【疾病分类】基于matlab SVM农作物叶子虫害识别与分类【含Matlab源码 624期】
海神之光 发表于 2022/05/29 04:10:34 2022/05/29
【摘要】 一、SVM简介 支持向量机(Support Vector Machine)是Cortes和Vapnik于1995年首先提出的,它在解决小样本、非线性及高维模式识别中表现出许多特有的优势,并能够推广应用到...
一、SVM简介
支持向量机(Support Vector Machine)是Cortes和Vapnik于1995年首先提出的,它在解决小样本、非线性及高维模式识别中表现出许多特有的优势,并能够推广应用到函数拟合等其他机器学习问题中。
1 数学部分
1.1 二维空间
2 算法部分
二、部分源代码
clear all
clc
disp('正在训练农作物叶子图像模板,请稍后...');
disp(' ');
%color_Ip = xunlian();
pause(2);
load C:\Users\lenovo\Desktop\图像检索\color_Ip.mat;
disp('图像训练完成,正在进行图像识别,请稍后...');
disp(' ');
pause(2);
path = input('请输入待识别叶子图像路径:'); % 'F:\病虫害识别\图像检索\示例2中等.jpg'
A = imread(path); % 读入叶子图像
G0 = lianghua_hsv(A); % 量化hsv分量并获得颜色直方图
color_Iq = color_feature(G0); % 提取颜色特征
color_Dpq = color_match(color_Ip,color_Iq); % 颜色特征匹配
[r c] = find(min(min(color_Dpq))==color_Dpq);
A=imread('F:\病虫害识别\图像检索\1.jpg');
[M,N,O] = size(A);
[h,s,v] = rgb2hsv(A);
H = h; S = s; V = v;
h = h*360;
%将hsv空间非等间隔量化:
%  h量化成16级;
%  s量化成4级;
%  v量化成4级;
for i = 1:M
    for j = 1:N
        if h(i,j)<=15||h(i,j)>345
            H(i,j) = 0;
        end
        if h(i,j)<=25&&h(i,j)>15
            H(i,j) = 1;
        end
        if h(i,j)<=45&&h(i,j)>25
            H(i,j) = 2;
        end
        if h(i,j)<=55&&h(i,j)>45
            H(i,j) = 3;
        end
        if h(i,j)<=80&&h(i,j)>55
            H(i,j) = 4;
        end
        if h(i,j)<=108&&h(i,j)>80
            H(i,j) = 5;
        end
        if h(i,j)<=140&&h(i,j)>108
            H(i,j) = 6;
        end
        if h(i,j)<=165&&h(i,j)>140
            H(i,j) = 7;
        end
        if h(i,j)<=190&&h(i,j)>165
            H(i,j) = 8;
        end
        if h(i,j)<=220&&h(i,j)>190
            H(i,j) = 9;
        end
        if h(i,j)<=255&&h(i,j)>220
            H(i,j) = 10;
        end
        if h(i,j)<=275&&h(i,j)>255
            H(i,j) = 11;
        end
        if h(i,j)<=290&&h(i,j)>275
            H(i,j) = 12;
        end
        if h(i,j)<=316&&h(i,j)>290
            H(i,j) = 13;
        end
        if h(i,j)<=330&&h(i,j)>316
            H(i,j) = 14;
        end
        if h(i,j)<=345&&h(i,j)>330
            H(i,j) = 15;
        end
    end
end
for i = 1:M
    for j = 1:N
        if s(i,j)<=0.15&&s(i,j)>0
            S(i,j) = 1;
        end
        if s(i,j)<=0.4&&s(i,j)>0.15
            S(i,j) = 2;
        end
        if s(i,j)<=0.75&&s(i,j)>0.4
            S(i,j) = 3;
        end
        if s(i,j)<=1&&s(i,j)>0.75
            S(i,j) = 4;
        end
    end
end
for i = 1:M
    for j = 1:N
        if v(i,j)<=0.15&&v(i,j)>0
            V(i,j) = 1;
        end
        if v(i,j)<=0.4&&v(i,j)>0.15
            V(i,j) = 2;
        end
        if v(i,j)<=0.75&&v(i,j)>0.4
            V(i,j) = 3;
        end
        if v(i,j)<=1&&v(i,j)>0.75
            V(i,j) = 4;
        end
    end
end
% 构建4*16二维数组存放H-S数据
Hist = zeros(16,4);
for i = 1:M
    for j = 1:N
        for k = 1:16
            for l = 1:4
                if  l==S(i,j)&& k==H(i,j)+1
                    Hist(k,l) = Hist(k,l)+1;
                end
            end
        end
    end
end
for k = 1:16
    for l =1:4
        His((k-1)*4+l) = Hist(k,l);%转化为一维数组
    end
end
His = His/sum(His)*1000;
% 手工绘制彩色图像直方图
% hist_h
m=0;
for j = 1:300
    if rem(j,16)==1 && m<16
        for k = 0:15
            for i = 1:200
                hist_h(i,j+k) = m;
            end
        end
        m = m+1;
    end
end
% hist_s
m=0;
for j = 1:300
    if rem(j,4) == 1 && m<64
        n = rem(m,4);
        for k = 0:3
            for i =1:200
                hist_s(i,j+k) = n+1;
            end
        end
        m = m+1;
    end
end
% hist_v
for j = 1:256
    for i = 1:200
        hist_v(i,j) = 0.98;
    end
end
% 把His赋值给hist_v
for k = 1:64
    for j = 1:256
        if floor((j-1)/4) == k
            for i = 1:200
                if i<200-His(k+1)%i>His(k+1)%
                    hist_v(i,j) = 0;
                end
            end
        end
    end
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/115190641
