【优化算法】飞蛾优化算法 (MFO)【含Matlab源码 1081期】
海神之光 发表于 2022/05/29 01:43:12 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【优化算法】飞蛾优化算法 (MFO)【含Matlab源码 1081期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
clear all
clc
SearchAgents_no=30;
Function_name='F1';
Max_iteration=1000;
[lb,ub,dim,fobj]=Get_Functions_details(Function_name);
[Best_score,Best_pos,cg_curve]=MFO(SearchAgents_no,Max_iteration,lb,ub,dim,fobj);
figure('Position',[284 214 660 290])
subplot(1,2,1);
func_plot(Function_name);
title('Test function')
xlabel('x_1');
ylabel('x_2');
zlabel([Function_name,'(x_1,x_2)'])
function [lb,ub,dim,fobj] = Get_Functions_details(F)
switch F
    case 'F1'
        fobj=@F1;
        lb=-100;
        ub=100;
        dim=30;
    case 'F2'
    fobj=@F2;
    lb=-100;
    ub=100;
    dim=30;
    case 'F3'
    fobj=@F3;
    lb=-100;
    ub=100;
    dim=30;
    case 'F4'
    fobj=@F4;
    lb=-100;
    ub=100;
    dim=30;
    case 'F5'
    fobj=@F5;
    lb=-30;
    ub=30;
    dim=30;
    case 'F6'
    fobj=@F6;
    lb=-100;
    ub=100;
    dim=30;
    case 'F7'
    fobj=@F7;
    lb=-1.28;
    ub=1.28;
    dim=30;
    case 'F8'
    fobj=@F8;
    lb=-500;
    ub=500;
    dim=30;
    case 'F9'
    fobj=@F9;
    lb=-5.12;
    ub=5.12;
    dim=30;
    case 'F10'
    fobj=@F10;
    lb=-32;
    ub=32;
    dim=30;
    case 'F11'
    fobj=@F11;
    lb=-600;
    ub=600;
    dim=30;
    case 'F12'
    fobj=@F12;
    lb=-50;
    ub=50;
    dim=30;
    case 'F13'
    fobj=@F13;
    lb=-50;
    ub=50;
    dim=30;
    case 'F14'
    fobj=@F14;
    lb=-65.536;
    ub=65.536;
    dim=2;
    case 'F15'
    fobj=@F15;
    lb=-5;
    ub=5;
    dim=4;
    case 'F16'
    fobj=@F16;
    lb=-5;
    ub=5;
    dim=2;
    case 'F17'
    fobj=@F17;
    lb=[-5,0];
    ub=[10,15];
    dim=2;
    case 'F18'
    fobj=@F18;
    lb=-2;
    ub=2;
    dim=2;
    case 'F19'
    fobj=@F19;
    lb=0;
    ub=1;
    dim=3;
    case 'F20'
    fobj=@F20;
    lb=0;
    ub=1;
    dim=6;
    case 'F21'
    fobj=@F21;
    lb=0;
    ub=10;
    dim=4;
    case 'F22'
    fobj=@F22;
    lb=0;
    ub=10;
    dim=4;
    case 'F23'
    fobj=@F23;
    lb=0;
    ub=10;
    dim=4;
end
end
function o = F1(x)
o = sum(x.^2);
end
function o = F2(x)
    o=sum(abs(x))+prod(abs(x));
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 包子阳,余继周,杨杉.智能优化算法及其MATLAB实例(第2版)[M].电子工业出版社,2016.
[2]张岩,吴水根.MATLAB优化算法源代码[M].清华大学出版社,2017.
原文链接:qq912100926.blog.csdn.net/article/details/118437166
