【数学建模】基于matlab GUI干线交通控制方法【含Matlab源码 1259期】
海神之光 发表于 2022/05/29 03:06:19 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI干线交通控制方法【含Matlab源码 1259期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得2份代码(有效期为订阅日起,三天内有效);
三、部分源代码
function varargout = CrossSim(varargin)
% CROSSSIM MATLAB code for CrossSim.fig
%      CROSSSIM, by itself, creates a new CROSSSIM or raises the existing
%      singleton*.
%      H = CROSSSIM returns the handle to a new CROSSSIM or the handle to
%      CROSSSIM('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CROSSSIM.M with the given input arguments.
%      CROSSSIM('Property','Value',...) creates a new CROSSSIM or raises the
%      applied to the GUI before CrossSim_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to CrossSim_OpeningFcn via varargin.
% Edit the above text to modify the response to help CrossSim
% Last Modified by GUIDE v2.5 06-Dec-2020 16:56:12
gui_Singleton = 1;
                   'gui_OpeningFcn', @CrossSim_OpeningFcn, ...
                   'gui_OutputFcn',  @CrossSim_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before CrossSim is made visible.
function CrossSim_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to CrossSim (see VARARGIN)
% Choose default command line output for CrossSim
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
data = get(handles.main_fig,'UserData');
data.stop = false;
data.running = 0;
set(handles.main_fig,'UserData',data);
% UIWAIT makes CrossSim wait for user response (see UIRESUME)
% uiwait(handles.main_fig);
function varargout = CrossSim_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in sim_button.
function sim_button_Callback(hObject, eventdata, handles)
% hObject    handle to sim_button (see GCBO)
set(handles.sim_button, 'String', 'Pause simulation');
switch data.running
    case 0
        if (get(handles.type_1d,'Value') == 1)
            type = 1;
            city_gen;
            city = 'city.mat';
        else
            type = 2;
            city_gen_2d;
            city = 'city_2d.mat';
        end
        load(city);
        cyc = str2double(get(handles.cycles,'String'));
        p = str2double(get(handles.speed,'String'));
        newFig = figure;
        set(newFig,'Name','CrossSim Simulator');
        b = Builder(city);
        s = Simulation(b);
        d = Drawer(b);
        if (get(handles.custom_mode,'Value') == 1)
            mode = 1;
        elseif (get(handles.opt_mode,'Value') == 1)
            mode = 2;
        else
            mode = 3;
        end
        c = 1;
        switch (type)
            case 1
                switch (mode)
                    case 1
                        load('custom.mat');
                        gts = gts_1d;
                    case 2
                        disp('Optimalization has started');
                        gts = gaoptim(b, cyc);
                        disp('Optimalization has finished');
                    case 3
                        gts = zeros(1,(cyc-1)*b.numbers(1)) + 20;
                        rts = 0;
                        off = 0;
                end
            case 2
                switch (mode)
                    case 1
                        load('custom.mat');
                        gts = gts_2d;
                        rts = rts_2d;
                        off = off_2d;
                    case 2
                        [gts, rts, off] = time_calc(b);
                    case 3
                        gts = zeros(1,b.numbers(1)) + 20;
                        rts = zeros(1,b.numbers(1)) + 10;
                        for i = 1:b.numbers(1)
                            off(i) = mod(i,3)*10;
                        end
                end
        end
        s.init(gts,rts,off,rn(c:c+b.numbers(2)),type);
        isPaused = 0;
        data.stop = false;
        data.running = 1;
        set(handles.main_fig, 'UserData', data);
        keep_running = 1;
        while (keep_running == 1 && max(b.cycles) < cyc)
            while (isPaused == 1)
                if data.running == 1
                    isPaused=0;
                end
                if data.stop
                    keep_running=0;
                    isPaused=0;
                end
                pause(0.5);
            end
            figure(newFig);
            switch (type)
                case 1
                    s.simulate_1(gts,1,rn(c:c+b.numbers(2)));
                case 2
                    s.simulate_2(gts,rts,off,1,rn(c:c+b.numbers(2)));
            end
            d.draw();
            pause(p);
            M(c) = getframe(gcf);
            c = c + 1;
            if data.stop
                keep_running=0;
            end
            if data.running == 2
                isPaused=1;
            end
        end
        close(newFig);
        if (get(handles.save_cb, 'Value') == 1)
            movie2avi(M, get(handles.filename, 'String'), 'fps', 5);
        end
        set(handles.sim_button, 'String', 'Start simulation');
        data.stop = true;
        data.running = 0;
    case 1
        data.running = 2;
        set(handles.sim_button, 'String', 'Continue simulation');
    case 2
        data.running = 1;
end
function cycles_Callback(hObject, eventdata, handles)
% hObject    handle to cycles (see GCBO)
% Hints: get(hObject,'String') returns contents of cycles as text
%        str2double(get(hObject,'String')) returns contents of cycles as a double
% --- Executes during object creation, after setting all properties.
function cycles_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function speed_Callback(hObject, eventdata, handles)
% hObject    handle to speed (see GCBO)
% Hints: get(hObject,'String') returns contents of speed as text
%        str2double(get(hObject,'String')) returns contents of speed as a double
function speed_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in exit_button.
function exit_button_Callback(hObject, eventdata, handles)
% hObject    handle to exit_button (see GCBO)
close(handles.main_fig);
% --- Executes on button press in custom_mode.
function custom_mode_Callback(hObject, eventdata, handles)
% hObject    handle to custom_mode (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of custom_mode
% --- Executes on button press in opt_mode.
function opt_mode_Callback(hObject, eventdata, handles)
% hObject    handle to opt_mode (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of opt_mode
% --- Executes on button press in save_cb.
function save_cb_Callback(hObject, eventdata, handles)
% hObject    handle to save_cb (see GCBO)
% Hint: get(hObject,'Value') returns toggle state of save_cb
% --- Executes on button press in save_button.
function save_button_Callback(hObject, eventdata, handles)
% hObject    handle to save_button (see GCBO)
    type = 1;
    city_gen;
    city = 'city.mat';
else
    type = 2;
    city_gen_2d;
end
delete(get(handles.filename, 'String'));
mymovie = avifile(get(handles.filename, 'String'), 'compression','None', 'fps', 5);
load(city);
newFig = figure('Visible', 'off');
%set(newFig, 'Visible', 'off');
b = Builder(city);
s = Simulation(b);
d = Drawer(b);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/119951101
