【气动学】基于matlab GUI改进的遗传算法和高斯烟羽模型模拟气体扩散【含Matlab源码 1060期】
海神之光 发表于 2022/05/29 02:21:17 2022/05/29
【摘要】 零、完整代码CSDN下载链接 【气动学】基于matlab GUI改进的遗传算法和高斯烟羽模型模拟气体扩散【含Matlab源码 1060期】 一、高斯烟羽模型简介 1 高斯羽烟模型方程 式中c为污染...
零、完整代码CSDN下载链接
一、高斯烟羽模型简介
1 高斯羽烟模型方程
式中c为污染物浓度(单位:kg/m3)
Q为源强(单位:kg/s)
u为泄漏高度的平均风速(单位:m/s)
y、z分别用浓度标准偏差表示的y轴及z轴上的扩散参数
H为泄漏有效高度(单位:m)
2 扩散系数系数
二、源代码
function varargout = mGA_new(varargin)
% MGA_NEW MATLAB code for mGA_new.fig
%      MGA_NEW, by itself, creates a new MGA_NEW or raises the existing
%      singleton*.
%      H = MGA_NEW returns the handle to a new MGA_NEW or the handle to
%      MGA_NEW('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MGA_NEW.M with the given input arguments.
%      MGA_NEW('Property','Value',...) creates a new MGA_NEW or raises the
%      applied to the GUI before mGA_new_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to mGA_new_OpeningFcn via varargin.
% Edit the above text to modify the response to help mGA_new
% Last Modified by GUIDE v2.5 04-Jul-2020 16:21:23
gui_Singleton = 1;
                   'gui_OpeningFcn', @mGA_new_OpeningFcn, ...
                   'gui_OutputFcn',  @mGA_new_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before mGA_new is made visible.
function mGA_new_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to mGA_new (see VARARGIN)
% Choose default command line output for mGA_new
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes mGA_new wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = mGA_new_OutputFcn(hObject, eventdata, handles)
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function feng_Callback(hObject, eventdata, handles)
% hObject    handle to feng (see GCBO)
% Hints: get(hObject,'String') returns contents of feng as text
%        str2double(get(hObject,'String')) returns contents of feng as a double
function feng_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
function gaodu_Callback(hObject, eventdata, handles)
% hObject    handle to gaodu (see GCBO)
% Hints: get(hObject,'String') returns contents of gaodu as text
%        str2double(get(hObject,'String')) returns contents of gaodu as a double
function gaodu_CreateFcn(hObject, eventdata, handles)
end
% --- Executes on button press in jiancedian.
function jiancedian_Callback(hObject, eventdata, handles)
% hObject    handle to jiancedian (see GCBO)
[filename,pathname]=uigetfile({'*xls;*.xlsx'},'读入测量数据文件');%加载路径的选择
fpath=[pathname,filename];%总的路径
data=xlsread(fpath);%读测量文件
set(handles.guance,'data',data);%写入到表中
setappdata(handles.jiancedian,'data',data);
% --- Executes on button press in fansuan.
function fansuan_Callback(hObject, eventdata, handles)
% hObject    handle to fansuan (see GCBO)
 %% 获取参数
% diedai=str2double(get(handles.deidai,'String'));% 进化次数
val=get(handles.popupmenu1,'value'); %这是获取当前选项的位置,从上到下是1,2,3...
str=get(handles.popupmenu1,'string');
W=str{val}; %这个将返回当前选项的内容,若是纯数字用str2num(str(val))
popsize=100; %种群规模
lenchrom=3;%变量字串长度
maxgen=str2double(get(handles.diedai,'String'));% 进化次数
% maxgen=1000;% 进化次数
popmax=500;% 种群最大值
popmin=-500;% 种群最小值
u1=str2double(get(handles.feng,'String'));
hr=str2double(get(handles.gaodu,'String'));
% % z1=str2double(get(handles.edit3,'String'));
% z1=0;
% Q=str2double(get(handles.edit8,'String'));
dt=getappdata(handles.jiancedian,'data');
d=dt(:,:);
% mGA.data(:,1)=dt(:,2);
% mGA.data(:,2)=dt(:,3);
% % z1=dt(:,3);
% % set(handles.uitable2,'data',data);
%% 开始
bound=[0 20000;popmin popmax;popmin popmax];  %变量范围
for i=1:popsize
    %随机产生一个种群
    GApop(i,:)=Code(lenchrom,bound);       %随机产生个体
%     GApop(i,:)=mGA.data(i,:);
    %计算适应度
    fitvalue(i)=fitness(GApop(i,:),u1,hr,d,W);            %染色体的适应度
end
% set(handles.uitable2,'data',fitvalue);
%% 找最好的染色体
[bestfitness,bestindex]=min(fitvalue);
xm=GApop(bestindex,:);   %全局最佳
gbest=GApop;                %体最佳
fitnessgbest=fitvalue;       %个体最佳适应度值
xv=bestfitness;   %全局最佳适应度值
% % set(handles.uitable2,'data',xv);
%% 迭代寻优
for i=1:maxgen
        %种群更新 GA选择更新
        GApop=Select(GApop,fitvalue,popsize); % 其中Select为选择算子函数
        % 交叉操作 GA
        pc=i/maxgen; % maxgen  进化次数
        GApop=Cross(pc,lenchrom,GApop,popsize,bound); % 其中Cross为交叉算子函数
        % 变异操作 GA变异
        pm=i/maxgen;
        GApop=Mutation(pm,lenchrom,GApop,popsize,[i maxgen],bound);
        pop=GApop;
      for j=1:popsize
        %适应度值即变量约束条件
        if 1*pop(j,1)+0*pop(j,2)+0*pop(j,3)<=20000 && 1*pop(j,1)+0*pop(j,2)+0*pop(j,3)>=0
            if 0*pop(j,1)+1*pop(j,2)+0*pop(j,3)<=500 && 0*pop(j,1)+1*pop(j,2)+0*pop(j,3)>=-500
               if 0*pop(j,1)+0*pop(j,2)+1*pop(j,3)<=500 && 0*pop(j,1)+0*pop(j,2)+1*pop(j,3)>=-500
                    fitvalue(j)=fitness(pop(j,:),u1,hr,d,W);
               end
            end
        end
        %个体最优更新
        if fitvalue(j) < fitnessgbest(j)
            gbest(j,:) = pop(j,:);
            fitnessgbest(j) = fitvalue(j);
        end
        %群体最优更新
        if fitvalue(j) < xv
            xm = pop(j,:);
            xv = fitvalue(j);
        end
      end
       QQ(i)=xm(:,1);
       x(i)=xm(:,2);
       y(i)=xm(:,3);
       v(i)=xv;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 门云阁.MATLAB物理计算与可视化[M].清华大学出版社,2013.
原文链接:qq912100926.blog.csdn.net/article/details/118268871
