【数学建模】基于matlab GUI理发店排队模拟系统【含Matlab源码 1116期】
海神之光 发表于 2022/05/29 02:15:35 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI理发店排队模拟系统【含Matlab源码 1116期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = lifashi_final(varargin)
% LIFASHI_FINAL Application M-file for lifashi_final.fig
%    FIG = LIFASHI_FINAL launch lifashi_final GUI.
%    LIFASHI_FINAL('callback_name', ...) invoke the named callback.
% Last Modified by GUIDE v2.0 15-Aug-2020 00:44:45
if nargin == 0  % LAUNCH GUI
	fig = openfig(mfilename,'reuse');
	% Use system color scheme for figure:
	set(fig,'Color',get(0,'defaultUicontrolBackgroundColor'));
	% Generate a structure of handles to pass to callbacks, and store it.
	handles = guihandles(fig);
	guidata(fig, handles);
	if nargout > 0
		varargout{1} = fig;
	end
elseif ischar(varargin{1}) % INVOKE NAMED SUBFUNCTION OR CALLBACK
	try
		if (nargout)
			[varargout{1:nargout}] = feval(varargin{:}); % FEVAL switchyard
		else
		end
	catch
		disp(lasterr);
	end
end
%| ABOUT CALLBACKS:
%| GUIDE automatically appends subfunction prototypes to this file, and
%| sets objects' callback properties to call them through the FEVAL
%| switchyard above. This comment describes that mechanism.
%| Each callback subfunction declaration has the following form:
%| <SUBFUNCTION_NAME>(H, EVENTDATA, HANDLES, VARARGIN)
%| The subfunction name is composed using the object's Tag and the
%| callback type separated by '_', e.g. 'slider2_Callback',
%| 'figure1_CloseRequestFcn', 'axis1_ButtondownFcn'.
%| H is the callback object's handle (obtained using GCBO).
%| EVENTDATA is empty, but reserved for future use.
%| HANDLES is a structure containing handles of components in GUI using
%| tags as fieldnames, e.g. handles.figure1, handles.slider2. This
%| structure is created at GUI startup using GUIHANDLES and stored in
%| the figure's application data using GUIDATA. A copy of the structure
%| is passed to each callback.  You can store additional information in
%| this structure at GUI startup, and you can change the structure
%| during callbacks.  Call guidata(h, handles) after changing your
%| copy to replace the stored original so that subsequent callbacks see
%| the updates. Type "help guihandles" and "help guidata" for more
%| information.
%| VARARGIN contains any extra arguments you have passed to the
%| callback. Specify the extra arguments by editing the callback
%| property in the inspector. By default, GUIDE sets the property to:
%| <MFILENAME>('<SUBFUNCTION_NAME>', gcbo, [], guidata(gcbo))
%| Add any extra arguments after the last argument, before the final
%| closing parenthesis.
function varargout = lifashi_Callback(h, eventdata, handles, varargin)
function varargout = guke_Callback(h, eventdata, handles, varargin)
function varargout = pushbutton1_Callback(h, eventdata, handles, varargin)
ln=str2double(get(handles.lifashi,'string'));
axes(handles.axes1)
%理发仿真程序
%a(j,i):理发师j在第i分钟正在服务的顾客剩下的时间
%c(i):理发店里的顾客总数
%d(i):理发店等待的顾客数
%S(j) :理发师j的状态,1表示忙,0表示闲
%本程序模拟从第1分钟末到第10分钟末理发店的顾客数目,理发师的状态等情况
%假设理发师对顾客的服务都是从某分钟的末尾开始的
%假设理发师j的工作优先级高于j+1;
c(1)=0;d(1)=0;
for j=1:ln
    S(j)=0;
    a(j,1)=0;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/118771593
