【数学建模】基于matlab GUI模拟冰山运输系统(参数可调)【含Matlab源码 895期】
海神之光 发表于 2022/05/29 00:57:34 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数学建模】基于matlab GUI模拟冰山运输系统(参数可调)【含Matlab源码 895期】 获取代码方式2: 通过订阅紫极神光博客付费...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = bingshan(varargin)
% BINGSHAN MATLAB code for bingshan.fig
%      BINGSHAN, by itself, creates a new BINGSHAN or raises the existing
%      singleton*.
%      H = BINGSHAN returns the handle to a new BINGSHAN or the handle to
%      BINGSHAN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in BINGSHAN.M with the given input1 arguments.
%      BINGSHAN('Property','Value',...) creates a new BINGSHAN or raises the
%      applied to the GUI before bingshan_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to bingshan_OpeningFcn via varargin.
% Edit the above text to modify the response to help bingshan
% Last Modified by GUIDE v2.5 14-Dec-2015 15:09:14
gui_Singleton = 1;
                   'gui_OpeningFcn', @bingshan_OpeningFcn, ...
                   'gui_OutputFcn',  @bingshan_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before bingshan is made visible.
function bingshan_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to bingshan (see VARARGIN)
% Choose default command line output for bingshan
handles.output = hObject;
%题目要求的输入参数
global r0;
r0=100000;
global u;
u=1;
global s;
s=1000;
global a1;
a1=0.08;
global a2;
a2=50;
global d0
d0=500;
global b;
b=1;
%用于判断是否按下结束仿真按钮
global p;
p=0;
%时间+1的延时
global deltime;
deltime=0.01;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes bingshan wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = bingshan_OutputFcn(hObject, eventdata, handles)
function time_Callback(hObject, eventdata, handles)
% hObject    handle to time (see GCBO)
% Hints: get(hObject,'String') returns contents of time as text
%        str2double(get(hObject,'String')) returns contents of time as a double
% --- Executes during object creation, after setting all properties.
function time_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function r_Callback(hObject, eventdata, handles)
% hObject    handle to r (see GCBO)
% Hints: get(hObject,'String') returns contents of r as text
%        str2double(get(hObject,'String')) returns contents of r as a double
function r_CreateFcn(hObject, eventdata, handles)
end
function sleft_Callback(hObject, eventdata, handles)
% hObject    handle to sleft (see GCBO)
% Hints: get(hObject,'String') returns contents of sleft as text
%        str2double(get(hObject,'String')) returns contents of sleft as a double
function sleft_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on selection change in del.
function del_Callback(hObject, eventdata, handles)
% hObject    handle to del (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns del contents as cell array
%        contents{get(hObject,'Value')} returns selected item from del
                %获取时间+1延时时长
global deltime;
deltime1=get(handles.del,'String');
val=get(handles.del,'Value');
deltime=str2double(deltime1{val});
% set(handles.test,'String',deltime);
function del_CreateFcn(hObject, eventdata, handles)
% Hint: listbox controls usually have a white background on Windows.
end
% --- Executes on button press in input1.
function input1_Callback(hObject, eventdata, handles)
% hObject    handle to input1 (see GCBO)
global r0;
global u;
global s;
global a1;
global a2;
global d0
global b;
%输入数据 按钮,读取用户输入的数据
str={'r0','u','s','a1','a2','d0','b'};
inputdata=inputdlg(str,'输入',1);
% if ~isempty(inputdata);         %如果输入数据存在缺省值,则视其为1
% if ~isempty(inputdata(1));
%     set(handles.test1,'String','数据不全');
% elseif isempty(inputdata(1));
%     set(handles.test1,'String','数据可行');
% end
%按顺序赋值给各参数
r0=str2double(inputdata(1));
u=str2double(inputdata(2));
s=str2double(inputdata(3));
a1=str2double(inputdata(4));
a2=str2double(inputdata(5));
d0=str2double(inputdata(6));
b=str2double(inputdata(7));
% end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1]李昕.MATLAB数学建模[M].清华大学出版社.2017
[2]王健,赵国生.MATLAB数学建模与仿真[M].清华大学出版社.2016
[3]余胜威.MATLAB数学建模经典案例实战[M].清华大学出版社.2015
原文链接:qq912100926.blog.csdn.net/article/details/116923005
