【限速标志识别】基于matlab GUI形态学限速标志识别【含Matlab源码 1142期】
海神之光 发表于 2022/05/29 00:18:43 2022/05/29
【摘要】 一、简介 基于matlab GUI形态学限速标志识别 二、源代码 function varargout = Mat5_2(varargin) % MAT5_2 MATLAB code for Mat5_...
一、简介
二、源代码
% MAT5_2 MATLAB code for Mat5_2.fig
%      MAT5_2, by itself, creates a new MAT5_2 or raises the existing
%      singleton*.
%      H = MAT5_2 returns the handle to a new MAT5_2 or the handle to
%      MAT5_2('CALLBACK',hObject,eventData,handles,...) calls the local
%      function named CALLBACK in MAT5_2.M with the given input arguments.
%      MAT5_2('Property','Value',...) creates a new MAT5_2 or raises the
%      applied to the GUI before Mat5_2_OpeningFcn gets called.  An
%      unrecognized property name or invalid value makes property application
%      stop.  All inputs are passed to Mat5_2_OpeningFcn via varargin.
% Edit the above text to modify the response to help Mat5_2
% Last Modified by GUIDE v2.5 21-Jul-2021 15:09:04
gui_Singleton = 1;
                   'gui_OpeningFcn', @Mat5_2_OpeningFcn, ...
                   'gui_OutputFcn',  @Mat5_2_OutputFcn, ...
                   'gui_LayoutFcn',  [] , ...
                   'gui_Callback',   []);
end
if nargout
else
end
% --- Executes just before Mat5_2 is made visible.
function Mat5_2_OpeningFcn(hObject, eventdata, handles, varargin)
% hObject    handle to figure
% varargin   command line arguments to Mat5_2 (see VARARGIN)
% Choose default command line output for Mat5_2
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes Mat5_2 wait for user response (see UIRESUME)
% uiwait(handles.figure1);
function varargout = Mat5_2_OutputFcn(hObject, eventdata, handles)
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)%载入图像
% hObject    handle to pushbutton1 (see GCBO)
global Image
[filename,pathname]=uigetfile({'*.jpg';'*.bmp';'.gif'},'选择图片');
str=[pathname filename];
Image1 = imread(str);
Image=Image1;
axes(handles.axes1);
imshow(Image1);
function edit1_Callback(hObject, eventdata, handles)
% hObject    handle to edit1 (see GCBO)
% Hints: get(hObject,'String') returns contents of edit1 as text
%        str2double(get(hObject,'String')) returns contents of edit1 as a double
% --- Executes during object creation, after setting all properties.
function edit1_CreateFcn(hObject, eventdata, handles)
% handles    empty - handles not created until after all CreateFcns called
% Hint: edit controls usually have a white background on Windows.
%       See ISPC and COMPUTER.
if ispc && isequal(get(hObject,'BackgroundColor'), get(0,'defaultUicontrolBackgroundColor'))
    set(hObject,'BackgroundColor','white');
end
function BW = imbinarize(I,varargin) %#codegen
%imbinarize Binarize image by thresholding.
%   Copyright 2015-2018 The MathWorks, Inc.
%   Syntax
%       BW = imbinarize(I)
%       BW = imbinarize(I,method)
%       BW = imbinarize(I,'adaptive',Param,Value,...)
%       BW = imbinarize(I,t)
%   Input Specs
%      I:
%        real
%        non-sparse
%        2d
%        uint8, uint16, uint32, int8, int16, int32, single or double
%      method:
%        string with value: 'global' or 'adaptive'
%        default: 'global'
%      Sensitivity:
%        numeric
%        real
%        non-sparse
%        scalar
%        non-negative
%        <= 1
%        default: 0.5
%        converted to double
%      ForegroundPolarity:
%        string with value either 'bright' or 'dark'
%        default: 'bright'
%      t:
%        numeric
%        real
%        non-sparse
%        2d
%        either scalar or matrix of the same size as I
%   Output Specs
%     BW:
%       logical
%       2D matrix
%       same size as I
% Validate the input image
validateImage(I);
% Parse and validate optional inputs
[isNumericThreshold,options] = parseOptionalInputs(I,varargin{:});
coder.internal.prefer_const(isNumericThreshold,options);
if isNumericThreshold
    BW = binarize(I,options.t);
else
    if strcmp(options.method,'global')
        % BW = imbinarize(I,'global')
        t = computeGlobalThreshold(I);
    else
        % BW = imbinarize(I,'adaptive',...)
        t = adaptthresh(I,options.sensitivity,'ForegroundPolarity',options.polarity);
    end
    BW = binarize(I,t);
end
  • 26
  • 27
  • 28
  • 29
  • 30
  • 31
  • 32
  • 33
  • 34
  • 35
  • 36
  • 37
  • 38
  • 39
  • 40
  • 41
  • 42
  • 43
  • 44
  • 45
  • 46
  • 47
  • 48
  • 49
  • 50
  • 51
  • 52
  • 53
  • 54
  • 55
  • 56
  • 57
  • 58
  • 59
  • 60
  • 61
  • 62
  • 63
  • 64
  • 65
  • 66
  • 67
  • 68
  • 69
  • 70
  • 71
  • 72
  • 73
  • 74
  • 75
  • 76
  • 77
  • 78
  • 79
  • 80
  • 81
  • 82
  • 83
  • 84
  • 85
  • 86
  • 87
  • 88
  • 89
  • 90
  • 91
  • 92
  • 93
  • 94
  • 95
  • 96
  • 97
  • 98
  • 99
  • 100
  • 101
  • 102
  • 103
  • 104
  • 105
  • 106
  • 107
  • 108
  • 109
  • 110
  • 111
  • 112
  • 113
  • 114
  • 115
  • 116
  • 117
  • 118
  • 119
  • 120
  • 121
  • 122
  • 123
  • 124
  • 125
  • 126
  • 127
  • 128
  • 129
  • 130
  • 131
  • 132
  • 133
  • 134
  • 135
  • 136
  • 137
  • 138
  • 139
  • 140
  • 141
  • 142
  • 143
  • 144
  • 145
  • 146
  • 147
  • 148
  • 149
  • 150
  • 151
  • 152
  • 153
  • 154
  • 155
  • 156
  • 157
  • 158
  • 159
  • 160
  • 161
  • 162
  • 163
  • 164
  • 165
  • 166
  • 167
  • 168
  • 169
  • 170
  • 171
  • 172
  • 173
  • 174
  • 175
  • 176
  • 177
  • 178
  • 179
  • 180
  • 181
  • 182
  • 183
  • 184
  • 185
  • 186
  • 187
三、运行结果
四、备注
版本:2014a
原文链接:qq912100926.blog.csdn.net/article/details/118964042
