【图像处理】基于matlab GUI图像直方图+滤波处理【含Matlab源码 839期】
海神之光 发表于 2022/05/29 01:56:54 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。 获取代码方式2: 完整代码已上传我的资源:【图像处理】基于matlab GUI图像直方图+滤波处...
一、获取代码方式
获取代码方式1:
获取代码方式2:
完整代码已上传我的资源:【图像处理】基于matlab GUI图像直方图+滤波处理【含Matlab源码 839期】
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、图像处理简介
图像处理知识点:
1 数字图像处理及matlab实现知识点总结1-4
2 数字图像处理及matlab实现知识点总结 5-10
三、部分源代码
function varargout = mygui(varargin)
% MYGUI MATLAB code for mygui.fig
%      MYGUI, by itself, creates a new MYGUI or raises the existing
%      singleton*.
%      H = MYGUI returns the handle to a new MYGUI or the handle to
%      MYGUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MYGUI.M with the given input arguments.
%      MYGUI('Property','Value',...) creates a new MYGUI or raises the
%      applied to the GUI before mygui_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to mygui_OpeningFcn via varargin.
% Edit the above text to modify the response to help mygui
% Last Modified by GUIDE v2.5 04-May-2018 10:20:34
gui_Singleton = 1;
                   'gui_OpeningFcn', @mygui_OpeningFcn, ...
                   'gui_OutputFcn',  @mygui_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before mygui is made visible.
function mygui_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to mygui (see VARARGIN)
% Choose default command line output for mygui
handles.output = hObject;
set(handles.axes3,'Visible','off');
set(handles.axes2,'Visible','off');
set(handles.axes4,'Visible','off');
set(handles.axes5,'Visible','off');
set(handles.axes6,'Visible','off');
set(handles.axes7,'Visible','off');
set(handles.axes9,'Visible','off');
set(handles.text9,'Visible','off');
set(handles.text4,'Visible','off');
set(handles.text6,'Visible','off');
set(handles.text7,'Visible','off');
set(handles.text8,'Visible','off');
set(handles.text10,'Visible','off');
set(handles.text11,'Visible','off');
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes mygui wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = mygui_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in load.
function load_Callback(hObject, eventdata, handles)
% hObject    handle to load (see GCBO)
[FileName,PathName] = uigetfile({'*.*'},'Load Image File');
handles.fullpath=[PathName FileName];
if (FileName==0) % cancel pressed
    return;
end
[a, b, Ext] = fileparts(FileName);
availableExt = {'.bmp','.jpg','.jpeg','.tiff','.png','.gif'};
FOUND = 0;
for (i=1:length(availableExt))
    if (strcmpi(Ext, availableExt{i}))
        FOUND=1;
        break;
    end
end
if (FOUND==0)
    h = msgbox('File type not supported!','Error','error');
    return;
end
rgb=imread(handles.fullpath);
imshow(rgb);
axes(handles.axes3); cla;
axes(handles.axes2); cla;
axes(handles.axes5); cla;
handles.rgb = rgb;
set(handles.mean,'String',sprintf('原图的均值:%f  方差:%f',mean2(rgb),std2(rgb)*std2(rgb)));
f1=handles.rgb(:,:,1);
axes(handles.axes4);
imhist(f1);
f2=handles.rgb(:,:,2);
axes(handles.axes6);
imhist(f2);
f3=handles.rgb(:,:,3);
axes(handles.axes7);
imhist(f3);
set(handles.max,'String',sprintf('原图像最大值:%f 最小值:%f\n',max(max(max(rgb))),min(min(min(rgb)))));
set(handles.text4,'Visible','on');
set(handles.text6,'Visible','on');
set(handles.text7,'Visible','on');
set(handles.text8,'Visible','on');
% --- Executes on button press in mean.
function mean_Callback(hObject, eventdata, handles)
% hObject    handle to mean (see GCBO)
% --- Executes during object creation, after setting all properties.
function max_CreateFcn(hObject, eventdata, handles)
% hObject    handle to max (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
Gray=rgb2gray(handles.rgb);
    axes(handles.axes2);%这是用来花在另外一张图上的!
    imshow(Gray);
      imhist(Gray);
      set(handles.text9,'Visible','on');
set(handles.text11,'String',sprintf('改变后图像最大值:%f 最小值:%f\n',max(max(Gray)),min(min(Gray))));
    set(handles.text10,'String',sprintf('改变后均值:%f  方差:%f',mean2(Gray),std2(Gray)*std2(Gray)));
set(handles.text10,'Visible','on');
set(handles.text11,'Visible','on');
% --- Executes on button press in log.
function log_Callback(hObject, eventdata, handles)
% hObject    handle to log (see GCBO)
p=rgb2gray(handles.rgb);
li=log(double(p+1));
imshow(li,[]);
 M=max(li(:));
 m=min(li(:));
 xn=(li-m)./(M-m);
 imhist(xn);
 set(handles.text11,'String',sprintf('改变后图像最大值:%f 最小值:%f\n',max(max(li)),min(min(li))));
    set(handles.text10,'String',sprintf('改变后均值:%f  方差:%f',mean2(li),std2(li)*std2(li)));
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]陈浩,方勇,朱大洲,王成,陈子龙.基于蚁群算法的玉米植株热红外图像边缘检测[J].农机化研究. 2015,37(06)
原文链接:qq912100926.blog.csdn.net/article/details/116198526
