【数学建模】基于matlab GUI排队系统仿真【含Matlab源码 1253期】
海神之光 发表于 2022/05/29 02:54:51 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI排队系统仿真【含Matlab源码 1253期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = classdesign(varargin)
% CLASSDESIGN MATLAB code for classdesign.fig
%      CLASSDESIGN, by itself, creates a new CLASSDESIGN or raises the existing
%      singleton*.
%      H = CLASSDESIGN returns the handle to a new CLASSDESIGN or the handle to
%      CLASSDESIGN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in CLASSDESIGN.M with the given input arguments.
%      CLASSDESIGN('Property','Value',...) creates a new CLASSDESIGN or raises the
%      applied to the GUI before classdesign_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to classdesign_OpeningFcn via varargin.
% Edit the above text to modify the response to help classdesign
% Last Modified by GUIDE v2.5 26-Aug-2021 17:23:25
gui_Singleton = 1;
                   'gui_OpeningFcn', @classdesign_OpeningFcn, ...
                   'gui_OutputFcn',  @classdesign_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before classdesign is made visible.
function classdesign_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to classdesign (see VARARGIN)
% Choose default command line output for classdesign
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes classdesign wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = classdesign_OutputFcn(hObject, eventdata, handles)
function ser_rate_Callback(hObject, eventdata, handles)
% hObject    handle to ser_rate (see GCBO)
% Hints: get(hObject,'String') returns contents of ser_rate as text
%        str2double(get(hObject,'String')) returns contents of ser_rate as a double
% --- Executes during object creation, after setting all properties.
function ser_rate_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function MYGETA_Callback(hObject, eventdata, handles)
% hObject    handle to MYGETA (see GCBO)
% Hints: get(hObject,'String') returns contents of MYGETA as text
%        str2double(get(hObject,'String')) returns contents of MYGETA as a double
function MYGETA_CreateFcn(hObject, eventdata, handles)
end
function server_count_Callback(hObject, eventdata, handles)
% hObject    handle to server_count (see GCBO)
% Hints: get(hObject,'String') returns contents of server_count as text
%        str2double(get(hObject,'String')) returns contents of server_count as a double
function server_count_CreateFcn(hObject, eventdata, handles)
end
function edit4_Callback(hObject, eventdata, handles)
% hObject    handle to LS (see GCBO)
% Hints: get(hObject,'String') returns contents of LS as text
%        str2double(get(hObject,'String')) returns contents of LS as a double
function LS_CreateFcn(hObject, eventdata, handles)
end
function edit5_Callback(hObject, eventdata, handles)
% hObject    handle to TS (see GCBO)
% Hints: get(hObject,'String') returns contents of TS as text
%        str2double(get(hObject,'String')) returns contents of TS as a double
function TS_CreateFcn(hObject, eventdata, handles)
end
function edit6_Callback(hObject, eventdata, handles)
% hObject    handle to edit6 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit6 as text
%        str2double(get(hObject,'String')) returns contents of edit6 as a double
function edit6_CreateFcn(hObject, eventdata, handles)
end
function edit7_Callback(hObject, eventdata, handles)
% hObject    handle to edit7 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit7 as text
%        str2double(get(hObject,'String')) returns contents of edit7 as a double
function edit7_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
% --- Executes on button press in cal.
function cal_Callback(hObject, eventdata, handles)
% hObject    handle to cal (see GCBO)
Lq = 0; %平均排队长
Ls = 0;      %平均队长
Tq = 0;      %平均排队时间
Ts = 0;      %平均逗留时间
lamda=str2double(get(handles.arr_rate,'String'));
u=str2double(get(handles.ser_rate,'String'));
s=str2double(get(handles.server_count,'String'));
mode=get(handles.single,'Value');%仿真类型
mode1=get(handles.wait_sys,'Value');%排队系统类型
if mode1==1
   switch mode
      case 1 %单服务台模式
        set(handles.attention,'String','此种情况下,到达率要小于服务率');
        lou = lamda/u;%获得服务强度
        %----以下为仿真模型参数计算
        if ((lou > 0)&&(lou < 1) &&(lamda>0) && (u>0))
            Lq = lou^2/(1-lou); %平均排队长
            Ls = Lq + lou;      %平均队长
            Tq = Lq/lamda;      %平均排队时间
            Ts = Ls/lamda;      %平均逗留时间
        else
            errordlg('输入错误,请重新输入','错误');
        end
      case 0%多服务模式
        set(handles.attention,'String','此种情况下,到达率要小于(服务率*服务台数)');
        a=lamda/u;
        lou = a/s;
        if (lou > 0)&&(lou < 1) &&(lamda>0) && (u>0) && (s>0)&&(s==fix(s))
            Lq = lou/(1-lou)*C(s,a);
            Ls = Lq + a;
            Tq = Lq/lamda;
            Ts=Ls/lamda;
        else
        end
    otherwise
        errordlg('请选择仿真类型','错误');
   end
else
        set(handles.attention,'String','此种情况下,只需注意到达率、服务率大于0,服务台数为正整数');
        a=lamda/u;
        if (lamda>0) && (u>0) && (s>=0)&&(s==fix(s))
            Lq = 0;
            Ls = a*(1-B(s,a));
            Tq = 0;
            Ts=Ls/lamda;
        else
        end
end
%显示平均等待时间,平均队长等
set(handles.LS,'string',num2str(Ls));
set(handles.LQ,'string',num2str(Lq));
set(handles.TS,'string',num2str(Ts));
set(handles.TQ,'string',num2str(Tq));
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
global flag
flag=0;
ts=timerfind;
if ~isempty(ts)
    stop(ts);
end
% --- Executes on button press in exit.
function exit_Callback(hObject, eventdata, handles)
% hObject    handle to exit (see GCBO)
ts=timerfind;
if ~isempty(ts)
    stop(ts);
    delete(ts);
end
Button=questdlg('确定退出吗','请选择','是','否','否');
switch Button
    case '是'
        close(gcf);
    case '否'
end
function uipanel1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to uipanel1 (see GCBO)
% --- Executes when selected object is changed in uipanel1.
function uipanel1_SelectionChangeFcn(hObject, eventdata, handles)
% hObject    handle to the selected object in uipanel1
% eventdata  structure with the following fields (see UIBUTTONGROUP)
%	EventName: string 'SelectionChanged' (read only)
%	OldValue: handle of the previously selected object or empty if none was selected
%	NewValue: handle of the currently selected object
if  get(handles.single,'Value')==get(handles.single,'Max')
    set(handles.server_count,'Enable','off');
    set(handles.server_count,'String','1');
else
     set(handles.server_count,'Enable','on');
end
function Myaxe_CreateFcn(hObject, eventdata, handles)
% hObject    handle to Myaxe (see GCBO)
% Hint: place code in OpeningFcn to populate Myaxe
% --- Executes on mouse press over axes background.
function Myaxe_ButtonDownFcn(hObject, eventdata, handles)
function arr_rate_Callback(hObject, eventdata, handles)
% hObject    handle to arr_rate (see GCBO)
% Hints: get(hObject,'String') returns contents of arr_rate as text
%        str2double(get(hObject,'String')) returns contents of arr_rate as a double
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
  • 276
  • 277
  • 278
  • 279
  • 280
  • 281
  • 282
  • 283
  • 284
  • 285
  • 286
  • 287
  • 288
  • 289
  • 290
  • 291
  • 292
  • 293
  • 294
  • 295
  • 296
  • 297
  • 298
  • 299
  • 300
  • 301
  • 302
  • 303
  • 304
  • 305
  • 306
  • 307
  • 308
  • 309
  • 310
  • 311
  • 312
  • 313
  • 314
  • 315
  • 316
  • 317
  • 318
  • 319
  • 320
  • 321
  • 322
  • 323
  • 324
  • 325
  • 326
  • 327
  • 328
  • 329
  • 330
  • 331
  • 332
  • 333
  • 334
  • 335
  • 336
  • 337
  • 338
  • 339
  • 340
  • 341
  • 342
  • 343
  • 344
  • 345
  • 346
  • 347
  • 348
  • 349
  • 350
  • 351
  • 352
  • 353
  • 354
  • 355
  • 356
  • 357
  • 358
  • 359
  • 360
  • 361
  • 362
  • 363
  • 364
  • 365
  • 366
  • 367
  • 368
  • 369
  • 370
  • 371
  • 372
  • 373
  • 374
  • 375
  • 376
  • 377
  • 378
  • 379
  • 380
  • 381
  • 382
  • 383
  • 384
  • 385
  • 386
  • 387
  • 388
  • 389
  • 390
  • 391
  • 392
  • 393
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/119933965
