【图像隐写】基于matlab GUI DWT+SVD数字水印 【含Matlab源码 939期】
海神之光 发表于 2022/05/29 02:09:30 2022/05/29
【摘要】 一、DWT+SVD数字水印简介 理论知识参考文献:基于DWT和SVD的彩色图像数字水印算法研究 一种基于DWT-SVD的图像数字水印算法 二、部分源代码 function varargout = m...
一、DWT+SVD数字水印简介
二、部分源代码
function varargout = main(varargin)
gui_Singleton = 1;
                   'gui_OpeningFcn', @main_OpeningFcn, ...
                   'gui_OutputFcn',  @main_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
if nargin & isstr(varargin{1})
end
if nargout
else
end
function main_OpeningFcn(hObject, eventdata, handles, varargin)
handles.output = hObject;
guidata(hObject, handles);
function varargout = main_OutputFcn(hObject, eventdata, handles)
function axes1_ButtonDownFcn(hObject, eventdata, handles)
function popupmenu1_CreateFcn(hObject, eventdata, handles)
if ispc
    set(hObject,'BackgroundColor','white');
else
    set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
function pushbutton1_Callback(hObject, eventdata, handles)
f1=uigetfile('*.bmp','打开载体图像');
global cover_object;
cover_object=imread(f1);
axes(handles.axes1);
imshow(cover_object);
title('载体图像');
function pushbutton3_Callback(hObject, eventdata, handles)
f2=uigetfile('*.jpg','打开原始水印图像');
global watermark;
watermark=imread(f2);
watermark=im2bw(watermark);
axes(handles.axes4);
imshow(watermark);
title('水印图像');
function pushbutton2_Callback(hObject, eventdata, handles)
global watermark;
global watermark_en;
Mm=size(watermark,1);
Nm=size(watermark,2);
N=Mm*Nm;
key=0.2345;
m(1)=key;
for i=1:N-1
    m(i+1)=4*m(i)-4*m(i)^2;
end
m=mod(1000*m,256);
m=uint8(m);m=im2bw(m);
n=1;
for i=1:Mm
    for j=1:Nm
        watermark_en(i,j)=bitxor(m(n),watermark(i,j));
        n=n+1;
    end
end
axes(handles.axes6);
imshow(watermark_en);
title('加密水印');
function pushbutton4_Callback(hObject, eventdata, handles)
global cover_object watermark_en CWI Temp;
[mm,nn]=size(cover_object);
[mm1,nn1]=size(watermark_en);
[LL HL LH HH]=dwt2(cover_object,'haar');
[U,S,V]=svd(LL);
af=0.03;
[lm,ln]=size(LL);
WW=zeros(lm,ln);
for i=1:mm1
    for j=1:nn1
            WW(i,j)=watermark_en(i,j);
    end
end
Temp=S+af*WW;
[U1,S1,V1]=svd(Temp);
CW=U*S1*V';
I1=idwt2(CW,HL,LH,HH,'haar');
CWI=uint8(I1);
axes(handles.axes2);
imshow(CWI);
title('含水印信息的载体图像');
global CWI;
global Temp;
function pushbutton8_Callback(hObject, eventdata, handles)
global CWI;
global attackf;
f=CWI;
attackd=get(handles.popupmenu1,'Value');
while attackd~=0
switch attackd
    case 1,
    attackf=f;
    att='未攻击';
break;
  case 2,
f(20:180,20:180)=256;
attackf=f;
att='剪切图像';
break;
  case 3,
attackf=imadjust(f,[],[0.4,1]);
att='图像增亮';
break;
case 4,
attackf=imadjust(f,[],[0,0.95]);
att='图像变暗';
break;
case 5,
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
[5]梁欣.基于DWT和SVD的彩色图像数字水印算法研究[J].计算机与数字工程. 2019,47(08)
[6]张秀娟,朱春伟.一种基于DWT-SVD的图像数字水印算法[J].数字技术与应用. 2017,(10)
原文链接:qq912100926.blog.csdn.net/article/details/117355392
