【数字信号去噪】基于matlab同心兰姆波模式分解【含Matlab源码 679期】
海神之光 发表于 2022/05/29 01:23:53 2022/05/29
【摘要】 一、获取代码方式 获取代码方式1: 完整代码已上传我的资源:【数字信号去噪】基于matlab同心兰姆波模式分解【含Matlab源码 679期】 获取代码方式2: 通过订阅紫极神光博客付费专栏,凭支付凭...
一、获取代码方式
获取代码方式1:
获取代码方式2:
通过订阅紫极神光博客付费专栏,凭支付凭证,私信博主,可获得此代码。
备注:
订阅紫极神光博客付费专栏,可免费获得1份代码(有效期为订阅日起,三天内有效);
二、部分源代码
%% Parameters
clear; clc; close all; format shortg; warning off;
%% Setup folders
folderDataExp       = fullfile(cd(cd('..')),'data','exp');
%% Load raw signals
% CH0 : Dual PZT A
% CH1 : Dual PZT B
% CH2 : Dual PZT D
% CH3 : Dual PZT C
% The channel order is that only dual PZTs A, B, and D are used
% for the proposed technique, which are installed on a single side. Dual
% PZT C (CH3) is installed to validate decomposition results.
% AB_F{i,j} indicates excitation at dual PZT A and sensing at dual PZT B.
% i and j denote the different part(s) of the dual PZT activated for
% excitation and sensing. 1, 2, and 3 represent the entire, ring and
% circular parts of the dual PZT, respectively. For example, AB_F13 means
% the response signals measured at the circular part of the dual PZT B when
% both ring and circular part of dual PZT A is actuated.
% Notations are defined in similar fashion in case of FEM simulation.
% The raw signals are stored in AB_F, AD_F, CB_F and CD_F.
AB_F = cell(3,3);AD_F = cell(3,3);
CB_F = cell(3,3);CD_F = cell(3,3);
for ii=1:3
    for jj=1:3
        AB = ['180k_CH0CH1_F' int2str(ii) int2str(jj)];
        AD = ['180k_CH0CH2_F' int2str(ii) int2str(jj)];
        CB = ['180k_CH3CH1_F' int2str(ii) int2str(jj)];
        CD = ['180k_CH3CH2_F' int2str(ii) int2str(jj)];
        load(fullfile(folderDataExp,AB));
        load(fullfile(folderDataExp,AD));
        load(fullfile(folderDataExp,CB));
        load(fullfile(folderDataExp,CD));
        AB_F{ii,jj} = eval(['transpose(X' AB ');']);
        AD_F{ii,jj} = eval(['transpose(X' AD ');']);
        CB_F{ii,jj} = eval(['transpose(X' CB ');']);
        CD_F{ii,jj} = eval(['transpose(X' CD ');']);
    end
end; clearvars -except AB_F AD_F CB_F CD_F;
%% Decomposition of S0 and A0 mode signals using collocate dual PZTs
% These are considered as reference (ground-truth).
% In Section 3.2, S0 and A0 mode signals are obatined by adding and
% subtracting respones from dual PZTs B and C, respectively. (Please refer
% the following paper : S.B. Kim, H. Sohn, Instantaneous reference-free
% crack detection based on polarization characteristics of piezoelectric
% materials, Smart Mater. Struct. 16 (2007) 2375?387.
% S0_D_F_Col: S0 mode extracted from a signal measured between path AD
% using collocated PZTs
% A0_D_F_Col: A0 mode extracted from a signal measured between path AD
S0_D_F_Col = cellfun(@(x,y) plus(x,y)/2,  AD_F, CD_F,'UniformOutput',0);
A0_D_F_Col = cellfun(@(x,y) minus(x,y)/2, AD_F, CD_F,'UniformOutput',0);
% S0_B_F_Col: S0 mode extracted from a signal measured between path AB
% A0_B_F_Col: A0 mode extracted from a signal measured between path AB
S0_B_F_Col = cellfun(@(x,y) plus(x,y)/2,  AB_F, CB_F,'UniformOutput',0);
A0_B_F_Col = cellfun(@(x,y) minus(x,y)/2, AB_F, CB_F,'UniformOutput',0);
%% Decomposition of S0 and A0 mode at path AD using the proposed method
S0_range = 5000:5600;
A0_range = 5600:5900;
[~, S_LOC] = cellfun(@(x) max(x(S0_range)),AD_F);
[~, A_LOC] = cellfun(@(x) max(x(A0_range)),AD_F);
% scaling factor obtained from experiment signals
scaleFact_S_AD = cellfun(@(x,y) x(y),AD_F,num2cell(S_LOC+S0_range(1)-1));
scaleFact_A_AD = cellfun(@(x,y) x(y),AD_F,num2cell(A_LOC+A0_range(1)-1));
scalingMatrix_AD_MD  = [reshape(scaleFact_S_AD,9,1)/scaleFact_S_AD(1) ...
                        reshape(scaleFact_A_AD,9,1)/scaleFact_A_AD(1)];
% S0 and A0 modes can be reconstred by mutiplying scaling factors and
% common factors Ms = S11*C(1) for S0 mode and Ma = A11*C(2) for A0 mode.
% We know V matrix (signal matrix) and scaling matrix (scaled with S11 and
% A11) so we can compute common factor Ms and Ma. Please see eq.(7).
inv_S_AD    = pinv(scalingMatrix_AD_MD);
Ms_AD       = inv_S_AD(1,:) * cell2mat(reshape(AD_F,9,1));
Ma_AD       = inv_S_AD(2,:) * cell2mat(reshape(AD_F,9,1));
% S0 and A0 mode extracted using the proposed mode decomposition method
S0_D_F_MD = cellfun(@(x,y) x*y, repmat({Ms_AD},3,3), ...
    num2cell(reshape(scalingMatrix_AD_MD(:,1),3,3)), ...
    'UniformOutput',0);
A0_D_F_MD = cellfun(@(x,y) x*y, repmat({Ma_AD},3,3), ...
    num2cell(reshape(scalingMatrix_AD_MD(:,2),3,3)), ...
    'UniformOutput',0);
clearvars S_LOC A_LOC scaleFact_S_AD scaleFact_A_AD S0_range A0_range
clearvars inv_S_AD Ms_AD Ma_AD
inv_S_AB    = pinv(scalingMatrix_AD_MD);
Ms_AB       = inv_S_AB(1,:) * cell2mat(reshape(AB_F,9,1));
Ma_AB       = inv_S_AB(2,:) * cell2mat(reshape(AB_F,9,1));
S0_B_F_MD = cellfun(@(x,y) x*y, repmat({Ms_AB},3,3), ...
    'UniformOutput',0);
A0_B_F_MD = cellfun(@(x,y) x*y, repmat({Ma_AB},3,3), ...
    'UniformOutput',0);
clearvars S_LOC A_LOC scaleFact_S_AB scaleFact_A_AB S0_range A0_range
clearvars inv_S_AB Ms_AB Ma_AB
%% Output Plot
% Ouput folder
folderOut          = fullfile(cd(cd('..')),'output');
%% Comparison of the normalized scaling factors of the S0 and A0 modes
% In theory, the normalized scaling factors should be identical among
% these two paths as long as the sizes of the used dual PZTs are identical.
% Please see Fig. 11.
% Scaling factor computation at AD using collocate PZTS
[~, S_LOC] = cellfun(@(x) max(x(S0_range)),S0_D_F_Col);
[~, A_LOC] = cellfun(@(x) max(x(A0_range)),A0_D_F_Col);
scaleFact_S_D = ...
    cellfun(@(x,y) x(y),S0_D_F_Col,num2cell(S_LOC+S0_range(1)-1));
scaleFact_A_D = ...
    cellfun(@(x,y) x(y),A0_D_F_Col,num2cell(A_LOC+A0_range(1)-1));
scalingMatrix_AD_Col  = [reshape(scaleFact_S_D',9,1)/scaleFact_S_D(1) ...
                         reshape(scaleFact_A_D',9,1)/scaleFact_A_D(1)];
clearvars S_LOC A_LOC scaleFact_S_D scaleFact_A_D S0_range A0_range
% Scaling factor computation at AB using collocate PZTS
S0_range = 5000:5400;
A0_range = 5000:5500;
[~, S_LOC] = cellfun(@(x) max(x(S0_range)),S0_B_F_Col);
[~, A_LOC] = cellfun(@(x) max(x(A0_range)),A0_B_F_Col);
scaleFact_S_B = ...
    cellfun(@(x,y) x(y),S0_B_F_Col,num2cell(S_LOC+S0_range(1)-1));
scaleFact_A_B = ...
    cellfun(@(x,y) x(y),A0_B_F_Col,num2cell(A_LOC+A0_range(1)-1));
scalingMatrix_AB_Col   = [reshape(scaleFact_S_B',9,1)/scaleFact_S_B(1) ...
                          reshape(scaleFact_A_B',9,1)/scaleFact_A_B(1)];
clearvars S_LOC A_LOC scaleFact_S_B scaleFact_A_B S0_range A0_range
y_S0(:,1) = scalingMatrix_AD_Col(:,1);
y_S0(:,2) = scalingMatrix_AB_Col(:,1);
y_A0(:,1) = scalingMatrix_AD_Col(:,2);
y_A0(:,2) = scalingMatrix_AB_Col(:,2);
figure(1) ; x = 1:9;
h = stem(x,y_S0,'fill','--','linewidth',2);
legend('AB path', 'AD path');legend('location','northEast', ...
    'orientation', 'horizontal');legend('boxoff');
set(h(1),'MarkerFaceColor','red','Marker','s','markeredgecolor','none')
set(h(2),'MarkerFaceColor','blue','Marker','d','markeredgecolor','none')
set(gca, 'xTickLabel',{'S_1_1';'S_1_2';'S_1_3';'S_2_1'; ...
    'S_2_2';'S_2_3';'S_3_1';'S_3_2';'S_3_3';})
xlim([0 10]);%ylim([-8 8]);
set(gca,'fontsize',12,'linewidth',2,'fontweight','bold','XTick' ,[1:9]);
set(gcf,'pos',[50 50 450 250]);
xlabel('\bf Normalized scaling factor');
ylabel('\bf Normalized amplitdue');
print(fullfile(folderOut,'EXP_ScalingS0'),'-djpeg','-r0')
figure(2) ; x = 1:9;
h = stem(x,y_A0,'fill','--','linewidth',2);
set(gca, 'xTickLabel',{'A_1_1';'A_1_2';'A_1_3';'A_2_1'; ...
    'A_2_2';'A_2_3';'A_3_1';'A_3_2';'A_3_3';})
print(fullfile(folderOut,'EXP_ScalingA0'),'-djpeg','-r0')
%% Comparison between the S0 and A0 modes in the path AD
% decomposed by the proposed technique and the ones selectively generated
% by the collocated PTS. Please see Fig. 10.
% experiment parameter
startTime   =  5000;        % time point at a peak of toneburst input
fs          =  5000000;     % sampling frequency
endTime     =  6500;        % end time point to be plotted
x_path = 5000:6500;
x_time = (x_path-5000)./fs*1000 ;  % for ms
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
  • 188
  • 189
  • 190
  • 191
  • 192
  • 193
  • 194
  • 195
  • 196
  • 197
  • 198
  • 199
  • 200
  • 201
  • 202
  • 203
  • 204
  • 205
  • 206
  • 207
  • 208
三、运行结果
四、matlab版本及参考文献
1 matlab版本
2014a
2 参考文献
[1] 沈再阳.精通MATLAB信号处理[M].清华大学出版社,2015.
[2]高宝建,彭进业,王琳,潘建寿.信号与系统——使用MATLAB分析与实现[M].清华大学出版社,2020.
[3]王文光,魏少明,任欣.信号处理与系统分析的MATLAB实现[M].电子工业出版社,2018.
原文链接:qq912100926.blog.csdn.net/article/details/118118602
