【光学】基于matlab GUI(杨氏双缝+劈尖)干涉+(单缝+多缝+圆孔+矩孔)衍射仿真【含Matlab源码 878期】
海神之光 发表于 2022/05/29 03:04:08 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【光学】基于matlab GUI(杨氏双缝+劈尖)干涉+(单缝+多缝+圆孔+矩孔)衍射仿真【含Matlab源码 878期】 获取代码方式2:...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
 function varargout = untitled(varargin)
% UNTITLED MATLAB code for untitled.fig
%      UNTITLED, by itself, creates a new UNTITLED or raises the existing
%      singleton*.
%      H = UNTITLED returns the handle to a new UNTITLED or the handle to
%      UNTITLED('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in UNTITLED.M with the given input arguments.
%      UNTITLED('Property','Value',...) creates a new UNTITLED or raises the
%      applied to the GUI before untitled_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to untitled_OpeningFcn via varargin.
% Edit the above text to modify the response to help untitled
% Last Modified by GUIDE v2.5 28-Apr-2019 02:20:39
gui_Singleton = 1;
                   'gui_OpeningFcn', @untitled_OpeningFcn, ...
                   'gui_OutputFcn',  @untitled_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before untitled is made visible.
function untitled_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to untitled (see VARARGIN)
% Choose default command line output for untitled
handles.output = hObject;
axes(handles.axes1)
cData=imread('douluodalu.jpg');
image(cData);
axis off;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes untitled wait for user response (see UIRESUME)
 function varargout = untitled1(varargin)
% UNTITLED1 MATLAB code for untitled1.fig
%      UNTITLED1, by itself, creates a new UNTITLED1 or raises the existing
%      singleton*.
%      H = UNTITLED1 returns the handle to a new UNTITLED1 or the handle to
%      UNTITLED1('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in UNTITLED1.M with the given input arguments.
%      UNTITLED1('Property','Value',...) creates a new UNTITLED1 or raises the
%      applied to the GUI before untitled1_OpeningFcn gets called.  An
%      stop.  All inputs are passed to untitled1_OpeningFcn via varargin.
% Edit the above text to modify the response to help untitled1
% Last Modified by GUIDE v2.5 13-May-2019 12:05:52
gui_Singleton = 1;
                   'gui_OpeningFcn', @untitled1_OpeningFcn, ...
                   'gui_OutputFcn',  @untitled1_OutputFcn, ...
end
if nargout
else
end
% --- Executes just before untitled1 is made visible.
function untitled1_OpeningFcn(hObject, eventdata, handles, varargin)
% varargin   command line arguments to untitled1 (see VARARGIN)
% Choose default command line output for untitled1
axes(handles.axes1)
cData=imread('杨氏双缝实验.jpg');
image(cData);
title('杨氏双缝干涉示意图')
axis off;
function varargout = untitled2(varargin)
% UNTITLED2 MATLAB code for untitled2.fig
%      UNTITLED2, by itself, creates a new UNTITLED2 or raises the existing
%      singleton*.
%      H = UNTITLED2 returns the handle to a new UNTITLED2 or the handle to
%      UNTITLED2('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in UNTITLED2.M with the given input arguments.
%      UNTITLED2('Property','Value',...) creates a new UNTITLED2 or raises the
%      applied to the GUI before untitled2_OpeningFcn gets called.  An
%      stop.  All inputs are passed to untitled2_OpeningFcn via varargin.
% Edit the above text to modify the response to help untitled2
% Last Modified by GUIDE v2.5 06-May-2019 15:46:20
gui_Singleton = 1;
                   'gui_OpeningFcn', @untitled2_OpeningFcn, ...
                   'gui_OutputFcn',  @untitled2_OutputFcn, ...
end
if nargout
else
end
% --- Executes just before untitled2 is made visible.
function untitled2_OpeningFcn(hObject, eventdata, handles, varargin)
% varargin   command line arguments to untitled2 (see VARARGIN)
% Choose default command line output for untitled2
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
三、运行结果
四、备注
版本:2014
原文链接:qq912100926.blog.csdn.net/article/details/116400127
