【心电信号】基于matlab GUI心电信号预处理【含Matlab源码 938期】
海神之光 发表于 2022/05/29 03:21:17 2022/05/29
【摘要】 一、心电信号预处理方法简介 理论知识参考文献:心电信号预处理方法研究 二、部分源代码 function varargout = kaishi(varargin) gui_Singleton = 1...
一、心电信号预处理方法简介
二、部分源代码
gui_Singleton = 1;
                   'gui_OpeningFcn', @kaishi_OpeningFcn, ...
                   'gui_OutputFcn',  @kaishi_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
    gui_mainfcn(gui_State, varargin{:});
end
% --- Executes just before kaishi is made visible.
function kaishi_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to kaishi (see VARARGIN)
% Choose default command line output for kaishi
%handles.output = hObject;
ha=axes('units','normalized','position',[0 0 1 1]);
colormap gray
set(ha,'handlevisibility','off','visible','off');
% Update handles structure
global  xd;
handles.output = xd;
guidata(hObject, handles);
% UIWAIT makes kaishi wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = kaishi_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in xhxz.
function xhxz_Callback(hObject, eventdata, handles)
% hObject    handle to xhxz (see GCBO)
global m;
global xd;
global a;
global n;
n=25000;
[filename, pathname,index] = uigetfile('*.txt', '请选择信号');
m=index;
if isequal(filename,0)
    f = errordlg('没有选择有效信号', '注意!', 'modal');
else
f1=importdata(filename);
plot(xd);
title('选取的心电信号');
end
% --- Executes on button press in exit_1.
function exit_1_Callback(hObject, eventdata, handles)
% hObject    handle to exit_1 (see GCBO)
 close(gcf);
% --- Executes during object creation, after setting all properties.
function figure1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to figure1 (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on button press in FD.
function FD_Callback(hObject, eventdata, handles)
% hObject    handle to FD (see GCBO)
%xd=a(13000:5:25000);
%plot(xd);
% --- Executes on button press in SX.
function SX_Callback(hObject, eventdata, handles)
% hObject    handle to SX (see GCBO)
% --- Executes on button press in pushbutton5.
function pushbutton5_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton5 (see GCBO)
global m;
    XZLB;
else
     f0 = errordlg('没有选择有效信号', '注意!', 'modal');
end
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
function edit1_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in pushbutton6.
function pushbutton6_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton6 (see GCBO)
% --- Executes on button press in pushbutton7.
function pushbutton7_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton7 (see GCBO)
 close(gcf);
    JGXS;
% --- Executes on button press in FD1.
function FD1_Callback(hObject, eventdata, handles)
% hObject    handle to FD1 (see GCBO)
global xd;
global a;
global n;
global c;
if n>15000
   n=n-2000;
else
    n=n;
end
gui_Singleton = 1;
                   'gui_OpeningFcn', @XBQZCS_OpeningFcn, ...
                   'gui_OutputFcn',  @XBQZCS_OutputFcn, ...
end
if nargout
else
end
% --- Executes just before XBQZCS is made visible.
function XBQZCS_OpeningFcn(hObject, eventdata, handles, varargin)
% varargin   command line arguments to XBQZCS (see VARARGIN)
% Choose default command line output for XBQZCS
uistack(ha,'down')
II=imread('aa6.jpg');%里面的参数可以是你自己的图片,把名字连同格式写进去就可以了
image(II)
colormap gray
% UIWAIT makes XBQZCS wait for user response (see UIRESUME)
function varargout = XBQZCS_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in goon_2.
function goon_2_Callback(hObject, eventdata, handles)
% hObject    handle to goon_2 (see GCBO)
 close(gcf);
    JGXS;
% --- Executes on button press in exit_5.
function exit_5_Callback(hObject, eventdata, handles)
% hObject    handle to exit_5 (see GCBO)
 close(gcf);
    XZLB;
% --- Executes when selected object is changed in uipanel3.
function uipanel3_SelectionChangeFcn(hObject, eventdata, handles)
% hObject    handle to the selected object in uipanel3
% eventdata  structure with the following fields (see UIBUTTONGROUP)
%	EventName: string 'SelectionChanged' (read only)
%	OldValue: handle of the previously selected object or empty if none was selected
%	NewValue: handle of the currently selected object
global xd;
global Y1;
tString=get(hObject,'tag');
switch tString
    case 'sym_4'
      Y1=wden(xd,'heursure','s','one',3,'sym4');   %进行相应的操作
    case 'sym_6'
      Y1=wden(xd,'heursure','s','one',3,'sym6');%进行相应的操作
    case 'sym_8'
       Y1=wden(xd,'heursure','s','one',3,'sym8');%进行相应的操作
    case 'sym_10'
      Y1=wden(xd,'heursure','s','one',3,'sym10'); %进行相应的操作
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
  • 215
  • 216
  • 217
  • 218
  • 219
  • 220
  • 221
  • 222
  • 223
  • 224
  • 225
  • 226
  • 227
  • 228
  • 229
  • 230
  • 231
  • 232
  • 233
  • 234
  • 235
  • 236
  • 237
  • 238
  • 239
  • 240
  • 241
  • 242
  • 243
  • 244
  • 245
  • 246
  • 247
  • 248
  • 249
  • 250
  • 251
  • 252
  • 253
  • 254
  • 255
  • 256
  • 257
  • 258
  • 259
  • 260
  • 261
  • 262
  • 263
  • 264
  • 265
  • 266
  • 267
  • 268
  • 269
  • 270
  • 271
  • 272
  • 273
  • 274
  • 275
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
[4]王旭,钱伟,余宇帆.心电信号预处理方法研究[J].中国医学工程. 2018,26(12)
原文链接:qq912100926.blog.csdn.net/article/details/117340592
