【图像分割】基于matlab GUI迭代阙值选择+最大类间差+区域生长图像分割【含Matlab源码 816期】
海神之光 发表于 2022/05/29 01:21:55 2022/05/29
【摘要】 一、图像分割简介 理论知识参考:【基础教程】基于matlab图像处理图像分割【含Matlab源码 191期】 二、部分源代码 function varargout = ImageDivision(v...
一、图像分割简介
二、部分源代码
function varargout = ImageDivision(varargin)
% IMAGEDIVISION M-file for ImageDivision.fig
%      IMAGEDIVISION, by itself, creates a new IMAGEDIVISION or raises the existing
%      singleton*.
%      H = IMAGEDIVISION returns the handle to a new IMAGEDIVISION or the handle to
%      IMAGEDIVISION('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in IMAGEDIVISION.M with the given input arguments.
%      IMAGEDIVISION('Property','Value',...) creates a new IMAGEDIVISION or raises the
%      applied to the GUI before ImageDivision_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to ImageDivision_OpeningFcn via varargin.
% Edit the above text to modify the response to help ImageDivision
% Last Modified by GUIDE v2.5 26-Aug-2013 17:11:44
gui_Singleton = 1;
                   'gui_OpeningFcn', @ImageDivision_OpeningFcn, ...
                   'gui_OutputFcn',  @ImageDivision_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before ImageDivision is made visible.
function ImageDivision_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to ImageDivision (see VARARGIN)
% Choose default command line output for ImageDivision
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes ImageDivision wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = ImageDivision_OutputFcn(hObject, eventdata, handles)
function file_Callback(hObject, eventdata, handles)
% hObject    handle to file (see GCBO)
function openfile_Callback(hObject, eventdata, handles)
% hObject    handle to openfile (see GCBO)
global x;
[name,path]=uigetfile('*.*','');
file=[path,name];
axes(handles.axes1);
x=imread(file);
imshow(x);
x=rgb2gray(x);
handles.img=x;
guidata(hObject,handles);
function savefile_Callback(hObject, eventdata, handles)
% hObject    handle to savefile (see GCBO)
set(handles.axes2,'HandleVisibility','ON');
axes(handles.axes2);
[filename,pathname]=uiputfile({'*.jpg';'*.bmp';'*.tif';'*.*'},'save image as');
file=strcat(pathname,filename);
i=getimage(gca);
imwrite(i,file);
set(handles.axes2,'HandleVisibility','OFF');
function exit_Callback(hObject, eventdata, handles)
% hObject    handle to exit (see GCBO)
clc;
close all;
close('gcf');
function preprocessing_Callback(hObject, eventdata, handles)
% hObject    handle to preprocessing (see GCBO)
function HistEnhance_Callback(hObject, eventdata, handles)
% hObject    handle to HistEnhance (see GCBO)
I=handles.img;
I_hist=histeq(I);
imshow(I_hist);
function LiSmooth_Callback(hObject, eventdata, handles)
% hObject    handle to LiSmooth (see GCBO)
I=handles.img;
I_aver=filter2(fspecial('average',3),I)/255;
imshow(I_aver);
function LogTrans_Callback(hObject, eventdata, handles)
% hObject    handle to LogTrans (see GCBO)
I=handles.img;
I_log=double(I);
I_log=log(I_log+1);
imshow(mat2gray(I_log));
function EdgeDetection_Callback(hObject, eventdata, handles)
% hObject    handle to EdgeDetection (see GCBO)
function Edge_Sobel_Callback(hObject, eventdata, handles)
% hObject    handle to Edge_Sobel (see GCBO)
I=handles.img;
BW1=edge(I,'sobel');
imshow(BW1);
function Edge_Prewitt_Callback(hObject, eventdata, handles)
% hObject    handle to Edge_Prewitt (see GCBO)
I=handles.img;
BW2=edge(I,'prewitt');
imshow(BW2);
function Edge_Canny_Callback(hObject, eventdata, handles)
% hObject    handle to Edge_Canny (see GCBO)
I=handles.img;
BW3=edge(I,'canny');
imshow(BW3);
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/116031423
