【图像分割】基于matlab GUI多种阈值图像分割(带面板)【含Matlab源码 733期】
海神之光 发表于 2022/05/29 03:36:13 2022/05/29
【摘要】 一、图像分割简介 理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】 二、部分源代码 function varargout = yuzhifenge(vara...
一、图像分割简介
二、部分源代码
function varargout = yuzhifenge(varargin)
% YUZHIFENGE MATLAB code for yuzhifenge.fig
%      YUZHIFENGE, by itself, creates a new YUZHIFENGE or raises the existing
%      singleton*.
%      H = YUZHIFENGE returns the handle to a new YUZHIFENGE or the handle to
%      YUZHIFENGE('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in YUZHIFENGE.M with the given input arguments.
%      YUZHIFENGE('Property','Value',...) creates a new YUZHIFENGE or raises the
%      applied to the GUI before yuzhifenge_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to yuzhifenge_OpeningFcn via varargin.
% Edit the above text to modify the response to help yuzhifenge
% Last Modified by GUIDE v2.5 05-Nov-2017 11:53:20
gui_Singleton = 1;
                   'gui_OpeningFcn', @yuzhifenge_OpeningFcn, ...
                   'gui_OutputFcn',  @yuzhifenge_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before yuzhifenge is made visible.
function yuzhifenge_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to yuzhifenge (see VARARGIN)
% Choose default command line output for yuzhifenge
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes yuzhifenge wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = yuzhifenge_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
global im;
[filename,pathname]=...
	uigetfile({'*.jpg';'*.bnp';'*.png'},'选择图片');
str=[pathname filename];
im=imread(str);
axes(handles.axes1);
imshow(im);
title('原始图像')
axes(handles.axes3);
if isrgb( im )
    im=rgb2gray(im);
end
hist_im=imhist(im); %计算直方图
bar(hist_im);%画直方图
title('原始图像灰度直方图')
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
close(gcf)
% --- Executes on button press in radiobutton1.
function radiobutton1_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton1 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton1
set(handles.radiobutton1,'value',1);
set(handles.radiobutton2,'value',0);
set(handles.radiobutton3,'value',0);
set(handles.popupmenu1,'value',1);
set(handles.popupmenu2,'value',1);
global im;
        B=im;
        T=0.5*(double(min(B(:)))+double(max(B(:))));
        d=false;
        %通过迭代求最佳阈值
        while~d
         g=B>=T;%g=0或1
         Tn=0.5*(mean(B(g))+mean(B(~g)));%mean(A,2)是矩阵求各行的均值,
         %mean(A)表示求矩阵A的均值,默认的是求各列的均值
         if(abs(T-Tn)<0.1)
         d=1;
         end
        T=Tn;
        end
        axes(handles.axes2);
        % 根据最佳阈值进行图像分割
        level=T/255;
        J=im2bw(B,level);
        imshow(J);
        title('使用基本全局阈值法');
% --- Executes on button press in radiobutton2.
function radiobutton2_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton2 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton2
set(handles.radiobutton1,'value',0);
set(handles.radiobutton2,'value',1);
global im;
        I=im;
        I=im2double(I);
        %[width,height]=size(I);
        %otsu
        Th = graythresh(I);
        BW = im2bw(I,Th);
        imshow(BW);
        title('Otsu最佳阈值法');
% --- Executes on button press in radiobutton3.
function radiobutton3_Callback(hObject, eventdata, handles)
% hObject    handle to radiobutton3 (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of radiobutton3
set(handles.radiobutton3,'value',1);
global im;
        zi=im;
        bw=adaptivethreshold(zi,11,0.03,0);%	ws=11-平均滤波时的窗口大小,可参考fspecial的用法
                                            %	C-0.03常量,需要根据经验选取合适的参数
                                            %	tm-开关变量,tm=1进行中值滤波,tm=0则进行均值滤波
                                            %	bw-图像分割后输出的二值图像
        imshow(bw);
        title('自适应阈值');
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]赵勇,方宗德,庞辉,王侃伟.基于量子粒子群优化算法的最小交叉熵多阈值图像分割[J].计算机应用研究. 2008,(04)
原文链接:qq912100926.blog.csdn.net/article/details/115529739
