【游戏】基于matlab GUI时钟设计【含Matlab源码 1102期】
海神之光 发表于 2022/05/29 02:56:48 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【游戏】基于matlab GUI时钟设计【含Matlab源码 1102期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = clockfjnu(varargin)
% CLOCKFJNU M-file for clockfjnu.fig
%      CLOCKFJNU, by itself, creates a new CLOCKFJNU or raises the existing
%      singleton*.
%      H = CLOCKFJNU returns the handle to a new CLOCKFJNU or the handle to
%      CLOCKFJNU('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CLOCKFJNU.M with the given input arguments.
%      CLOCKFJNU('Property','Value',...) creates a new CLOCKFJNU or raises the
%      applied to the GUI before clockfjnu_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to clockfjnu_OpeningFcn via varargin.
% Edit the above text to modify the response to help clockfjnu
% Last Modified by GUIDE v2.5 23-Jun-2021 22:44:21
gui_Singleton = 1;
                   'gui_OpeningFcn', @clockfjnu_OpeningFcn, ...
                   'gui_OutputFcn',  @clockfjnu_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before clockfjnu is made visible.
function clockfjnu_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to clockfjnu (see VARARGIN)
% Choose default command line output for clockfjnu
handles.output = hObject;
global  Title;
Title='北京时间';
global VarTime;
VarTime=0;
TimeZoneString=get(handles.TimeZone,'String');
TimeZoneStingSize=size(TimeZoneString);
for i=1:TimeZoneStingSize(1) %时区选择中,默认选中(GMT+08:00)北京时间
    if  strcmp( TimeZoneString{i},'(GMT+08:00)北京时间')
     set(handles.TimeZone,'value',i); %北京
     break;
    end
end
handles.t=timer('ExecutionMode','fixedRate' ,'TimerFcn',{@TimeUpdate,handles},'Period',1);
start(handles.t);
set(gcf, 'DeleteFcn', {@DeleteFcn, handles.t}); %设置窗口销毁时的回调函数
global hh;
global hm;
global hs;
axes(handles.axes1);
set(hObject,'NumberTitle','off');
set(hObject,'MenuBar','none');
set(hObject,'visible','on');
A=linspace(0,6.3,1000); %0到6.3之间产生1000个点
x1=8*cos(A);
y1=8*sin(A);  %设置外圆所对应的x,y值
x2=7*cos(A);
y2=7*sin(A);  %设置内圆所对应的x,y值
plot(x1,y1,'b','linewidth',1)
hold on
plot(x2,y2,'b','linewidth',3.5,'color',[0 0 0])
fill(0.4*cos(A),0.4*sin(A),'r');%时钟中心小实心圆点
axis off;  %取消坐标轴显示
axis equal;%坐标轴x,y等比率
for k=1:12; %时钟面盘12等分,并写上相应的1,2...12数字
xk=9*cos(-2*pi/12*k+pi/2);
yk=9*sin(-2*pi/12*k+pi/2);
plot([xk/9*8 xk/9*7],[yk/9*8 yk/9*7],'color',[1 0 0])
h=text(xk,yk,num2str(k),'fontsize',16,'color',...
[1 0 0],'HorizontalAlignment','center');
end
set(handles.TimeZoneStr,'string',Title);
% 计算时针位置
ti=clock;
th=-(ti(4)+ti(5)/60+ti(6)/3600)/12*2*pi+pi/2;
xh3=4.0*cos(th);
yh3=4.0*sin(th);
xh2=xh3/2+0.5*cos(th-pi/2);
yh2=yh3/2+0.5*sin(th-pi/2);
xh4=xh3/2-0.5*cos(th-pi/2);
yh4=yh3/2-0.5*sin(th-pi/2);
 hh=fill([0 xh2 xh3 xh4 0],[0 yh2 yh3 yh4 0],[1 0 0]);
% 计算分针位置
tm=-(ti(5)+ti(6)/60)/60*2*pi+pi/2;
xm3=6.0*cos(tm);
ym3=6.0*sin(tm);
xm2=xm3/2+0.5*cos(tm-pi/2);
ym2=ym3/2+0.5*sin(tm-pi/2);
xm4=xm3/2-0.5*cos(tm-pi/2);
ym4=ym3/2-0.5*sin(tm-pi/2);
hm=fill([0 xm2 xm3 xm4 0],[0 ym2 ym3 ym4 0],[0 1 0]);
% 计算秒针位置
ts=-(ti(6))/60*2*pi+pi/2;
hs=plot([0 7*cos(ts)],[0 7*sin(ts)],...
'color',[0 0 1],'linewidth',3);
set(gcf,'doublebuffer','on');
guidata(hObject, handles);
% UIWAIT makes clockfjnu wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = clockfjnu_OutputFcn(hObject, eventdata, handles)
function date_Callback(hObject, eventdata, handles)
% hObject    handle to date (see GCBO)
% Hints: get(hObject,'String') returns contents of date as text
%        str2double(get(hObject,'String')) returns contents of date as a double
% --- Executes during object creation, after setting all properties.
function date_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/118519385
