【土壤分类】基于matlab GUI多类SVM土壤分类【含Matlab源码 1398期】
海神之光 发表于 2022/05/29 03:13:11 2022/05/29
【摘要】 一、SVM简介 支持向量机(Support Vector Machine)是Cortes和Vapnik于1995年首先提出的,它在解决小样本、非线性及高维模式识别中表现出许多特有的优势,并能够推广应用到...
一、SVM简介
支持向量机(Support Vector Machine)是Cortes和Vapnik于1995年首先提出的,它在解决小样本、非线性及高维模式识别中表现出许多特有的优势,并能够推广应用到函数拟合等其他机器学习问题中。
1 数学部分
1.1 二维空间
2 算法部分
二、部分源代码
% Project Title: Soil Detection & Classification
function varargout = SoilDetect_GUI(varargin)
% SOILDETECT_GUI MATLAB code for SoilDetect_GUI.fig
%      SOILDETECT_GUI, by itself, creates a new SOILDETECT_GUI or raises the existing
%      singleton*.
%      H = SOILDETECT_GUI returns the handle to a new SOILDETECT_GUI or the handle to
%      SOILDETECT_GUI('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in SOILDETECT_GUI.M with the given input arguments.
%      SOILDETECT_GUI('Property','Value',...) creates a new SOILDETECT_GUI or raises the
%      applied to the GUI before SoilDetect_GUI_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to SoilDetect_GUI_OpeningFcn via varargin.
% Edit the above text to modify the response to help SoilDetect_GUI
% Last Modified by GUIDE v2.5 28-Aug-2021 14:31:16
gui_Singleton = 1;
                   'gui_OpeningFcn', @SoilDetect_GUI_OpeningFcn, ...
                   'gui_OutputFcn',  @SoilDetect_GUI_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before SoilDetect_GUI is made visible.
function SoilDetect_GUI_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to SoilDetect_GUI (see VARARGIN)
% Choose default command line output for SoilDetect_GUI
handles.output = hObject;
ss = ones(300,400);
axes(handles.axes1);
imshow(ss);
axes(handles.axes2);
imshow(ss);
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes SoilDetect_GUI wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = SoilDetect_GUI_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
clc
[filename, pathname] = uigetfile({'*.*';'*.bmp';'*.jpg';'*.gif'}, 'Pick a Soil Image');
I = imread([pathname,filename]);
I = imresize(I,[256,256]);
I2 = imresize(I,[300,400]);
imshow(I2);title('Query Image');
ss = ones(300,400);
imshow(ss);
handles.ImgData1 = I;
guidata(hObject,handles);
% --- Executes on button press in pushbutton2.
function pushbutton2_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton2 (see GCBO)
I3 = handles.ImgData1;
I4 = imadjust(I3,stretchlim(I3));
I5 = imresize(I4,[300,400]);
imshow(I5);title(' Contrast Enhanced ');
handles.ImgData2 = I4;
%% Feature Extraction Part
   % queryimage = I4;
    %queryImage = imresize(queryImage, [256 256]);
    hsvHist = hsvHistogram(I4);
    autoCorrelogram = colorAutoCorrelogram(I4);
    color_moments = colorMoments(I4);
    % for gabor filters we need gary scale image
    img = double(rgb2gray(I4))/255;
    [meanAmplitude, msEnergy] = gaborWavelet(img, 4, 6); % 4 = number of scales, 6 = number of orientations
    wavelet_moments = waveletTransform(I4);
    % construct the queryImage feature vector
    Feature_Vector = [hsvHist autoCorrelogram color_moments meanAmplitude msEnergy wavelet_moments];
    whos Feature_Vector
    F1 = mean2(hsvHist(:));
    F2 = mean2(autoCorrelogram(:));
    F3 = mean2(color_moments(:));
    F4 = mean2(meanAmplitude(:));
    F5 = mean2(msEnergy(:));
    F6 = mean2(wavelet_moments(:));
    set(handles.edit3,'string',F1);
    set(handles.edit4,'string',F2);
    set(handles.edit5,'string',F3);
    set(handles.edit6,'string',F4);
    set(handles.edit7,'string',F5);
    set(handles.edit8,'string',F6);
    handles.ImgData3 = Feature_Vector;
% --- Executes on button press in pushbutton3.
function pushbutton3_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton3 (see GCBO)
load('TrainFeat_Soil.mat')
test = handles.ImgData3;
result = multisvm(TrainFeat,Train_Label,test);
disp(result);
if result == 1
    A1 = 'Clay';
    set(handles.edit1,'string',A1);
    helpdlg(' Clay ');
    disp(' Clay ');
elseif result == 2
    A2 = 'Clayey Peat';
    set(handles.edit1,'string',A2);
    helpdlg(' Clayey Peat ');
    disp('Clayey Peat');
elseif result == 3
    A3 = 'Clayey Sand';
    set(handles.edit1,'string',A3);
    helpdlg(' Clayey Sand ');
    disp(' Clayey Sand ');
elseif result == 4
    A4 = 'Humus Clay';
    set(handles.edit1,'string',A4);
    helpdlg(' Humus Clay ');
    disp(' Humus Clay ');
elseif result == 5
    A5 = 'Peat';
    set(handles.edit1,'string',A5);
    helpdlg(' Peat ');
    disp(' Peat ');
elseif result == 6
    A6 = 'Sandy Clay';
    set(handles.edit1,'string',A6);
    helpdlg(' Sandy Clay ');
    disp('Sandy Clay');
elseif result == 7
    A7 = 'Silty Sand';
    set(handles.edit1,'string',A7);
    helpdlg(' Silty Sand ');
    disp(' Silty Sand ');
end
% --- Executes on button press in pushbutton4.
function pushbutton4_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton4 (see GCBO)
load('Accuracy_Data.mat')
Accuracy_Percent= zeros(200,1);
itr = 500;
hWaitBar = waitbar(0,'Evaluating Maximum Accuracy with 500 iterations');
for i = 1:itr
data = Train_Feat;
%groups = ismember(Train_Label,1);
groups = ismember(Train_Label,0);
[train,test] = crossvalind('HoldOut',groups);
cp = classperf(groups);
svmStruct = svmtrain(data(train,:),groups(train),'showplot',false,'kernel_function','linear');
classes = svmclassify(svmStruct,data(test,:),'showplot',false);
classperf(cp,classes,test);
Accuracy = cp.CorrectRate;
Accuracy_Percent(i) = Accuracy.*100;
sprintf('Accuracy of Linear Kernel is: %g%%',Accuracy_Percent(i))
waitbar(i/itr);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
  • 212
  • 213
  • 214
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 蔡利梅.MATLAB图像处理——理论、算法与实例分析[M].清华大学出版社,2020.
[2]杨丹,赵海滨,龙哲.MATLAB图像处理实例详解[M].清华大学出版社,2013.
[3]周品.MATLAB图像处理与图形用户界面设计[M].清华大学出版社,2013.
[4]刘成龙.精通MATLAB图像处理[M].清华大学出版社,2015.
原文链接:qq912100926.blog.csdn.net/article/details/120800517
