【语音处理】基于matlab GUI语音时域频域频谱图分析【含Matlab源码 527期】
海神之光 发表于 2022/05/29 04:03:06 2022/05/29
【摘要】 一、语音处理简介 MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口...
一、语音处理简介
MATLAB GUI是用户与计算机或计算机程序的接触点或交互方式,是用户与计算机进行信息交流的方式。图形用户界面(Graphical User Interfaces,GUI)则是由窗口、光标、按键、菜单、文字说明等对象(Object)构成的一个用户界面。用户通过一定的方法(如鼠标或键盘)选择、激活这些图形对象,使计算机产生某种动作或变化,比如实现计算、绘图等。本设计基于MATLAB GUI技术,完成了语音信号处理的界面平台,可进行语音的选取、线性预测分析(LPC)、语谱图、频谱等相关波形的显示。这样可以更直观、更方便地分析和处理语音信号,得到用户需要的实验结果。
具体理论知识参考:基于MATLAB GUI的语音处理界面设计
二、部分源代码
function varargout = gui(varargin)
% GUI MATLAB code for gui.fig
%      GUI, by itself, creates a new GUI or raises the existing
%      singleton*.
%      H = GUI returns the handle to a new GUI or the handle to
%      GUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in GUI.M with the given input arguments.
%      GUI('Property','Value',...) creates a new GUI or raises the
%      applied to the GUI before gui_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to gui_OpeningFcn via varargin.
% Edit the above text to modify the response to help gui
% Last Modified by GUIDE v2.5 23-Apr-2019 15:32:28
gui_Singleton = 1;
                   'gui_OpeningFcn', @gui_OpeningFcn, ...
                   'gui_OutputFcn',  @gui_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before gui is made visible.
function gui_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to gui (see VARARGIN)
% Choose default command line output for gui
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes gui wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = gui_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global aud RecordLength ShowLength FrequencyWindow1 FrequencyWindow2 fs nBits
global mag idx_last recObj myRecording bit
record(recObj,RecordLength);
tic
while toc<.1
end
bit = 2;
while toc<RecordLength
    myRecording = getaudiodata(recObj);
    idx = round(toc*fs);
    while idx-idx_last<.1*fs
       idx=round(toc*fs);
    end
   axes(handles.axes1)
   plot((max(1,size(myRecording,1)-fs*ShowLength):(2^bit):size(myRecording,1))./fs,myRecording(max(1,size(myRecording,1)-fs*ShowLength):(2^bit):end))
   mag = max(abs(myRecording));
   ylim([-1.2 1.2]*mag)
   xlim([max(0,size(myRecording,1)/fs-ShowLength)
   max(size(myRecording,1)/fs,ShowLength)])
   title('声音信号的波形显示');
   ylabel('Signal level(volts)');
   xlabel('Samples');
   drawnow
   idx_last = idx;
end
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
save data.mat aud RecordLength ShowLength FrequencyWindow1 FrequencyWindow2 fs nBits mag idx_last recObj myRecording
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
clc,clear,
close all force;
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
aud = audiodevinfo;
RecordLength = 15;
ShowLength = 15;
FrequencyWindow1 = 0;
FrequencyWindow2 = 3000;
fs = 44100;
nBits = 16;
mag = 1.05;
idx_last = 1;
 recObj = audiorecorder(fs,nBits,1);
 if isempty(recObj);
 else
     msgbox('语音设备已检测到!!!');
 end
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
global fs
load('data.mat')
sound(myRecording,fs);
function Untitled_1_Callback(hObject, eventdata, handles)
% hObject    handle to Untitled_1 (see GCBO)
global mag idx_last recObj myRecording bit x3
x1 = myRecording(max(1,size(myRecording,1)-fs*ShowLength):(2^bit):end);
N=length(x1);
x2 = x1-mean(x1);
x3 = smooth(x2);
axes(handles.axes1)
plot(x3,'b-','linewidth',2)
axis tight
title('零均值化——平滑滤波')
function Untitled_2_Callback(hObject, eventdata, handles)
% hObject    handle to Untitled_2 (see GCBO)
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]韩纪庆,张磊,郑铁然.语音信号处理(第3版)[M].清华大学出版社,2019.
[2]柳若边.深度学习:语音识别技术实践[M].清华大学出版社,2019.
[3]宋云飞,姜占才,魏中华.基于MATLAB GUI的语音处理界面设计[J].科技信息. 2013,(02)
原文链接:qq912100926.blog.csdn.net/article/details/114870522
