【数字信号处理】基于matlab GUI IIR低通+FIR高通信号时域+频谱分析【含Matlab源码 1029期】
海神之光 发表于 2022/05/29 00:59:06 2022/05/29
【摘要】 一、数字信号处理系统简介 理论知识参考文献:基于GUI的《数字信号处理》教学演示系统的设计 基于Matlab GUI界面的数字信号处理辅助教学系统 基于MATLAB的数字信号处理实验平台 二、部分源代...
一、数字信号处理系统简介
基于MATLAB的数字信号处理实验平台
二、部分源代码
function varargout = program1(varargin)
% PROGRAM1 MATLAB code for program1.fig
%      PROGRAM1, by itself, creates a new PROGRAM1 or raises the existing
%      singleton*.
%      H = PROGRAM1 returns the handle to a new PROGRAM1 or the handle to
%      PROGRAM1('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in PROGRAM1.M with the given input arguments.
%      PROGRAM1('Property','Value',...) creates a new PROGRAM1 or raises the
%      applied to the GUI before program1_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to program1_OpeningFcn via varargin.
% Edit the above text to modify the response to help program1
% Last Modified by GUIDE v2.5 03-Jan-2020 09:14:21
gui_Singleton = 1;
                   'gui_OpeningFcn', @program1_OpeningFcn, ...
                   'gui_OutputFcn',  @program1_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before program1 is made visible.
function program1_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to program1 (see VARARGIN)
% Choose default command line output for program1
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes program1 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
set(handles.uipanel1,'visible','off');
set(handles.uipanel2,'visible','off');
function varargout = program1_OutputFcn(hObject, eventdata, handles)
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% hObject    handle to popupmenu1 (see GCBO)
% Hints: contents = cellstr(get(hObject,'String')) returns popupmenu1 contents as cell array
%        contents{get(hObject,'Value')} returns selected item from popupmenu1
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject    handle to pushbutton1 (see GCBO)
cla(handles.axes1,'reset');
cla(handles.axes2,'reset');
cla(handles.axes3,'reset');
axes(handles.axes1);
cla;
L=str2num(get(handles.edit1,'String'));
A=str2num(get(handles.edit2,'String'));
f1=str2num(get(handles.edit3,'String'));
f2=str2num(get(handles.edit4,'String'));
Phi=str2num(get(handles.edit5,'String'));
a=str2num(get(handles.edit6,'String'));
Sig=str2num(get(handles.edit7,'String'));
fs=1000;
phi=Phi*pi/180;
popup_sel_index = get(handles.popupmenu1, 'Value');
switch popup_sel_index
    case 1
        t=0:0.001:L;
        y=A*sin(2*pi*f1*t+phi);
        plot(t,y);
        set(gca,'Xlim',[0 1]);
        title('原始信号');
    case 2
         t=0:0.001:L;
         y=A*square(2*pi*f1*t,a);
         plot(t,y);
         title('原始信号');
    case 3
        t=0:0.001:L;
        y=A*sin(2*pi*f1*t)+A*sin(2*pi*f2*t);
        plot(t,y);
        title('原始信号');
    case 4
        n=round(1000*L);
        t=linspace(0,L,n);
        y=sqrt(Sig)*randn(1,n);
        plot(t,y);
        title('原始信号');
    case 5
        n=round(1000*L);
        t=linspace(0,L,n);
        y=sqrt(Sig)*rand(1,n);
        plot(t,y);
        title('原始信号');
end
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
function edit1_CreateFcn(hObject, eventdata, handles)
% Hint: edit controls usually have a white background on Windows.
end
function edit2_Callback(hObject, eventdata, handles)
% hObject    handle to edit2 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit2 as text
%        str2double(get(hObject,'String')) returns contents of edit2 as a double
function edit2_CreateFcn(hObject, eventdata, handles)
end
function edit3_Callback(hObject, eventdata, handles)
% hObject    handle to edit3 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit3 as text
%        str2double(get(hObject,'String')) returns contents of edit3 as a double
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
  • 209
  • 210
  • 211
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
[4]高彦彦,张晶,李莉,贾英茜.基于GUI的《数字信号处理》教学演示系统的设计[J].教育教学论坛. 2019,(48)
[5]李俊,张淑玲,帅晶.基于Matlab GUI界面的数字信号处理辅助教学系统[J].信息通信. 2020,(08)
[6]朱御康.基于MATLAB的数字信号处理实验平台[J].通信电源技术. 2021,38(03)
原文链接:qq912100926.blog.csdn.net/article/details/118052706
