【数字信号】基于matlab GUI手机拨号音效模拟【含Matlab源码 909期】
海神之光 发表于 2022/05/29 03:14:48 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数字信号】基于matlab GUI手机拨号音效模拟【含Matlab源码 909期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
function varargout = tul(varargin)
% TUL MATLAB code for tul.fig
%      TUL, by itself, creates a new TUL or raises the existing
%      singleton*.
%      H = TUL returns the handle to a new TUL or the handle to
%      TUL('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in TUL.M with the given input arguments.
%      TUL('Property','Value',...) creates a new TUL or raises the
%      applied to the GUI before tul_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to tul_OpeningFcn via varargin.
% Edit the above text to modify the response to help tul
% Last Modified by GUIDE v2.5 09-May-2021 18:33:50
gui_Singleton = 1;
                   'gui_OpeningFcn', @tul_OpeningFcn, ...
                   'gui_OutputFcn',  @tul_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before tul is made visible.
function tul_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to tul (see VARARGIN)
% Choose default command line output for tul
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes tul wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = tul_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
n=[1:1000];
d1=sin(0.5343*n)+sin(0.9268*n);
n1=strcat(get(handles.edit1,'string'),'1');
set(handles.edit1,'string',n1);
space=zeros(1,100);
global NUM
phone=[NUM,d1];
NUM=[phone,space];
sound(d1,8192);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
n=[1:1000];
d2=sin(0.5343*n)+sin(1.024*n);
n2=strcat(get(handles.edit1,'string'),'2');
set(handles.edit1,'string',n2);
space=zeros(1,100);
global NUM
phone=[NUM,d2];
NUM=[phone,space];
sound(d2,8192);
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
n=[1:1000];
d3=sin(0.5343*n)+sin(1.1323*n);
n3=strcat(get(handles.edit1,'string'),'3');
set(handles.edit1,'string',n3);
space=zeros(1,100);
global NUM
phone=[NUM,d3];
NUM=[phone,space];
sound(d3,8192);
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
n=[1:1000];
d4=sin(0.59033*n)+sin(0.9268*n);
n4=strcat(get(handles.edit1,'string'),'4');
set(handles.edit1,'string',n4);
space=zeros(1,100);
global NUM
phone=[NUM,d4];
NUM=[phone,space];
sound(d4,8192);
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
n=[1:1000];
d5=sin(0.59033*n)+sin(1.024*n);
n5=strcat(get(handles.edit1,'string'),'5');
set(handles.edit1,'string',n5);
space=zeros(1,100);
global NUM
phone=[NUM,d5];
NUM=[phone,space];
sound(d5,8192);
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
n=[1:1000];
d6=sin(0.59033*n)+sin(1.1323*n);
n6=strcat(get(handles.edit1,'string'),'6');
set(handles.edit1,'string',n6);
space=zeros(1,100);
global NUM
phone=[NUM,d6];
NUM=[phone,space];
sound(d6,8192);
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
n=[1:1000];
d7=sin(0.6531*n)+sin(0.9268*n);
n7=strcat(get(handles.edit1,'string'),'7');
set(handles.edit1,'string',n7);
space=zeros(1,100);
global NUM
phone=[NUM,d7];
NUM=[phone,space];
sound(d7,8192);
% --- Executes on button press in pushbutton8.
function pushbutton8_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton8 (see GCBO)
n=[1:1000];
d8=sin(0.6531*n)+sin(1.024*n);
n8=strcat(get(handles.edit1,'string'),'8');
set(handles.edit1,'string',n8);
space=zeros(1,100);
global NUM
phone=[NUM,d8];
NUM=[phone,space];
sound(d8,8192);
% --- Executes on button press in pushbutton9.
function pushbutton9_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton9 (see GCBO)
n=[1:1000];
d9=sin(0.6531*n)+sin(1.1323*n);
n9=strcat(get(handles.edit1,'string'),'9');
set(handles.edit1,'string',n9);
space=zeros(1,100);
global NUM
phone=[NUM,d9];
NUM=[phone,space];
sound(d9,8192);
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/117152759
