【优化算法】鸽群优化算法(PIO)【含Matlab源码 1077期】
海神之光 发表于 2022/05/29 01:59:42 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【优化算法】鸽群优化算法(PIO)【含Matlab源码 1077期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%_________________________________________________________________________%
% 鸽群优化算法             %
% 使用方法
% fobj = @YourCostFunction        设定适应度函数
% dim = number of your variables   设定维度
% Max_iteration = maximum number of generations 设定最大迭代次数
% SearchAgents_no = number of search agents   种群数量
% lb=[lb1,lb2,...,lbn] where lbn is the lower bound of variable n  变量下边界
% ub=[ub1,ub2,...,ubn] where ubn is the upper bound of variable n   变量上边界
% If all the variables have equal lower bound you can just
% define lb and ub as two single number numbers
% To run PIO: [Best_pos,Best_score,curve]=PIO(pop,Max_iter,lb,ub,dim,fobj)
clear all
clc
% rng('default');
SearchAgents_no=50; % Number of search agents 种群数量
Function_name='F9'; % Name of the test function that can be from F1 to F23 (Table 1,2,3 in the paper) 设定适应度函数
Max_iteration=1000; % Maximum numbef of iterations 设定最大迭代次数
% Load details of the selected benchmark function
[lb,ub,dim,fobj]=Get_Functions_details(Function_name);  %设定边界以及优化函数
[Best_score,Best_pos,PIO_curve]=PIO(SearchAgents_no,Max_iteration,lb,ub,dim,fobj); %开始优化
% This function containts full information and implementations of the benchmark
% lb is the lower bound: lb=[lb_1,lb_2,...,lb_d]
% up is the uppper bound: ub=[ub_1,ub_2,...,ub_d]
% dim is the number of variables (dimension of the problem)
function [lb,ub,dim,fobj] = Get_Functions_details(F)
switch F
    case 'F1'
        fobj = @F1;
        lb=-100;
        ub=100;
        dim=30;
    case 'F2'
        fobj = @F2;
        lb=-10;
        ub=10;
        dim=30;
    case 'F3'
        fobj = @F3;
        lb=-100;
        ub=100;
        dim=30;
    case 'F4'
        fobj = @F4;
        lb=-100;
        ub=100;
        dim=30;
    case 'F5'
        fobj = @F5;
        lb=-30;
        ub=30;
        dim=30;
    case 'F6'
        fobj = @F6;
        lb=-100;
        ub=100;
        dim=30;
    case 'F7'
        fobj = @F7;
        lb=-1.28;
        ub=1.28;
        dim=30;
    case 'F8'
        fobj = @F8;
        lb=-500;
        ub=500;
        dim=30;
    case 'F9'
        fobj = @F9;
        lb=-5.12;
        ub=5.12;
        dim=30;
    case 'F10'
        fobj = @F10;
        lb=-32;
        ub=32;
        dim=30;
    case 'F11'
        fobj = @F11;
        lb=-600;
        ub=600;
        dim=30;
    case 'F12'
        fobj = @F12;
        lb=-50;
        ub=50;
        dim=30;
    case 'F13'
        fobj = @F13;
        lb=-50;
        ub=50;
        dim=30;
    case 'F14'
        fobj = @F14;
        lb=-65.536;
        ub=65.536;
        dim=2;
    case 'F15'
        fobj = @F15;
        lb=-5;
        ub=5;
        dim=4;
    case 'F16'
        fobj = @F16;
        lb=-5;
        ub=5;
        dim=2;
    case 'F17'
        fobj = @F17;
        lb=[-5,0];
        ub=[10,15];
        dim=2;
    case 'F18'
        fobj = @F18;
        lb=-2;
        ub=2;
        dim=2;
    case 'F19'
        fobj = @F19;
        lb=0;
        ub=1;
        dim=3;
    case 'F20'
        fobj = @F20;
        lb=0;
        ub=1;
        dim=6;
    case 'F21'
        fobj = @F21;
        lb=0;
        ub=10;
        dim=4;
    case 'F22'
        fobj = @F22;
        lb=0;
        ub=10;
        dim=4;
    case 'F23'
        fobj = @F23;
        lb=0;
        ub=10;
        dim=4;
end
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/118421976
