,0) | isequal(pathname,0), return, end
% 读入图像并显示
[X, map] = imread([pathname filename]);
colormap(map)
image(X)
% 设置坐标系为适合显示图像的方式
% axis imageset(gca, 'vis', 'off')
set(gcf,'UserData',X);
% --- Executes during object creation, after setting all properties.
function pushbuttonLoadImage_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on selection change in popupmenu.
function popupmenu_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu
function popupmenu_CreateFcn(hObject, eventdata, handles)
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function editJG_Callback(hObject, eventdata, handles)
% hObject    handle to editJG (see GCBO)
% Hints: get(hObject,'String') returns contents of editJG as text
%        str2double(get(hObject,'String')) returns contents of editJG as a double
function editJG_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
function SF = SpaceFrequency(image)
%计算空间频率
%空间频率反映了一幅图像空间域的总体活跃度
% clear all
% [filename,pathname]=uigetfile('*.*','图像');
% A=imread([pathname,filename]);
A=image;
%s=size(size(A));
%if s(2)==3
%   A=rgb2gray(A);
%end
A=double(A);
[M,N]=size(A);
sum1=0;
sum2=0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/116230922
