【数字信号处理】基于matlab GUI频谱分析仪【含Matlab源码 932期】
海神之光 发表于 2022/05/29 03:06:39 2022/05/29
【摘要】 一、数字信号处理系统简介 理论知识参考文献:基于GUI的《数字信号处理》教学演示系统的设计 基于Matlab GUI界面的数字信号处理辅助教学系统 基于MATLAB的数字信号处理实验平台 二、部分源代...
一、数字信号处理系统简介
基于MATLAB的数字信号处理实验平台
二、部分源代码
unction varargout = ch4(varargin)
gui_Singleton = 1;
                   'gui_OpeningFcn', @ch4_OpeningFcn, ...
                   'gui_OutputFcn',  @ch4_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before ch4 is made visible.
function ch4_OpeningFcn(hObject, eventdata, handles, varargin)        %界面打开载入信息
% hObject    handle to figure
% varargin   command line arguments to ch4 (see VARARGIN)
% Choose default command line output for ch4
handles.inputtype=0;
xlabel(handles.plot1,'freqency(Hz)');
xlabel(handles.plot2,'freqency(Hz)');
xlabel(handles.plot3,'freqency(Hz)');
xlabel(handles.plot4,'freqency(Hz)');
xlabel(handles.plot5,'freqency(Hz)');
ylabel(handles.plot1,'amplitude');
ylabel(handles.plot2,'phase(rad)');
ylabel(handles.plot3,'real');
ylabel(handles.plot4,'Imaginary');
ylabel(handles.plot5,'power');
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);            %更新数据
% UIWAIT makes ch4 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = ch4_OutputFcn(hObject, eventdata, handles)
% --- Executes during object creation, after setting all properties.
function figure1_CreateFcn(hObject, eventdata, handles)
% hObject    handle to figure1 (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% --- Executes on button press in timeanalyse.
function timeanalyse_Callback(hObject, eventdata, handles)            %时域分析Callback
% hObject    handle to timeanalyse (see GCBO)
Fs=str2double(get(findobj('Tag','samplerate'),'String'));      %获得界面采样频率数值
N=str2double(get(findobj('Tag','samplenum'),'String'));        %获得界面采样点数数值
if handles.inputtype==0                                        %handles.inputtype记录输入方式  0(默认)为当前无输入;1为声卡录音方式;2为打开文件方式;3为信号生成方式
        msgbox('No wave exist! Please choose a input type!');
        return;
end
%过 零 监 测
n=1;
ymax=max([handles.y(1) handles.y(2)]);
ymin=min([handles.y(1) handles.y(2)]);
from=str2double(get(handles.pointfrom,'String'));
to=str2double(get(handles.pointto,'String'));
if from<1 | to-from<5;            %计算区间过小判定
    msgbox('Error range!');
    return;
end
for i=from+2:to-1;
    if handles.y(i-1)<0 & handles.y(i-2)<0 & handles.y(i)>=0 & handles.y(i+1)>0
        if handles.y(i)==0             %若y(i)为0,直接得到零点序号
            ti(n)=i;
        else
            ti(n)=i-handles.y(i)/(handles.y(i)-handles.y(i-1));   %线性内插得到零点序号
%             x1=i-1;
%             y1=handles.y(i-1);
%             x2=i;
%             y2=handles.y(i);
%             a=handles.y(i)-handles.y(i-1);
%             b=a*x1-y1;
%             ti(n)=b/a;
        end
        amp(n)=(ymax-ymin)/2;
        ymax=0;
        ymin=0;
        n=n+1;
    else
        if ymax<handles.y(i)
            ymax=handles.y(i);
        end
        if ymin>handles.y(i)
            ymin=handles.y(i);
        end
    end
end
n=n-1;
%freqence and periodicity
for i=1:n-1
    T(i)=ti(i+1)-ti(i);
end
freq=Fs/mean(T);
set(handles.outt,'String',1/freq);                                                   %返回信号周期估计
set(handles.outfreq,'String',num2str(freq));                                         %返回信号频率估计
%amplitude
set(handles.outamp,'String',num2str(mean(amp(2:n-1))));                              %返回信号幅值估计
%phase
phase=2*pi*(1-(ti(1:n-1)-1)./T+floor((ti(1:n-1)-1)./T));
set(handles.outphase,'String',num2str(mean(phase)));                                 %返回信号相位估计
%peak
set(handles.outpeak,'String',(max(handles.y(from:to))-min(handles.y(from:to)))/2);   %返回信号峰值估计
%mean
set(handles.outmean,'String',mean(handles.y(from:to)));                              %返回信号均值估计
%meansquare
set(handles.outmeansquare,'String',mean(handles.y(from:to).^2));                     %返回信号均方差估计
%s
set(handles.outs,'String',(std(handles.y(from:to)))^2);                              %返回信号方差估计
function filename_Callback(hObject, eventdata, handles)
% hObject    handle to filename (see GCBO)
% Hints: get(hObject,'String') returns contents of filename as text
%        str2double(get(hObject,'String')) returns contents of filename as a double
function filename_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function freq_Callback(hObject, eventdata, handles)
% hObject    handle to freq (see GCBO)
% Hints: get(hObject,'String') returns contents of freq as text
%        str2double(get(hObject,'String')) returns contents of freq as a double
function freq_CreateFcn(hObject, eventdata, handles)
if ispc
else
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
[4]高彦彦,张晶,李莉,贾英茜.基于GUI的《数字信号处理》教学演示系统的设计[J].教育教学论坛. 2019,(48)
[5]李俊,张淑玲,帅晶.基于Matlab GUI界面的数字信号处理辅助教学系统[J].信息通信. 2020,(08)
[6]朱御康.基于MATLAB的数字信号处理实验平台[J].通信电源技术. 2021,38(03)
原文链接:qq912100926.blog.csdn.net/article/details/117253874
