【图像处理】基于matlab GUI图像直方图+滤波+小波变换+分割处理系统【含Matlab源码 608期】
海神之光 发表于 2022/05/29 03:05:47 2022/05/29
【摘要】 一、图像处理简介 图像处理知识点: 1 数字图像处理及matlab实现知识点总结1-4 2 数字图像处理及matlab实现知识点总结 5-10 二、部分源代码 unction varargout =...
一、图像处理简介
图像处理知识点:
二、部分源代码
unction varargout = exp_gs(varargin)
% EXP_GS M-file for exp_gs.fig
%      EXP_GS, by itself, creates a new EXP_GS or raises the existing
%      singleton*.
%      H = EXP_GS returns the handle to a new EXP_GS or the handle to
%      EXP_GS('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in EXP_GS.M with the given input arguments.
%      EXP_GS('Property','Value',...) creates a new EXP_GS or raises the
%      applied to the GUI before exp_gs_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to exp_gs_OpeningFcn via varargin.
% Edit the above text to modify the response to help exp_gs
% Last Modified by GUIDE v2.5 30-Jun-2010 13:33:39
gui_Singleton = 1;
                   'gui_OpeningFcn', @exp_gs_OpeningFcn, ...
                   'gui_OutputFcn',  @exp_gs_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before exp_gs is made visible.
function exp_gs_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to exp_gs (see VARARGIN)
% Choose default command line output for exp_gs
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes exp_gs wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = exp_gs_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
ImgPath=get(handles.edit1,'String');
global img_1;
img_1=imread(ImgPath);
axes(handles.axes1);
imshow(img_1);
global histogram1;
histogram1=zeros(1,256);
[sizex,sizey]=size(img_1);
for ii=1:sizex % 计算直方图
    for jj=1:sizey
        histogram1(img_1(ii,jj)+1)=histogram1(img_1(ii,jj)+1)+1;
    end
end
maxhisto1=sum(histogram1);% 归一化
histogram1=histogram1/maxhisto1;
axes(handles.axes2);
bar(0:255,histogram1);
axis([0 255 0 max(histogram1)]);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
global img_1;
for ii=1:sizex % 减小动态范围
    for jj=1:sizey
        img_1tmp(ii,jj)=floor(img_1(ii,jj)/2)+64;
    end
end
global img_11;
img_11=img_1tmp;
axes(handles.axes3);
imshow(img_11);
histogram2=zeros(1,256);
for ii=1:sizex
    for jj=1:sizey
        histogram2(img_11(ii,jj)+1)=histogram2(img_11(ii,jj)+1)+1;
    end
end
maxhisto2=sum(histogram2);
histogram2=histogram2/maxhisto2;
axes(handles.axes4);
bar(0:255,histogram2);
axis([0 255 0 max(histogram2)]);
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
global img_1;
for ii=1:sizex % 直方图左移
    for jj=1:sizey
        img_1tmp(ii,jj)=img_1(ii,jj)-30;
    end
end
global img_11;
img_11=img_1tmp;
imshow(img_11);
histogram3=zeros(1,256);
for ii=1:sizex
    for jj=1:sizey
        histogram3(img_11(ii,jj)+1)=histogram3(img_11(ii,jj)+1)+1;
    end
end
maxhisto3=sum(histogram3);
histogram3=histogram3/maxhisto3;
bar(0:255,histogram3);
axis([0 255 0 max(histogram3)]);
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
global img_1;
for ii=1:sizex % 直方图右移
    for jj=1:sizey
        img_1tmp(ii,jj)=img_1(ii,jj)+30;
    end
end
global img_11;
img_11=img_1tmp;
imshow(img_11);
histogram4=zeros(1,256);
for ii=1:sizex
    for jj=1:sizey
        histogram4(img_11(ii,jj)+1)=histogram4(img_11(ii,jj)+1)+1;
    end
end
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/115107076
