【细胞分割】基于matlab GUI分水岭算法细胞分割计数【含Matlab源码 637期】
海神之光 发表于 2022/05/29 01:52:57 2022/05/29
【摘要】 一、图像分割简介 理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】 二、部分源代码 function varargout = CellCount(varar...
一、图像分割简介
二、部分源代码
function varargout = CellCount(varargin)
% CELLCOUNT M-file for CellCount.fig
%      CELLCOUNT, by itself, creates a new CELLCOUNT or raises the existing
%      singleton*.
%      H = CELLCOUNT returns the handl e to a new CELLCOUNT or the handle to
%      CELLCOUNT('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CELLCOUNT.M with the given input arguments.
%      CELLCOUNT('Property','Value',...) creates a new CELLCOUNT or raises the
%      applied to the GUI before CellCount_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to CellCount_OpeningFcn via varargin.
% Edit the above text to modify the response to help CellCount
% Last Modified by GUIDE v2.5 01-May-2015 19:43:57
gui_Singleton = 1;
                   'gui_OpeningFcn', @CellCount_OpeningFcn, ...
                   'gui_OutputFcn',  @CellCount_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before CellCount is made visible.
function CellCount_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to CellCount (see VARARGIN)
% Choose default command line output for CellCount
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes CellCount wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = CellCount_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
function edit3_CreateFcn(hObject, eventdata, handles)
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to edit4 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit4 as text
%        str2double(get(hObject,'String')) returns contents of edit4 as a double
function edit4_CreateFcn(hObject, eventdata, handles)
end
function edit5_Callback(hObject, eventdata, handles)
% hObject    handle to edit5 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit5 as text
%        str2double(get(hObject,'String')) returns contents of edit5 as a double
function edit5_CreateFcn(hObject, eventdata, handles)
end
function edit6_Callback(hObject, eventdata, handles)
% hObject    handle to edit6 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit6 as text
%        str2double(get(hObject,'String')) returns contents of edit6 as a double
function edit6_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
function file_Callback(hObject, eventdata, handles)
% hObject    handle to file (see GCBO)
function open_Callback(hObject, eventdata, handles)
% hObject    handle to open (see GCBO)
global im;
[filename,pathname]=uigetfile({'*.jpg';'*bmp';'*.gif'},'选择图片');
%合成图片路径+文件名
str=[pathname filename];
%读取图片
im=imread(str);
%使用第一个axes
axes(handles.axes0);
imshow(im);
function save_Callback(hObject, eventdata, handles)
% hObject    handle to save (see GCBO)
% --- Executes on button press in pushbutton8.
function pushbutton8_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton8 (see GCBO)
close(gcf) %关闭当前figure句柄
% --- Executes on button press in pushbutton9.
function pushbutton9_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton9 (see GCBO)
global im
global I
global C
I=im;
R=I(:,:,1);
G=I(:,:,2);
B=I(:,:,3);
K=rgb2hsv(I);
H=K(:,:,1);
S=K(:,:,2);
V=K(:,:,3);
[cenwhite,copywhite]=Kmeans(H,3);
cenwhite;
A=copywhite;
[m,n]=size(A);
for i=1:m
    for j=1:n
        if A(i,j)==cenwhite(2)
           A(i,j)=1;
        else A(i,j)=0;
        end
    end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/115267339
