【气动学】基于matlab GUI弹道仿真【含Matlab源码 1136期】
海神之光 发表于 2022/05/29 02:47:49 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【气动学】基于matlab GUI弹道仿真【含Matlab源码 1136期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = p89(varargin)
% P89 MATLAB code for p89.fig
%      P89, by itself, creates a new P89 or raises the existing
%      singleton*.
%      H = P89 returns the handle to a new P89 or the handle to
%      P89('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in P89.M with the given input arguments.
%      P89('Property','Value',...) creates a new P89 or raises the
%      applied to the GUI before p89_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to p89_OpeningFcn via varargin.
% Edit the above text to modify the response to help p89
% Last Modified by GUIDE v2.5 16-Sep-2020 16:02:22
gui_Singleton = 1;
                   'gui_OpeningFcn', @p89_OpeningFcn, ...
                   'gui_OutputFcn',  @p89_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before p89 is made visible.
function p89_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to p89 (see VARARGIN)
% Choose default command line output for p89
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes p89 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = p89_OutputFcn(hObject, eventdata, handles)
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function edit2_Callback(hObject, eventdata, handles)
% hObject    handle to edit2 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit2 as text
%        str2double(get(hObject,'String')) returns contents of edit2 as a double
function edit2_CreateFcn(hObject, eventdata, handles)
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
function edit3_CreateFcn(hObject, eventdata, handles)
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to edit4 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit4 as text
%        str2double(get(hObject,'String')) returns contents of edit4 as a double
function edit4_CreateFcn(hObject, eventdata, handles)
end
function dydt=p89_dif(t,y,P,alp,dm,t1)
r=y(1:3);
v=y(4:6);
%UNTITLED3 此处显示有关此函数的摘要
%   此处显示详细说明
if t<t1
    phi=pi/2;
elseif t<t1+2
    phi =pi/2+alp;
elseif t<t1+20
    phi=atan(v(2)/v(1));
end
%shuchu
g=[0;-9.8;0];
Po=A3z(phi)'*[P;0;0];
dydt = [v; g+Po; dm];
%坐标转换私有函数
function A3=A3z(x)
A3=[cos(x) sin(x) 0;    -sin(x) cos(x) 0;     0     0       1];
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/118963946
