【运动学】基于matlab GUI倒立摆系统【含Matlab源码 1117期】
海神之光 发表于 2022/05/29 03:09:24 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【运动学】基于matlab GUI倒立摆系统【含Matlab源码 1117期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = pendulum(varargin)
% PENDULUM M-file for pendulum.fig
%      PENDULUM, by itself, creates a new PENDULUM or raises the existing
%      singleton*.
%      H = PENDULUM returns the handle to a new PENDULUM or the handle to
%      PENDULUM('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in PENDULUM.M with the given input arguments.
%      PENDULUM('Property','Value',...) creates a new PENDULUM or raises the
%      applied to the GUI before pendulum_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to pendulum_OpeningFcn via varargin.
% Edit the above text to modify the response to help pendulum
% Last Modified by SHE on 15-Dec-2020 22:08:58
gui_Singleton = 1;
                   'gui_OpeningFcn', @pendulum_OpeningFcn, ...
                   'gui_OutputFcn',  @pendulum_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before pendulum is made visible.
function pendulum_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to pendulum (see VARARGIN)
% Choose default command line output for pendulum
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes pendulum wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = pendulum_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
%以字符串的形式来存储数据文本框1的内容。如果字符串不是数字,则现实空白内容
input =str2double(get(hObject,'String'));
%检查输入是否为空. 如果为空,则默认显示为0
if (isempty(input))
set(hObject,'String','0')
end
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function edit2_Callback(hObject, eventdata, handles)
% hObject    handle to edit2 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit2 as text
%        str2double(get(hObject,'String')) returns contents of edit2 as a double
%以字符串的形式来存储数据文本框2的内容。如果字符串不是数字,则现实空白内容
if (isempty(input))
end
function edit2_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
%以字符串的形式来存储数据文本框3的内容。如果字符串不是数字,则现实空白内容
if (isempty(input))
end
function edit3_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to edit4 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit4 as text
%        str2double(get(hObject,'String')) returns contents of edit4 as a double
%以字符串的形式来存储数据文本框4的内容。如果字符串不是数字,则现实空白内容
if (isempty(input))
end
function edit4_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
function edit5_Callback(hObject, eventdata, handles)
% hObject    handle to edit5 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit5 as text
%        str2double(get(hObject,'String')) returns contents of edit5 as a double
%以字符串的形式来存储数据文本框5的内容。如果字符串不是数字,则现实空白内容
if (isempty(input))
end
function edit5_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = get(hObject,'String') returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
popup_sel_index = get(handles.popupmenu1, 'Value');
switch popup_sel_index
    case 1
        set(handles.text10 ,'String','期望极点');
        set(handles.text11 ,'String','      -10             -10');
        set(handles.text12 ,'String','-2+2*sqrt(3)*i -2-2*sqrt(3)*i');
    case 2
        set(handles.text10 ,'String','加权矩阵');
        set(handles.text11 ,'String','Q=[1 0 0 0; 0 0 0 0; 0 0 1 0;0 0 0 0];');
        set(handles.text12 ,'String','     R=1');
    case 3
        set(handles.text10 ,'String','参考输入');
        set(handles.text11 ,'String','  y_r=0.2*U(t)');
        set(handles.text12 ,'String',' ');
     case 4
        set(handles.text10 ,'String','PID');
        set(handles.text11 ,'String','  P=5,I=0.001,D=1');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/118771597
