【心电信号】基于matlab心电信号采集与处理【含Matlab源码 954期】
海神之光 发表于 2022/05/29 03:23:50 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【心电信号】基于matlab心电信号采集与处理【含Matlab源码 954期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭证,...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、心电信号采集与处理简介
理论知识参考文献:心电信号采集及小波分析处理系统设计
三、部分源代码
function varargout = GUI_ECG(varargin)
%GUI_ECG M-file for GUI_ECG.fig
%      GUI_ECG, by itself, creates a new GUI_ECG or raises the existing
%      singleton*.
%      H = GUI_ECG returns the handle to a new GUI_ECG or the handle to
%      GUI_ECG('Property','Value',...) creates a new GUI_ECG using the
%      given property value pairs. Unrecognized properties are passed via
%      varargin to GUI_ECG_OpeningFcn.  This calling syntax produces a
%      warning when there is an existing singleton*.
%      GUI_ECG('CALLBACK') and GUI_ECG('CALLBACK',hObject,...) call the
%      local function named CALLBACK in GUI_ECG.M with the given input
%      arguments.
% Edit the above text to modify the response to help GUI_ECG
% Last Modified by GUIDE v2.5 10-May-2021 16:17:00
gui_Singleton = 1;
                   'gui_OpeningFcn', @GUI_ECG_OpeningFcn, ...
                   'gui_OutputFcn',  @GUI_ECG_OutputFcn, ...
                   'gui_LayoutFcn',  [], ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before GUI_ECG is made visible.
function GUI_ECG_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   unrecognized PropertyName/PropertyValue pairs from the
%            command line (see VARARGIN)
% Choose default command line output for GUI_ECG
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes GUI_ECG wait for user response (see UIRESUME)
% uiwait(handles.figure1);
set(handles.COM_State,'string','COM closed');
global valys;
global valxs;
global scom;
global ECG;
valys=1;
valxs=0;
ECG=[];
try
    scoms=instrfind;
    fclose(scoms);
end
function varargout = GUI_ECG_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in OpenCOM.
function OpenCOM_Callback(hObject, eventdata, handles)
% hObject    handle to OpenCOM (see GCBO)
% sprintf('%d',get(hObject,'value'))
% Open COM
global scom;
if get(hObject,'value')
    port=get(handles.Port,'value');
    portstr=['COM',num2str(port)];
    scom=serial(portstr);
    scom.OutputBufferSize=4;
    scom.InputBufferSize=27*2048;
    set(scom,'BaudRate',256000,'Parity','none','DataBits',8,'StopBits',1);
    try
        fopen(scom);
        set(hObject,'String','Close COM');
        set(handles.COM_State,'string',['COM',num2str(port),' ', 'Open']);
    catch
        msgbox('Port Unavailable');
        set(hObject,'value',0);
        return;
    end
% Close COM
else
set(handles.COM_State,'string','COMs closed');
set(hObject,'String','Open COM');
scoms=instrfind;
stopasync(scoms);
fclose(scoms);
delete(scoms);
end
% --- Executes during object creation, after setting all properties.
function Port_CreateFcn(hObject, eventdata, handles)
% hObject    handle to Port (see GCBO)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on selection change in Port.
function Port_Callback(hObject, eventdata, handles)
% Hints: contents = cellstr(get(hObject,'String')) returns Port contents as cell array
%        contents{get(hObject,'Value')} returns selected item from Port
% --- Executes on button press in Configuration.
function Configuration_Callback(hObject, eventdata, handles)
% hObject    handle to Configuration (see GCBO)
uint8 command;
uint8 addr;
uint8 val;
% pn=get(handles.Port,'value');
% portstr=['COM',num2str(pn)];
% s=serial(portstr);
% s.OutputBufferSize=4;
% s.InputBufferSize=27;
% set(s,'BaudRate',256000,'Parity','none','DataBits',8,'StopBits',1,'ReadAsyncMode','continuous',...
% 'BytesAvailableFcnCount',27,'BytesAvailableFcnMode','byte','BytesAvailableFcn',{@bytes,handles});
% try
%     fopen(s);
% catch
%     msgbox('Port Unavailable');
%     return;
% end
% global mark;
global scom;
sm=get(handles.Signal_Mode,'value');
if sm==1
    v2=hex2dec('20');
    v512=hex2dec('60');
else
    v2=hex2dec('30');
    v512=hex2dec('65');
end
command(1)=hex2dec('72');
command(2)=hex2dec('02');
for i=1:19
    if(i<17) addr(i)=i;
    else addr(i)=i+6;
    end
    val(i)=0;
end
addr=addr+64;
val(1)=hex2dec('86');
val(2)=v2;
val(3)=hex2dec('CC');
for k=5:12
    val(k)=v512;
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
四、运行结果
五、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
[4]郑雷,李国蕾,王晓军,王丽,刘艳霖,李颖,高泽利.心电信号采集及小波分析处理系统设计[J].实验科学与技术. 2014,12(01)
原文链接:qq912100926.blog.csdn.net/article/details/117449035
