【肌电信号】基于matlab GUI脉搏信号处理系统【含Matlab源码 1062期】
海神之光 发表于 2022/05/29 02:01:49 2022/05/29
【摘要】 一、案例简介 对应的文献链接:基于MATLAB 的脉搏信号处理软件系统 二、部分源代码 function varargout = linbingwen(varargin) % LINBINGWEN ...
一、案例简介
二、部分源代码
% LINBINGWEN M-file for linbingwen.fig
%      LINBINGWEN, by itself, creates a new LINBINGWEN or raises the existing
%      singleton*.
%      H = LINBINGWEN returns the handle to a new LINBINGWEN or the handle to
%      LINBINGWEN('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in LINBINGWEN.M with the given input arguments.
%      LINBINGWEN('Property','Value',...) creates a new LINBINGWEN or raises the
%      applied to the GUI before linbingwen_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to linbingwen_OpeningFcn via varargin.
% Edit the above text to modify the response to help linbingwen
% Last Modified by GUIDE v2.5 27-Jun-2021 16:54:46
gui_Singleton = 1;
                   'gui_OpeningFcn', @linbingwen_OpeningFcn, ...
                   'gui_OutputFcn',  @linbingwen_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before linbingwen is made visible.
function linbingwen_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to linbingwen (see VARARGIN)
% Choose default command line output for linbingwen
handles.output = hObject;
t = timer('tag', 'timer1', 'BusyMode', 'queue', 'ExecutionMode', ...
    'fixedrate', 'Period', 1, 'timerfcn', {@t_update, handles});
start(t);
% Update handles structure
% UIWAIT makes linbingwen wait for user response (see UIRESUME)
% uiwait(handles.figure1);
movegui( handles.figure1, 'center' );
set(handles.pushbutton1,'enable','off');%下面几条指令是不启动其余按钮功能
set(handles.pushbutton2,'enable','off');
set(handles.pushbutton7,'enable','off');
set(handles.pushbutton8,'enable','off');
set(handles.pushbutton14,'enable','off');
set(handles.pushbutton9,'enable','off');
set(handles.pushbutton10,'enable','off');
set(handles.pushbutton11,'enable','off');
set(handles.pushbutton17,'enable','off');
set(handles.pushbutton18,'enable','off');
set(handles.pushbutton19,'enable','off');
set(handles.pushbutton20,'enable','off');
set(handles.pushbutton15,'enable','off');
set(handles.pushbutton16,'enable','off');
set(handles.pushbutton21,'enable','off');
set(handles.pushbutton22,'enable','off');
set(handles.pushbutton23,'enable','off');
set(handles.pushbutton24,'enable','off');
axes(handles.axes1);
P = plot(5*ones(1000,1));grid on;
axis([0,1,-2,4])
axes(handles.axes2);
axis([0,1,-2,4])
guidata(hObject, handles);
function t_update(obj,eventdata,handles)
if ~isfield(handles, 'figure1')
    return
end
st1 = datestr(now, 'yyyy-mm-dd');
st2 = datestr(now, 'HH:MM:SS');
set(handles.activex5, 'AlphaNumeric', st2)
set(handles.activex4, 'AlphaNumeric', st1)
function varargout = linbingwen_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function axes1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to axes1 (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: place code in OpeningFcn to populate axes1
set(hObject,'xTick',[]);%设置窗口axes3的外观属性,XY轴无标签。
set(hObject,'ytick',[]);
set(hObject,'box','on');%打开窗口
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
set(handles.pushbutton2,'enable','on');
set(handles.pushbutton5,'enable','off');
set(handles.pushbutton6,'enable','off');
set(handles.pushbutton15,'enable','on');
set(handles.pushbutton16,'enable','on');
set(handles.pushbutton17,'enable','on');
set(handles.pushbutton18,'enable','on');
set(handles.pushbutton19,'enable','on');
set(handles.pushbutton20,'enable','on');
set(handles.pushbutton21,'enable','on');
set(handles.pushbutton22,'enable','on');
global str
global t
global maibo
global ymin
global ymax
global xmin
global xmax
global pauset
pauset=0.5;
data=load(str);
t=data(:,1);maibo=data(:,2);
ymin=min(data(:,2))-0.5;
ymax=max(data(:,2))+0.5;
global s21
global dt
yy=data;
x=yy(:,2)';
dt=yy(:,1)';
fs=800;
%%去除基线漂移
k = .7; % cut-off value
fc=0.3/fs;
alpha = (1-k*cos(2*pi*fc)-sqrt(2*k*(1-cos(2*pi*fc))-k^2*sin(2*pi*fc)^2))/(1-k);
y = zeros(size(x));
for i = 1:size(x,1)
   y(1,:) = filtfilt(1-alpha,[1 -alpha],x(1,:));
end
x1=x-y;
%%butter带通滤波
Wp=[0.9 50]/400;Ws=[0.3 140]/400;
[n,Wn] = buttord(Wp,Ws,3,10);
[b,a] = butter(n,Wn);
%%cheby去除50hz工频干扰
Wp1=[30 65]/400;Ws1=[45 55]/400;
rp=3;rs=60;
[n1,Wn1] = cheb2ord(Wp1,Ws1,rp,rs);
[b1,a1] = cheby2(n1,rs,Wn1,'stop');
%%信号之间的对比
x2=filtfilt(b,a,x1);
s21=filtfilt(b1,a1,x2);
plot(t,maibo);
title('原始脉搏信号');
xlabel('时间/s');
ylabel('幅值/mv');
grid
set(gca,'position',[10 27.5 120 20]);
xmin=0;
xmax=max(t)/10;
axis([xmin,xmax,ymin,ymax])
plot(dt,s21);grid;
title('滤波去噪后脉搏信号');
xlabel('时间/s');
ylabel('幅值/mv');
set(gca,'position',[10 3 120 20]);
global flg1
flg1=1;
while 1
    if (flg1==0)
        break;
    end
    xmin=xmin+0.1;
    xmax=xmax+0.1;
plot(t,maibo);
title('原始脉搏信号');
xlabel('时间/s');
ylabel('幅值/mv');
grid
    axis([xmin,xmax,ymin,ymax]); %移动坐标系
plot(dt,s21);grid;
title('滤波去噪后脉搏信号');
xlabel('时间/s');
ylabel('幅值/mv');
    pause(pauset);
end
guidata(hObject,handles);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
set(handles.pushbutton5,'enable','on');
set(handles.pushbutton6,'enable','on');
set(handles.pushbutton10,'enable','on');
set(handles.pushbutton11,'enable','on');
set(handles.pushbutton7,'enable','on');
global flg1
flg1=0;
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/118276633
