【无线通信】基于matlab无线传感网络WSN仿真【含Matlab源码 1237期】
海神之光 发表于 2022/05/29 03:36:30 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【无线通信】基于matlab无线传感网络WSN仿真【含Matlab源码 1237期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = ct_wsn(varargin)
% CT_WSN M-file for ct_wsn.fig
%      CT_WSN, by itself, creates a new CT_WSN or raises the existing
%      singleton*.
%      H_edit = CT_WSN returns the handle to a new CT_WSN or the handle to
%      CT_WSN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CT_WSN.M with the given input arguments.
%      CT_WSN('Property','Value',...) creates a new CT_WSN or raises the
%      applied to the GUI before ct_wsn_OpeningFunction gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to ct_wsn_OpeningFcn via varargin.
% Edit the above text to modify the response to help ct_wsn
% Last Modified by GUIDE v2.5 25-Mar-2021 18:16:18
gui_Singleton = 1;
                   'gui_OpeningFcn', @ct_wsn_OpeningFcn, ...
                   'gui_OutputFcn',  @ct_wsn_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before ct_wsn is made visible.
function ct_wsn_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to ct_wsn (see VARARGIN)
% Choose default command line output for ct_wsn
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes ct_wsn wait for user response (see UIRESUME)
% uiwait(handles.figure1);
L_CFP_maxFcn(handles);
set(handles.BO_edit,'String', BO_minFcn(handles));
rdata_maxFcn(handles);
function varargout = ct_wsn_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function Nrouter_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to Nrouter_edit (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function Nend_node_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to Nend_node_edit (see GCBO)
end
function H_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to H_edit (see GCBO)
end
function Hsink_edit_CreateFcn(hObject, eventdata, handles)
% hObject    handle to Hsink_edit (see GCBO)
end
function Nrouter_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of Nrouter_edit as text
%        str2double(get(hObject,'String')) returns contents of Nrouter_edit as a double
function Nend_node_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of Nend_node_edit as text
%        str2double(get(hObject,'String')) returns contents of Nend_node_edit as a double
function H_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of H_edit as text
%        str2double(get(hObject,'String')) returns contents of H_edit as a double
function Hsink_edit_Callback(hObject, eventdata, handles)
% Hints: get(hObject,'String') returns contents of Hsink_edit as text
%        str2double(get(hObject,'String')) returns contents of Hsink_edit as a double
H = str2double(get(handles.H_edit,'String'));    %Height of the tree
Hsink = str2double(get(handles.Hsink_edit,'String'));
if Hsink > H
    warndlg('! Hsink is not feasible (Hsink <= H) !','Warning');
    set(handles.Hsink_edit,'String', H);
else
end
% --- Executes on button press in S_checkbox.
function S_checkbox_Callback(hObject, eventdata, handles)
% hObject    handle to S_checkbox (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of S_checkbox
function bdata_edit_Callback(hObject, eventdata, handles)
% hObject    handle to bdata_edit (see GCBO)
% Hints: get(hObject,'String') returns contents of bdata_edit as text
%        str2double(get(hObject,'String')) returns contents of bdata_edit as a double
function bdata_edit_CreateFcn(hObject, eventdata, handles)
end
function rdata_edit_Callback(hObject, eventdata, handles)
% hObject    handle to rdata_edit (see GCBO)
% Hints: get(hObject,'String') returns contents of rdata_edit as text
%        str2double(get(hObject,'String')) returns contents of rdata_edit as a double
function rdata_edit_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in rdata_max_button.
function rdata_max_button_Callback(hObject, eventdata, handles)
% hObject    handle to rdata_max_button (see GCBO)
function SO_edit_Callback(hObject, eventdata, handles)
% hObject    handle to SO_edit (see GCBO)
% Hints: get(hObject,'String') returns contents of SO_edit as text
%        str2double(get(hObject,'String')) returns contents of SO_edit as a double
BO_minFcn(handles);
function SO_edit_CreateFcn(hObject, eventdata, handles)
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/119844312
